The iteration
The variables are described in The iteration.
Methods of the class homard
Methods of both classes cas and iteration ************************************” See also in The case.
Default: the produced mesh has got the same name as the iteration
Methods of the class iteration
General methods
Information about the meshes
Information about the field
The file of the fields
The time step for the driving field
If no time step is defined for the field or if a single time step is defined for the field, the definition of a time step is useless. That will be the default choice.
The time steps for the fields to interpolate
The choice of the fields to interpolated are defined in the hypothesis (see The hypothesis). For a given field, if nothing is declared, every single time step will be considered. If some time steps are wanted, they must be defined as follows.
Miscellenaous
Example
To create the first iteration, the starting point is the iteration associated to the initial mesh. It is the one that defines the case.
iter_name = "Iteration_1"
iter_1 = case_1.NextIteration(iter_name)
iter_1.SetField(field_file)
iter_1.SetTimeStepRank( 0, 0)
iter_1.SetMeshName("maill_01")
iter_1.SetMeshFile("/local00/M.01.med")
iter_1.AssociateHypo("HypoField")
codret = iter_1.Compute(1, 2)
Then, the next iteration is created from the current iteration.
iter_name = "Iteration_2"
iter_2 = iter_1.NextIteration(iter_name)
iter_2.SetField(field_file)
iter_2.SetTimeStepRank( 1, 1)
iter_2.SetMeshName("maill_02")
iter_2.SetMeshFile("/local00/M.02.med")
iter_2.AssociateHypo("HypoField")
codret = iter_2.Compute(1, 2)
Similar graphical input
Look at The iteration
