Creating Meshes
First of all see Example of 3d mesh generation: which is an example of good python script style for Mesh module.
Construction of a mesh
# Construction of a Mesh
import salome
salome.salome_init_without_session()
from salome.smesh import smeshBuilder
geom_builder = geomBuilder.New()
smesh_builder = smeshBuilder.New()
# create a box
box = geom_builder.MakeBox(0., 0., 0., 100., 200., 300.)
idbox = geom_builder.addToStudy(box, "box")
# create a mesh
tetra = smesh_builder.Mesh(box, "MeshBox")
algo1D = tetra.Segment()
algo1D.NumberOfSegments(7)
algo2D = tetra.Triangle()
algo2D.MaxElementArea(800.)
algo3D = tetra.Tetrahedron()
algo3D.MaxElementVolume(900.)
# compute the mesh
ret = tetra.Compute()
if not ret:
raise Exception("problem when computing the mesh")
print("mesh computed")
Construction of a sub-mesh
# Construction of a Sub-mesh
import salome
# create a box
box = geom_builder.MakeBoxDXDYDZ(10., 10., 10.)
geom_builder.addToStudy(box, "Box")
# select one edge of the box for definition of a local hypothesis
p5 = geom_builder.MakeVertex(5., 0., 0.)
EdgeX = geom_builder.GetEdgeNearPoint(box, p5)
geom_builder.addToStudyInFather(box, EdgeX, "Edge [0,0,0 - 10,0,0]")
# create a hexahedral mesh on the box
mesh = smesh_builder.Mesh(box, "Box : hexahedral 3D mesh")
# create a Regular_1D algorithm for discretization of edges
algo1D = mesh.Segment()
# define "NumberOfSegments" hypothesis to cut
# all the edges in a fixed number of segments
algo1D.NumberOfSegments(4)
# create a quadrangle 2D algorithm for the faces
mesh.Quadrangle()
# construct a sub-mesh on the edge with a local Regular_1D algorithm
algo_local = mesh.Segment(EdgeX)
# define "Arithmetic1D" hypothesis to cut EdgeX in several segments with length arithmetically
# increasing from 1.0 to 4.0
algo_local.Arithmetic1D(1, 4)
# define "Propagation" hypothesis that propagates algo_local and "Arithmetic1D" hypothesis
# from EdgeX to all parallel edges
algo_local.Propagation()
# assign a hexahedral algorithm
mesh.Hexahedron()
# any sub-shape can be meshed individually --
# compute mesh on two surfaces using different methods
# get surfaces
surfaces = geom_builder.SubShapeAll(box, geom_builder.ShapeType["FACE"])
# method 1: no sub-mesh is created
if not mesh.Compute( surfaces[0] ): raise Exception("Error when computing Mesh")
# method 2: a sub-mesh is created
submesh = mesh.GetSubMesh( surfaces[2], "submesh 2" )
if not submesh.Compute(): raise Exception("Error when computing Mesh")
# compute the whole mesh
if not mesh.Compute(): raise Exception("Error when computing Mesh")
Change priority of sub-meshes in mesh
# Change priority of sub-meshes in Mesh
import salome
box = geom_builder.MakeBoxDXDYDZ(200, 200, 200)
[Face_1, Face_2, Face_3, Face_4, Face_5, Face_6] = geom_builder.SubShapeAllSorted(box, geom_builder.ShapeType["FACE"])
# create Mesh object on Box shape
mesh = smesh_builder.Mesh(box)
# assign mesh algorithms and hypotheses
mesh.Segment().NumberOfSegments(20)
mesh.Triangle().MaxElementArea(1200)
mesh.Tetrahedron().MaxElementVolume(40000)
# create sub-mesh and assign algorithms on Face_1
mesh.Segment(geom=Face_1).NumberOfSegments(4)
mesh.Triangle(geom=Face_1)
# create sub-mesh and assign algorithms on Face_2
mesh.Segment(geom=Face_2).NumberOfSegments(8)
mesh.Triangle(geom=Face_2)
# create sub-mesh and assign algorithms on Face_3
mesh.Segment(geom=Face_3).NumberOfSegments(12)
mesh.Triangle(geom=Face_3)
# get existing sub-mesh priority order: F1 -> F2 -> F3
[[SubMesh_F1, SubMesh_F3, SubMesh_F2]] = mesh.GetMeshOrder()
isDone = mesh.Compute()
if not isDone: raise Exception("Error when computing Mesh")
print("Nb elements at initial order of sub-meshes:", mesh.NbElements())
# set new sub-mesh order: F2 -> F1 -> F3
isDone = mesh.SetMeshOrder([[SubMesh_F2, SubMesh_F1, SubMesh_F3]])
print("Nb elements at new order of sub-meshes:", mesh.NbElements())
# compute with other sub-mesh order: F3 -> F2 -> F1
isDone = mesh.SetMeshOrder([[SubMesh_F3, SubMesh_F2, SubMesh_F1]])
print("Nb elements at another order of sub-meshes:", mesh.NbElements())
Intermediate edition while meshing
import salome
geompy = geomBuilder.New()
