YACS::ENGINE::OptimizerAlgASync Class Referenceabstract
Base class to implement in external dynamic lib in case of optimizer non event oriented. More...
#include <OptimizerAlg.hxx>
Inheritance diagram for YACS::ENGINE::OptimizerAlgASync:
Collaboration diagram for YACS::ENGINE::OptimizerAlgASync:
virtual ~OptimizerAlgASync ()
virtual void finishProxy ()
- Public Member Functions inherited from YACS::ENGINE::OptimizerAlgBase
virtual TypeCode * getTCForInProxy () const
virtual TypeCode * getTCForOutProxy () const
virtual TypeCode * getTCForAlgoInitProxy () const
virtual TypeCode * getTCForAlgoResultProxy () const
virtual void initializeProxy (const Any *input)
virtual void startProxy ()
virtual void takeDecisionProxy ()
virtual Any * getAlgoResultProxy ()
virtual void setPool (Pool *pool)
virtual void setProc (Proc *proc)
virtual Proc * getProc ()
virtual bool hasError () const
virtual const std::string & getError () const
virtual void setError (const std::string &message)
void setNbOfBranches (int nbOfBranches)
int getNbOfBranches () const
void incrRef () const
bool decrRef () const
 OptimizerAlgASync (Pool *pool)
virtual void start ()
 Called when optimization has succeed. More...
virtual void takeDecision ()
 Update _pool attribute before performing anything. More...
virtual void run ()
virtual void startToTakeDecision ()=0
- Protected Member Functions inherited from YACS::ENGINE::OptimizerAlgBase
 OptimizerAlgBase (Pool *pool)
virtual ~OptimizerAlgBase ()
virtual TypeCode * getTCForIn () const =0
 returns typecode of type expected as Input. OwnerShip of returned pointer is held by this. More...
virtual TypeCode * getTCForOut () const =0
 returns typecode of type expected as Output. OwnerShip of returned pointer is held by this. More...
virtual TypeCode * getTCForAlgoInit () const
 returns typecode of type expected for algo initialization. OwnerShip of returned pointer is held by this. More...
virtual TypeCode * getTCForAlgoResult () const
 returns typecode of type expected as algo result. OwnerShip of returned pointer is held by this. More...
virtual void initialize (const Any *input)
virtual void start ()=0
virtual void takeDecision ()=0
virtual void finish ()
virtual Any * getAlgoResult ()
 RefCounter ()
virtual ~RefCounter ()
- Protected Attributes inherited from YACS::ENGINE::OptimizerAlgBase
Pool * _pool
Proc * _proc
std::string _errorMessage
int _nbOfBranches
unsigned int _cnt
Definition at line 99 of file OptimizerAlg.hxx.
◆ OptimizerAlgASync()
OptimizerAlgASync::OptimizerAlgASync ( Pool *  pool)
Definition at line 143 of file OptimizerAlg.cxx.
143 :OptimizerAlgBase(pool)
144{
145}
◆ ~OptimizerAlgASync()
OptimizerAlgASync::~OptimizerAlgASync ( )
Definition at line 147 of file OptimizerAlg.cxx.
148{
149}
◆ finishProxy()
void OptimizerAlgASync::finishProxy ( )
Reimplemented from YACS::ENGINE::OptimizerAlgBase.
Definition at line 151 of file OptimizerAlg.cxx.
152{
153 terminateSlaveThread();
155}
References YACS::ENGINE::OptimizerAlgBase::finishProxy().
◆ run()
void OptimizerAlgASync::run ( )
_pool->getCurrentId gives the id at the origin of this call. Perform the job of analysing to know what new jobs to do (_pool->pushInSample) or in case of convergence _pool->destroyAll
Definition at line 167 of file OptimizerAlg.cxx.
References YACS::ENGINE::OptimizerAlgBase::_pool, YACS::ENGINE::Pool::destroyAll(), and startToTakeDecision().
◆ start()
void OptimizerAlgASync::start ( )
Implements YACS::ENGINE::OptimizerAlgBase.
Definition at line 162 of file OptimizerAlg.cxx.
163{
164 AlternateThread::start();
165}
◆ startToTakeDecision()
virtual void YACS::ENGINE::OptimizerAlgASync::startToTakeDecision ( )
protectedpure virtual
_pool->getCurrentId gives the id at the origin of this call. Perform the job between 2 'condition->wait()' of analysing to know what new jobs to do (_pool->pushInSample) or in case of convergence _pool->destroyAll WARNING ! 'condition->wait()' must be called before any analyse of Pool.
Referenced by run().
◆ takeDecision()
void OptimizerAlgASync::takeDecision ( )
Definition at line 157 of file OptimizerAlg.cxx.
158{
159 signalSlaveAndWait();
160}
