The case
The variables are described in The creation of a case.
Methods of the class homard
Creation of a case
CreateCase(case_name, mesh_name, mesh_file)
Returns an instance of the class cas after its creation
  • case_name: the name of the case
  • mesh_name: the name of the initial mesh
  • mesh_file: the name of the MED file of this mesh
Default:
  • the directory for the results is /tmp
  • the adaptation is conformal
GetCase(case_name)
Returns an instance of the class cas known by its name
GetAllCasesName()
Returns the liste of the name of all the existing cases
Creation of a case by pursuit of a computed iteration
CreateCaseFromIteration(case_name, dir_name)
  • dir_name: the name of the directory that contains the iteration
CreateCaseFromCaseLastIteration(case_name, dir_name)
  • dir_name: the name of the directory that contains the case
CreateCaseFromCaseIteration(case_name, dir_name, number)
  • number: the number of the iteration of the case
Methods of the class cas
GetName()
Returns the name of the case
SetDirName(dirname)
Gives a directory for the results of the case. It can be done only after the creation of the case and before the first computation.
  • dirname: the name of the directory of the results
GetDirName()
Returns the name of the directory of the results of the case
SetConfType(conf_type)
Defines the type of conformity for the case
  • conf_type: integer as follows:
    • 0: conformal (default)
    • 1: non conformal with at max 2 cut edges per element
    • 2: non conformal with one hanging node per edge of element
    • 3: non conformal without any constraint
    • -1: conformal with boxes (no staircases)
    • -2: non-conformal with boxes (no staircases)
GetConfType()
Returns the type of conformity
SetExtType(ext_type)
Defines the external type for the case
  • ext_type : integer as follows:
    • 0 : Standard MED (default)
    • 1 : Saturne MED
    • 2 : Saturne 2D MED
GetExtType()
Returns the external type for the case
GetIter0()
Returns the iteration linked to the initial mesh. This iteration is automatically created by the module HOMARD. It is used to connect the iterations. It is connected to an initial mesh or to the iteration of a previous case.
AddBoundary(boundary)
Add a boundary to the definition of a case
  • boundary: name of the curved boundary
AddBoundaryGroup(boundary, group)
Discrete boundary:
. if all the curved lines are involved, the second argument is an empty string. . if only some curved lines are involved, group is the name of the group of segments
Analytical boundary:
  • group: name of the group of faces located on the boundary
Delete(option)
Deletes the case and all the connected iterations. The MED file of the first mesh is kept.
  • option: an integer to define what to do with the MED file of the associated meshes
    • 0: the files are kept
    • 1: the files are removed
Returns an integer:
  • 0: the destruction is done
  • other value: problem
GetState()
Returns the state of the case:
  • 0: corresponds to an initial mesh
  • other value: pursuit of an iteration with number n
WriteYACSSchema(ScriptFile, DirName, MeshFile)
Writes a schema YACS relative to the case.
  • ScriptFile : name of the file that contains the script to launch the computation
  • DirName : the directory for the computation
  • MeshFile : name of the file that contains the mesh for the very first computation
Advanced options
SetPyram(option)
Defines the status of the pyramids in this case
  • option: integer that defines the status of the pyramids that could belongs to the initial mesh
    • 0: rejected pyramids (default)
    • 1: authorized pyramids
GetPyram()
Returns the status of the pyramids in this case
Informations for the initial mesh
MeshInfo(Qual, Diam, Conn, Tail, Inte)
Gives information about the current mesh. For every option, the choice #0 corresponds to ‘no action’, while the choice #1 launches the option.
  • Qual: quality of the elements
  • Diam: diametre of the elements
  • Conn: connexity of the domain; a single block, how many holes, etc.
  • Tail: size of the parts of the domain, group by group
  • Inte: staggered elements, by dimension
Example
The creation of the object case_1 is done as follows:
case_name = "CAS_1"
mesh_name = "MAILL"
mesh_file = "/scratch/Salome/Adapt/m0.med"
case_1 = homard.CreateCase(case_name, mesh_name, mesh_file)
dirname = "/scratch/Salome/Adapt/resu"
case_1.SetDirName(dirname)
case_1.SetConfType(1)
case_1.AddBoundaryGroup( 'intersection', '' )
case_1.AddBoundaryGroup( 'cyl_1', 'T1_EXT' )
case_1.AddBoundaryGroup( 'cyl_1', 'T2_EXT' )
case_1.AddBoundaryGroup( 'cyl_2', 'T_INT' )
Similar graphical input
Look at The creation of a case