# This script demonstrates generation of 3D mesh basing on a modified 2D mesh
# Purpose is to get a tetrahedral mesh in a sphere cut by a cube.
# The requirement is to have a surface mesh on the cube comprised of
# triangles of exactly the same size arranged in a grid pattern.
# To fulfill this requirement we mesh the box using Quadrangle: Mapping
# meshing algorithm, split quadrangles into triangles and then generate
# tetrahedrons.
# Make the geometry
Box_1 = geompy.MakeBox(-100,-100,-100, 100, 100, 100)
Sphere_1 = geompy.MakeSphereR( 300 )
Cut_1 = geompy.MakeCut(Sphere_1, Box_1, theName="Cut_1")
# get a spherical face
Sph_Face = geompy.ExtractShapes( Sphere_1, geompy.ShapeType["FACE"] )[0]
# get the shape Sph_Face turned into during MakeCut()
Sph_Face = geompy.GetInPlace(Cut_1, Sph_Face, isNewImplementation=True, theName="Sphere_1")
# 1) Define a mesh with 1D and 2D meshers
import SMESH
smesh = smeshBuilder.New()
Mesh_1 = smesh.Mesh(Cut_1)
# "global" meshers (assigned to Cut_1) that will be used for the box
Regular_1D = Mesh_1.Segment()
Local_Length_1 = Regular_1D.LocalLength(20)
Quadrangle_2D = Mesh_1.Quadrangle()
# a "local" mesher (assigned to a sub-mesh on Sphere_1) to mesh the sphere
algo_2D = Mesh_1.Triangle( smeshBuilder.NETGEN_1D2D, Sph_Face )
algo_2D.SetMaxSize( 70. )
algo_2D.SetFineness( smeshBuilder.Moderate )
algo_2D.SetMinSize( 7. )
# 2) Compute 2D mesh
isDone = Mesh_1.Compute()
if not isDone:
# 3) Split quadrangles into triangles
Mesh_1.SplitQuadObject( Mesh_1, Diag13=True )
# 4) Define a 3D mesher
Mesh_1.Tetrahedron()
# 5) Compute 3D mesh
if not isDone:
if salome.sg.hasDesktop():
salome.sg.updateObjBrowser()
Editing a mesh (i.e. changing hypotheses)
# Editing of a mesh
import salome
def PrintMeshInfo(theMesh):
aMesh = theMesh.GetMesh()
print("Information about mesh:")
print("Number of nodes : ", aMesh.NbNodes())
print("Number of edges : ", aMesh.NbEdges())
print("Number of faces : ", aMesh.NbFaces())
print("Number of volumes : ", aMesh.NbVolumes())
pass
# create a box
box = geom_builder.MakeBox(0., 0., 0., 20., 20., 20.)
subShapeList = geom_builder.SubShapeAll(box, geom_builder.ShapeType["EDGE"])
edge = subShapeList[0]
name = geom_builder.SubShapeName(edge, box)
geom_builder.addToStudyInFather(box, edge, name)
# create a mesh
tria = smesh_builder.Mesh(box, "Mesh 2D")
algo1D = tria.Segment()
hyp1 = algo1D.NumberOfSegments(3)
algo2D = tria.Triangle()
hyp2 = algo2D.MaxElementArea(10.)
