- CreateZoneBox(zone_name, Xmin, Xmax, Ymin, Ymax, Zmin, Zmax)
Returns an instance of the class zone of type box
after its creation
zone_name: the name of the zone based on a box
Xmin, Xmax: min/max coordinates extrêmes along X
Ymin, Ymax: min/max coordinates extrêmes along Y
Zmin, Zmax: min/max coordinates extrêmes along Z
- CreateZoneCylinder(zone_name, Xbase, Ybase, Zbase, Xaxe, Yaxe, Zaxe, R, H)
Returns an instance of the class zone of type cylinder
after its creation
zone_name: the name of the zone based on a cylinder
Xbase, Ybase, Zbase: coordinates of a point on the axis
Xaxe, Yaxe, Zaxe: vector of the axis
R: radius of the cylinder
H: height of the cylinder
- CreateZonePipe(zone_name, Xbase, Ybase, Zbase, Xaxe, Yaxe, Zaxe, R, H, Rint)
Returns an instance of the class zone of type pipe
after its creation
zone_name: the name of the zone based on a pipe
R: external radius of the pipe
H: height of the pipe
R: internal radius of the pipe
- CreateZoneSphere(zone_name, Xcen, Ycen, Zcen, R)
Returns an instance of the class zone of type sphere
after its creation
zone_name: the name of the zone based on a sphere
Xcen, Ycen, Zcen: coordinates of the center of the sphere
R: radius of the sphere
- CreateZoneBox2D(zone_name, Umin, Umax, Vmin, Vmax, Orient)
Returns an instance of the class zone of type rectangle
after its creation
zone_name: the name of the zone based on a rectangle
Umin, Umax: min/max coordinates for the 1st dimension
Vmin, Vmax: min/max coordinates for the 2nd dimension
Orient: integer that defines the convention for the plane
- CreateZoneDisk(zone_name, Ucen, Vcen, R, Orient)
Returns an instance of the class zone of type disk
after its creation
zone_name: the name of the zone based on a full disk
Ucen, Vcen: coordinates of the center of the disk
R: radius of the disk
- CreateZoneDiskWithHole(zone_name, Ucen, Vcen, R, Rint, Orient)
Returns an instance of the class zone of type disk with a hole
after its creation
zone_name: the name of the zone based on a disk with a hole
R: external radius of the disk
Rint: internal radius of the disk
