Parallel Computing
Warning
This functionality is a work in progress.
It is only available for NETGEN.
It is only available in TUI.
The goal here is to speed up computation by running sub-meshes in parallel (multi-threading).
Concept
In order to parallelise the computation of the mesh we split the geometry into:
A 1D+2D compound
A list of 3D solids
Then create a sub-mesh for each of those geometry. And associate Hypothesis to the mesh using a hypothesis on the whole geometry
We will first compute sequentially the 1D+2D compound with NETGEN_1D2D.
Then we will compute all the solids in parallel. Having done the 1D+2D first ensure that all the solids can be computed without any concurrency.
How to
You follow the same principle as the creation of a sequential Mesh.
First you create the mesh:
par_mesh = smesh.ParallelMesh(my_geom, name="par_mesh")
Define the Global Hypothesis that will be split into an hypothesis for the 1D+2D compound and one for each of the 3D solids:
NETGEN_3D_Parameters_1 = smesh.CreateHypothesisByAverageLength( 'NETGEN_Parameters', 'NETGENEngine', 34.641, 0 ) par_mesh.AddGlobalHypothesis(NETGEN_3D_Parameters_1)
Set the method for the parallelisation:
You have two methods for parallelisation:
Multihtreading: Will run the computation on your computer using the processors on your computer.
par_mesh.SetParallelismMethod(smeshBuilder.MULTITHREAD)
MultiNodal: Will run the computation on a remote resource (cluster) that is defined in your salome catalog.
par_mesh.SetParallelismMethod(smeshBuilder.MULTINODE)
Set the parameters for the parallelism:
Multithread:
param = par_mesh.GetParallelismSettings() param.SetNbThreads(6)Multinode:
param = par_mesh.GetParallelismSettings() param.SetResource("cronos") param.SetNbProc(nbox**3) param.SetNbProcPerNode(2) param.SetNbNode(6) param.SetWcKey("P11N0:SALOME_COFEE")
- Compute the mesh:
is_done = par_mesh.Compute() if not is_done: raise Exception("Error when computing Mesh")
See Also a sample script of Creating Parallel Mesh.