# create a sub-mesh
algo_local = tria.Segment(edge)
hyp3 = algo_local.Arithmetic1D(1, 6)
hyp4 = algo_local.Propagation()
# compute the mesh
if not tria.Compute(): raise Exception("Error when computing Mesh")
PrintMeshInfo(tria)
# remove a local hypothesis
tria.RemoveHypothesis(hyp4, edge)
# compute the mesh
PrintMeshInfo(tria)
# change the value of the 2D hypothesis
hyp2.SetMaxElementArea(2.)
# compute the mesh
PrintMeshInfo(tria)
Export of a Mesh
# Export of a Mesh
import os
import tempfile
import MEDLoader
import salome
# create a box
# create a mesh
tetra.Segment().NumberOfSegments(7)
tetra.Triangle()
tetra.Tetrahedron()
# compute the mesh
if not tetra.Compute(): raise Exception("Error when computing Mesh")
# export the mesh in a MED file
medFile = tempfile.NamedTemporaryFile(suffix=".med").name
tetra.ExportMED( medFile, 0 )
# export a group in a MED file
face = geom_builder.SubShapeAll( box, geom_builder.ShapeType["FACE"])[0] # a box side
group = tetra.GroupOnGeom( face, "face group" ) # group of 2D elements on the <face>
tetra.ExportMED( medFile, meshPart=group )
# autoDimension parameter
face = geom_builder.MakeFaceHW( 10, 10, 1, "rectangle" )
mesh2D = smesh_builder.Mesh( face, "mesh2D" )
mesh2D.AutomaticHexahedralization(0)
# exported mesh is in 2D space because it is a planar mesh lying
# on XOY plane, and autoDimension=True by default
mesh2D.ExportMED( medFile )
medMesh = MEDLoader.ReadUMeshFromFile(medFile,mesh2D.GetName(),0)
print("autoDimension==True, exported mesh is in %sD"%medMesh.getSpaceDimension())
# exported mesh is in 3D space, same as in Mesh module,
# thanks to autoDimension=False
mesh2D.ExportMED( medFile, autoDimension=False )
print("autoDimension==False, exported mesh is in %sD"%medMesh.getSpaceDimension())
os.remove( medFile )
How to mesh a cylinder with hexahedrons?
The next script creates a hexahedral mesh on a cylinder. A picture below the script demonstrates the resulting mesh.
# Creating a hexahedral mesh on a cylinder.
# This example uses Partition to divide the cylinder into blocks, which is
# a general approach. But for the case of cylinder there is a dedicated
# command creating a blocked cylinder: geom_builder.MakeDividedCylinder()
import math
import salome
import GEOM
# Parameters
radius = 50
height = 200
# Build a cylinder
base = geom_builder.MakeVertex(0, 0, 0)
direction = geom_builder.MakeVectorDXDYDZ(0, 0, 1)
cylinder = geom_builder.MakeCylinder(base, direction, radius, height)
geom_builder.addToStudy(cylinder, "cylinder")
# Build blocks
size = radius/2.0
box_rot = geom_builder.MakeBox(-size, -size, 0, +size, +size, height)
box_axis = geom_builder.MakeLine(base, direction)
box = geom_builder.MakeRotation(box_rot, box_axis, math.pi/4)
hole = geom_builder.MakeCut(cylinder, box)
plane_trim = 2000
plane_a = geom_builder.MakePlane(base, geom_builder.MakeVectorDXDYDZ(1, 0, 0), plane_trim)
