YACS::ENGINE::PyOptimizerAlgASync Class Referenceabstract
Base class to implement in external dynamic lib or external python module in case of a non event oriented optimizer using Python code. More...
#include <PyOptimizerAlg.hxx>
Inheritance diagram for YACS::ENGINE::PyOptimizerAlgASync:
Collaboration diagram for YACS::ENGINE::PyOptimizerAlgASync:
virtual ~PyOptimizerAlgASync ()
virtual void startProxy ()
virtual void takeDecisionProxy ()
virtual void finishProxy ()
virtual void signalMasterAndWait ()
 Called when optimization has succeed. More...
- Public Member Functions inherited from YACS::ENGINE::PyOptimizerAlgBase
virtual ~PyOptimizerAlgBase ()
virtual TypeCode * getTCForInProxy () const
virtual TypeCode * getTCForOutProxy () const
virtual TypeCode * getTCForAlgoInitProxy () const
virtual TypeCode * getTCForAlgoResultProxy () const
virtual void initializeProxy (const Any *input)
virtual Any * getAlgoResultProxy ()
- Public Member Functions inherited from YACS::ENGINE::OptimizerAlgBase
virtual void setPool (Pool *pool)
virtual void setProc (Proc *proc)
virtual Proc * getProc ()
virtual bool hasError () const
virtual const std::string & getError () const
virtual void setError (const std::string &message)
void setNbOfBranches (int nbOfBranches)
int getNbOfBranches () const
void incrRef () const
bool decrRef () const
 PyOptimizerAlgASync (Pool *pool)
virtual void start ()
virtual void takeDecision ()
 Update _pool attribute before performing anything. More...
virtual void run ()
virtual void startToTakeDecision ()=0
- Protected Member Functions inherited from YACS::ENGINE::PyOptimizerAlgBase
 PyOptimizerAlgBase (Pool *pool)
- Protected Member Functions inherited from YACS::ENGINE::OptimizerAlgBase
virtual ~OptimizerAlgBase ()
virtual TypeCode * getTCForIn () const =0
 returns typecode of type expected as Input. OwnerShip of returned pointer is held by this. More...
virtual TypeCode * getTCForOut () const =0
 returns typecode of type expected as Output. OwnerShip of returned pointer is held by this. More...
virtual TypeCode * getTCForAlgoInit () const
 returns typecode of type expected for algo initialization. OwnerShip of returned pointer is held by this. More...
virtual TypeCode * getTCForAlgoResult () const
 returns typecode of type expected as algo result. OwnerShip of returned pointer is held by this. More...
virtual void initialize (const Any *input)
virtual void start ()=0
virtual void takeDecision ()=0
virtual void finish ()
virtual Any * getAlgoResult ()
 RefCounter ()
virtual ~RefCounter ()
- Protected Attributes inherited from YACS::ENGINE::OptimizerAlgBase
Pool * _pool
Proc * _proc
std::string _errorMessage
int _nbOfBranches
unsigned int _cnt
Definition at line 57 of file PyOptimizerAlg.hxx.
◆ ~PyOptimizerAlgASync()
PyOptimizerAlgASync::~PyOptimizerAlgASync ( )
Definition at line 114 of file PyOptimizerAlg.cxx.
115{
116 if (getThreadStatus() == AlternateThread::UNEXISTING) return;
117
118 Py_BEGIN_ALLOW_THREADS;
119 try {
120 // Force the thread termination. We must allow Python threads for that because the
121 // thread cleanup includes some Python cleanup.
122 terminateSlaveThread();
123 } catch (const exception & e) {
124 cerr << "Exception happened in PyOptimizerAlgASync destructor: " << e.what() << endl;
125 } catch (...) {
126 cerr << "Unknown exception happened in PyOptimizerAlgASync destructor." << endl;
127 }
128 Py_END_ALLOW_THREADS;
129}
◆ PyOptimizerAlgASync()
PyOptimizerAlgASync::PyOptimizerAlgASync ( Pool *  pool)
Definition at line 109 of file PyOptimizerAlg.cxx.
110 : PyOptimizerAlgBase(pool)
111{
112}
◆ finishProxy()
void PyOptimizerAlgASync::finishProxy ( )
Reimplemented from YACS::ENGINE::PyOptimizerAlgBase.
Definition at line 141 of file PyOptimizerAlg.cxx.
142{
143 terminateSlaveThread();
145}
References YACS::ENGINE::PyOptimizerAlgBase::finishProxy().
◆ run()
void PyOptimizerAlgASync::run ( void  )
_pool->getCurrentId gives the id at the origin of this call. Perform the job of analysing to know what new jobs to do (_pool->pushInSample) or in case of convergence _pool->destroyAll
Definition at line 164 of file PyOptimizerAlg.cxx.
165{
166 GILState gs;
168}
virtual void startToTakeDecision()=0
References startToTakeDecision().
◆ signalMasterAndWait()
void PyOptimizerAlgASync::signalMasterAndWait ( )
Definition at line 157 of file PyOptimizerAlg.cxx.
158{
159 Py_BEGIN_ALLOW_THREADS;
160 AlternateThread::signalMasterAndWait();
161 Py_END_ALLOW_THREADS;
162}
◆ start()
void PyOptimizerAlgASync::start ( void  )
Implements YACS::ENGINE::OptimizerAlgBase.
Definition at line 147 of file PyOptimizerAlg.cxx.
148{
149 AlternateThread::start();
150}
Referenced by startProxy().
◆ startProxy()
void PyOptimizerAlgASync::startProxy ( )
Definition at line 131 of file PyOptimizerAlg.cxx.
132{
133 start();
134}
References start().
◆ startToTakeDecision()
virtual void YACS::ENGINE::PyOptimizerAlgASync::startToTakeDecision ( )
protectedpure virtual
_pool->getCurrentId gives the id at the origin of this call. Perform the job between 2 'condition->wait()' of analysing to know what new jobs to do (_pool->pushInSample) or in case of convergence _pool->destroyAll WARNING ! 'condition->wait()' must be called before any analyse of Pool.
Referenced by run().
◆ takeDecision()
void PyOptimizerAlgASync::takeDecision ( )
Definition at line 152 of file PyOptimizerAlg.cxx.
153{
154 signalSlaveAndWait();
155}
Referenced by takeDecisionProxy().
◆ takeDecisionProxy()
void PyOptimizerAlgASync::takeDecisionProxy ( )
Definition at line 136 of file PyOptimizerAlg.cxx.
137{
138 takeDecision();
139}
virtual void takeDecision()
References takeDecision().
