The boundary
The variables are described in The boundary.
Methods of the class homard
These methods returns an instance of the class boundary.
CreateBoundaryCAO(boundary_name, xao_file)
Returns an instance of the class boundary, type CAO after its creation
  • boundary_name: the name of the CAO boundary
  • xao_file: the name of the file for this CAO, with format XAO
CreateBoundaryDi(boundary_name, mesh_name, mesh_file)
Returns an instance of the class boundary, type discrete after its creation
  • boundary_name: the name of the discrete boundary
  • mesh_name: the name of the mesh of the boundary
  • mesh_file: the name of the file for this mesh, with format MED
CreateBoundaryCylinder(boundary_name, Xcen, Ycen, Zcen, Xaxe, Yaxe, Zaxe, R)
Returns an instance of the class boundary analytical type cylindrical after its creation
  • boundary_name: the name of the analytical boundary based on a cylinder
  • Xcen, Ycen, Zcen: coordinates of a point on the axis of the cylinder
  • Xaxe, Yaxe, Zaxe: vector of the axis
  • R: radius of the cylinder
CreateBoundarySphere(boundary_name, Xcen, Ycen, Zcen, R)
Returns an instance of the class boundary analytical type spherical after its creation
  • boundary_name: the name of the boundary analytique based on a sphere
  • Xcen, Ycen, Zcen: coordinates of the centre of the sphere
  • R: radius of the sphere
CreateBoundaryConeA(boundary_name, Xaxe, Yaxe, Zaxe, Angle, Xcen, Ycen, Zcen)
Returns an instance of the class boundary analytical type conical after its creation
  • boundary_name: the name of the boundary analytique based on a cone
  • Angle: opening angle of the cone in degree (between 0 and 90)
  • Xcen, Ycen, Zcen: coordinates of the centre of the cone
CreateBoundaryConeR(boundary_name, Xc1, Yc1, Zc1, R1, Xc2, Yc2, Zc2, R2)
  • Xc1, Yc1, Zc1: coordinates of the first centre of the cone
  • R1: radius of the cone at the first centre of the cone
  • Xc2, Yc2, Zc2: coordinates of the second centre of the cone
  • R2: radius of the cone at the second centre of the cone
CreateBoundaryTorus(boundary_name, Xcen, Ycen, Zcen, Xaxe, Yaxe, Zaxe, RRev, RPri)
Returns an instance of the class boundary analytical type torus after its creation
  • boundary_name: the name of the analytical boundary based on a torus
  • Xcen, Ycen, Zcen: coordinates of the centre of the torus
  • RRev: revolution radius of the torus
  • RPri: primary radius of the torus
GetBoundary(boundary_name)
Returns the instance of the class classe boundary known by its name
GetAllBoundarysName()
Returns the list of the names of all the existing boundaries
Methods of the class cas
See also in The case.
AddBoundary(boundary)
Add a boundary to the definition of a case
  • boundary: name of the curved boundary
AddBoundaryGroup(boundary, group)
Add a boundary to the definition of a case with a filtering by groups
Discrete or CAO boundary:
  • group: the name of a group of meshes
Analytical boundary:
  • group: name of the groups of faces located on the boundary
Methods of the class boundary
GetName()
Returns the name of the boundary
GetType()
Returns the type of the boundary:
  • -1: CAO
  • 0: discrete
  • 1: cylinder
  • 2: sphere
  • 3: cone defined by an axis and an angle
  • 4: cone defined by 2 radius
  • 5: torus
GetCoords()
Returns the array of the coordinates of the boundary with the same order as in its definition with CreateBoundaryXXXX
Delete()
Deletes the boundary. If the boundary is discrete, the file of the mesh is kept. If the boundary is CAO, the xao file of the geometry is kept.
Returns an integer:
  • 0: the destruction is done
  • other value: problem
Example
Creation of a CAO boundary:
la_cao = homard.CreateBoundaryCAO("BLOC", dircase+'/tutorial_6.xao')
Creation of a discrete boundary, a spherical boundary, and a cylindrical boundary:
inter = homard.CreateBoundaryDi("INTERSECTION", 'PIQUAGE', dircase+'/tutorial_4.fr.med')
fron_1 = homard.CreateBoundarySphere("FRON_1", 12.3, 3.4, .56, 6.5)
fron_2 = homard.CreateBoundaryCylinder('CYL_1', 0.0, 25., -25., 25., 50., 75., 100.)
Similar graphical input
Look at The boundary