plane_b = geom_builder.MakePlane(base, geom_builder.MakeVectorDXDYDZ(0, 1, 0), plane_trim)
blocks_part = geom_builder.MakePartition([hole], [plane_a, plane_b], [], [], geom_builder.ShapeType["SOLID"])
blocks_list = [box] + geom_builder.SubShapeAll(blocks_part, geom_builder.ShapeType["SOLID"])
blocks_all = geom_builder.MakeCompound(blocks_list)
blocks = geom_builder.MakeGlueFaces(blocks_all, 0.0001)
geom_builder.addToStudy(blocks, "cylinder:blocks")
# Build geometric groups
group_a = geom_builder.CreateGroup(blocks, geom_builder.ShapeType["FACE"])
geom_builder.addToStudyInFather(blocks, group_a, "baseA")
items = geom_builder.GetShapesOnPlaneWithLocationIDs(blocks, geom_builder.ShapeType["FACE"], direction, base, GEOM.ST_ON)
geom_builder.UnionIDs(group_a, items)
base_b = geom_builder.MakeVertex(0, 0, height)
group_b = geom_builder.CreateGroup(blocks, geom_builder.ShapeType["FACE"])
geom_builder.addToStudyInFather(blocks, group_b, "baseB")
items = geom_builder.GetShapesOnPlaneWithLocationIDs(blocks, geom_builder.ShapeType["FACE"], direction, base_b, GEOM.ST_ON)
geom_builder.UnionIDs(group_b, items)
group_1 = geom_builder.CreateGroup(blocks, geom_builder.ShapeType["SOLID"])
geom_builder.addToStudyInFather(blocks, group_1, "limit")
group_1_all = geom_builder.SubShapeAllIDs(blocks, geom_builder.ShapeType["SOLID"])
geom_builder.UnionIDs(group_1, group_1_all)
group_1_box = geom_builder.GetBlockNearPoint(blocks, base)
geom_builder.DifferenceList(group_1, [group_1_box])
# Mesh the blocks with hexahedral
smesh_builder.UpdateStudy()
hexa = smesh_builder.Mesh(blocks)
hexa_1d = hexa.Segment()
hexa_1d.NumberOfSegments(1)
vertex = geom_builder.MakeVertex(+radius, +radius, 0)
edge = geom_builder.GetEdgeNearPoint(blocks, vertex)
algo = hexa.Segment(edge)
algo.NumberOfSegments(5)
algo.Propagation()
vertex = geom_builder.MakeVertex(-radius, +radius, 0)
algo.NumberOfSegments(8)
algo.Propagation()
vertex = geom_builder.MakeVertex((radius+size)/2, 0, 0)
algo.NumberOfSegments(10)
algo.Propagation()
vertex = geom_builder.MakeVertex(+radius, 0, height/2)
algo.NumberOfSegments(20)
algo.Propagation()
hexa.Quadrangle()
hexa.Hexahedron()
if not hexa.Compute(): raise Exception("Error when computing Mesh")
hexa.Group(group_a)
hexa.Group(group_b)
hexa.Group(group_1)
Building a compound of meshes
# Building a compound of meshes
import salome
## create a bottom box
Box_inf = geom_builder.MakeBox(0., 0., 0., 200., 200., 50.)
# get a top face
Psup1=geom_builder.MakeVertex(100., 100., 50.)
Fsup1=geom_builder.GetFaceNearPoint(Box_inf, Psup1)
# get a bottom face
Pinf1=geom_builder.MakeVertex(100., 100., 0.)
Finf1=geom_builder.GetFaceNearPoint(Box_inf, Pinf1)
## create a top box
Box_sup = geom_builder.MakeBox(100., 100., 50., 200., 200., 100.)
# get a top face
Psup2=geom_builder.MakeVertex(150., 150., 100.)
Fsup2=geom_builder.GetFaceNearPoint(Box_sup, Psup2)
# get a bottom face
Pinf2=geom_builder.MakeVertex(150., 150., 50.)
Finf2=geom_builder.GetFaceNearPoint(Box_sup, Pinf2)
## Publish in the study
geom_builder.addToStudy(Box_inf, "Box_inf")
geom_builder.addToStudyInFather(Box_inf, Fsup1, "Fsup")
geom_builder.addToStudyInFather(Box_inf, Finf1, "Finf")
geom_builder.addToStudy(Box_sup, "Box_sup")
geom_builder.addToStudyInFather(Box_sup, Fsup2, "Fsup")
geom_builder.addToStudyInFather(Box_sup, Finf2, "Finf")
## create a bottom mesh
Mesh_inf = smesh_builder.Mesh(Box_inf, "Mesh_inf")
algo1D_1=Mesh_inf.Segment()
algo1D_1.NumberOfSegments(10)
algo2D_1=Mesh_inf.Quadrangle()
algo3D_1=Mesh_inf.Hexahedron()
if not Mesh_inf.Compute(): raise Exception("Error when computing Mesh")
# create a group on the top face
Gsup1=Mesh_inf.Group(Fsup1, "Sup")
# create a group on the bottom face
Ginf1=Mesh_inf.Group(Finf1, "Inf")
## create a top mesh
Mesh_sup = smesh_builder.Mesh(Box_sup, "Mesh_sup")
algo1D_2=Mesh_sup.Segment()
algo1D_2.NumberOfSegments(5)
algo2D_2=Mesh_sup.Quadrangle()
algo3D_2=Mesh_sup.Hexahedron()
if not Mesh_sup.Compute(): raise Exception("Error when computing Mesh")
Gsup2=Mesh_sup.Group(Fsup2, "Sup")
Ginf2=Mesh_sup.Group(Finf2, "Inf")
## create compounds
# create a compound of two meshes with renaming namesake groups and
# merging elements with the given tolerance
Compound1 = smesh_builder.Concatenate([Mesh_inf, Mesh_sup], 0, 1, 1e-05,
name='Compound with RenamedGrps and MergeElems')
# create a compound of two meshes with uniting namesake groups and
# creating groups of all elements
Compound2 = smesh_builder.Concatenate([Mesh_inf, Mesh_sup], 1, 0, 1e-05, True,
name='Compound with UniteGrps and GrpsOfAllElems')
# copy Gsup1 into a separate mesh and translate it
groupMesh = Mesh_inf.TranslateObjectMakeMesh( Gsup1, [300,0,0] )
# add Ginf2 to groupMesh
smesh_builder.Concatenate([Ginf2], False, meshToAppendTo = groupMesh )
Mesh Copying
# Mesh Copying
import salome
import SMESH
# make geometry of a box
box = geom_builder.MakeBoxDXDYDZ(100,100,100)
face = geom_builder.SubShapeAllSorted(box, geom_builder.ShapeType["FACE"])[0]
# generate a prismatic 3D mesh
mesh = smesh_builder.Mesh(box, "box")
localAlgo = mesh.Triangle(face)
mesh.Segment().NumberOfSegments( 3 )
mesh.Quadrangle()
mesh.Prism()
# objects to copy
fGroup = mesh.GroupOnGeom( face, "2D on face")
nGroup = mesh.GroupOnGeom( face, "nodes on face", SMESH.NODE)
subMesh = localAlgo.GetSubMesh()
# make a new mesh by copying different parts of the mesh
# 1. copy the whole mesh
newMesh = smesh_builder.CopyMesh( mesh, "whole mesh copy")
# 2. copy a group of 2D elements along with groups
newMesh = smesh_builder.CopyMesh( fGroup, "face group copy with groups",toCopyGroups=True)
# 3. copy a group of nodes
newMesh = smesh_builder.CopyMesh( nGroup, "node group copy")
# 4. copy some faces
faceIds = fGroup.GetIDs()[-10:]
newMesh = smesh_builder.CopyMesh( mesh.GetIDSource( faceIds, SMESH.FACE ), "some faces copy")
# 5. copy some nodes
nodeIds = nGroup.GetIDs()[-10:]
newMesh = smesh_builder.CopyMesh( mesh.GetIDSource( nodeIds, SMESH.NODE), "some nodes copy")
# 6. copy a sub-mesh
newMesh = smesh_builder.CopyMesh( subMesh, "sub-mesh copy" )
# make a new mesh with same hypotheses on a modified geometry
smallBox = geom_builder.MakeScaleAlongAxes( box, None, 1, 0.5, 0.5 )
cutBox = geom_builder.MakeCut( box, smallBox, theName="box - smallBox" )
ok, newMesh, groups, submehses, hyps, invIDs = smesh_builder.CopyMeshWithGeom( mesh, cutBox, "cutBox" )
if not newMesh.Compute(): raise Exception("Error when computing Mesh")
Creating Dual Mesh
# Creating dual Mesh
import sys
import salome
salome.salome_init()
import salome_notebook
notebook = salome_notebook.NoteBook()
sys.path.insert(0, r'/home/B61570/work_in_progress/dual_mesh')
### GEOM component
import GEOM
import math
import SALOMEDS
# Creating a sphere
O = geompy.MakeVertex(0, 0, 0)
OX = geompy.MakeVectorDXDYDZ(1, 0, 0)
OY = geompy.MakeVectorDXDYDZ(0, 1, 0)
OZ = geompy.MakeVectorDXDYDZ(0, 0, 1)
Sphere_1 = geompy.MakeSphereR(100)
[geomObj_1] = geompy.ExtractShapes(Sphere_1, geompy.ShapeType["FACE"], True)
geompy.addToStudy( O, 'O' )
geompy.addToStudy( OX, 'OX' )
geompy.addToStudy( OY, 'OY' )
geompy.addToStudy( OZ, 'OZ' )
geompy.addToStudy( Sphere_1, 'Sphere_1' )
import SMESH, SALOMEDS
# Meshing sphere in Tetrahedron
NETGEN_3D_Parameters_1 = smesh.CreateHypothesisByAverageLength( 'NETGEN_Parameters', 'NETGENEngine', 34.641, 0 )
Mesh_1 = smesh.Mesh(Sphere_1,'Mesh_1')
status = Mesh_1.AddHypothesis( Sphere_1, NETGEN_3D_Parameters_1 )
NETGEN_1D_2D_3D = Mesh_1.Tetrahedron(algo=smeshBuilder.NETGEN_1D2D3D)
if not isDone:
# Creating Dual mesh with projection on shape
dual_Mesh_1 = smesh.CreateDualMesh( Mesh_1, 'dual_Mesh_1', True)
assert(dual_Mesh_1.NbPolyhedrons() > 0)
assert(dual_Mesh_1.NbTetras() == 0)
# Creating Dual mesh without projection on shape
dual_Mesh_2 = smesh.CreateDualMesh( Mesh_1, 'dual_Mesh_2', False)
assert(dual_Mesh_2.NbPolyhedrons() > 0)
assert(dual_Mesh_2.NbTetras() == 0)
Creating Parallel Mesh
# contains function to compute a mesh in parallel
import salome
### GEOM component
import GEOM
import SALOMEDS
import numpy as np
nbox = 2
boxsize = 100
offset = 0
# Create 3D faces
boxes = []
# First creating all the boxes
for i in range(nbox):
for j in range(nbox):
for k in range(nbox):
x_orig = i*(boxsize+offset)
y_orig = j*(boxsize+offset)
z_orig = k*(boxsize+offset)
tmp_box = geompy.MakeBoxDXDYDZ(boxsize, boxsize, boxsize)
if not i == j == k == 0:
box = geompy.MakeTranslation(tmp_box, x_orig,
y_orig, z_orig)
else:
box = tmp_box
geompy.addToStudy(box, 'box_{}:{}:{}'.format(i, j, k))
boxes.append(box)
# Create fuse of all boxes
all_boxes = geompy.MakeCompound(boxes)
geompy.addToStudy(all_boxes, 'Compound_1')
# Removing duplicates faces and edges
all_boxes = geompy.MakeGlueFaces(all_boxes, 1e-07)
geompy.addToStudy(all_boxes, 'Glued_Faces_1')
rubik_cube = geompy.MakeGlueEdges(all_boxes, 1e-07)
geompy.addToStudy(rubik_cube, 'rubik_cube')
print("Creating Parallel Mesh")
par_mesh = smesh.ParallelMesh(rubik_cube, name="par_mesh")
print("Creating hypoehtesis for netgen")
print("Adding hypothesis")
par_mesh.AddGlobalHypothesis(NETGEN_3D_Parameters_1)
print("Setting parallelism method")
par_mesh.SetParallelismMethod(smeshBuilder.MULTITHREAD)
print("Setting parallelism options")
param = par_mesh.GetParallelismSettings()
param.SetNbThreads(6)
print("Starting parallel compute")
is_done = par_mesh.Compute()
if not is_done:
print(" Tetrahedron: ", par_mesh.NbTetras())
print(" Triangle: ", par_mesh.NbTriangles())
print(" edge: ", par_mesh.NbEdges())
assert par_mesh.NbTetras() > 0
assert par_mesh.NbTriangles() > 0
assert par_mesh.NbEdges() > 0
