Defining Hypotheses and Algorithms
This page provides example codes of defining algorithms and hypotheses.
Wire discretisation 1D algorithm
Adaptive hypothesis
Arithmetic Progression hypothesis
Geometric Progression hypothesis
Deflection and Number of Segments hypotheses
Start and End Length hypothesis
Local Length hypothesis
Propagation additional hypotheses
Fixed Points 1D hypothesis
Triangle: NETGEN 2D algorithm
Maximum Element Area hypothesis
Length from Edges hypothesis
Quadrangle: Mapping 2D algorithm
Quadrangle Parameters hypothesis
Radial Quadrangle 1D-2D algorithm
NETGEN 3D algorithm
Maximum Element Volume hypothesis
Viscous layers hypotheses
Hexahedron (i,j,k) 3D algorithm
Extrusion 3D algorithm
Radial Prism algorithm
Body Fitting algorithm
Import 1D-2D Elements from Another Mesh algorithm
Use Faces to be Created Manually algorithm
Segments around Vertex algorithm
Defining 1D Hypotheses
Arithmetic Progression and Geometric Progression
# Arithmetic Progression and Geometric Progression
import salome
salome.salome_init_without_session()
from salome.smesh import smeshBuilder
geom_builder = geomBuilder.New()
smesh_builder = smeshBuilder.New()
# create a box
box = geom_builder.MakeBoxDXDYDZ(10., 10., 10.)
geom_builder.addToStudy(box, "Box")
# create a hexahedral mesh on the box
hexa = smesh_builder.Mesh(box, "Box : hexahedrical mesh")
# create a Regular 1D algorithm for edges
algo1D = hexa.Segment()
# optionally reverse node distribution on certain edges
allEdges = geom_builder.SubShapeAllSorted( box, geom_builder.ShapeType["EDGE"])
reversedEdges = [ allEdges[0], allEdges[4] ]
# define "Arithmetic1D" hypothesis to cut all edges in several segments with increasing arithmetic length
algo1D.Arithmetic1D(1, 4, reversedEdges)
# define "Geometric Progression" hypothesis on one edge to cut this edge in segments with length increasing by 20% starting from 1
gpAlgo = hexa.Segment( allEdges[1] )
gpAlgo.GeometricProgression( 1, 1.2 )
# propagate distribution of nodes computed using "Geometric Progression" to parallel edges
gpAlgo.PropagationOfDistribution()
# create a quadrangle 2D algorithm for faces
hexa.Quadrangle()
# create a hexahedron 3D algorithm for solids
hexa.Hexahedron()
# compute the mesh
if not hexa.Compute(): raise Exception("Error when computing Mesh")
Adaptive
# Usage of Adaptive 1D hypothesis
import math
import salome
box = geom_builder.MakeBoxDXDYDZ( 100, 100, 100 )
tool = geom_builder.MakeTranslation( box, 50, 0, 10 )
axis = geom_builder.MakeVector( geom_builder.MakeVertex( 100, 0, 100 ),geom_builder.MakeVertex( 100, 10, 100 ),)
tool = geom_builder.Rotate( tool, axis, math.pi * 25 / 180. )
shape = geom_builder.MakeCut( box, tool )
cyl = geom_builder.MakeCylinder( geom_builder.MakeVertex( -10,5, 95 ), geom_builder.MakeVectorDXDYDZ(1,0,0), 2, 90)
shape = geom_builder.MakeCut( shape, cyl )
tool = geom_builder.MakeBoxTwoPnt( geom_builder.MakeVertex( -10, 2, 15 ), geom_builder.MakeVertex( 90, 5, 16 ))
shape = geom_builder.MakeCut( shape, tool, theName="shape" )
# Parameters of Adaptive hypothesis. minSize and maxSize are such that they do not limit
# size of segments because size of geometrical features lies within [2.-100.] range, hence
# size of segments is defined by deflection parameter and size of geometrical features only.
minSize = 0.1
maxSize = 200
deflection = 0.05
mesh = smesh_builder.Mesh( shape )
mesh.Segment().Adaptive( minSize, maxSize, deflection )
mesh.Triangle().MaxElementArea( 300 )
if not mesh.Compute(): raise Exception("Error when computing Mesh")
# Deflection and Number of Segments
import salome
# create a face from arc and straight segment
px = geom_builder.MakeVertex(100., 0. , 0. )
py = geom_builder.MakeVertex(0. , 100., 0. )
pz = geom_builder.MakeVertex(0. , 0. , 100.)
exy = geom_builder.MakeEdge(px, py)
arc = geom_builder.MakeArc(py, pz, px)
wire = geom_builder.MakeWire([exy, arc])
isPlanarFace = 1
face1 = geom_builder.MakeFace(wire, isPlanarFace)
geom_builder.addToStudy(face1,"Face1")
# get edges from the face
e_straight,e_arc = geom_builder.SubShapeAll(face1, geom_builder.ShapeType["EDGE"])
geom_builder.addToStudyInFather(face1, e_arc, "Arc Edge")
# create hexahedral mesh
hexa = smesh_builder.Mesh(face1, "Face : triangle mesh")
# define "NumberOfSegments" hypothesis to cut a straight edge in a fixed number of segments
algo1D.NumberOfSegments(6)
# define "MaxElementArea" hypothesis
algo2D = hexa.Triangle()
algo2D.MaxElementArea(70.0)
# define a local "Deflection1D" hypothesis on the arc
algo_local = hexa.Segment(e_arc)
algo_local.Deflection1D(1.0)
# compute the mesh
# Start and End Length
import salome
# create a box
# get one edge of the box to put local hypothesis on
p5 = geom_builder.MakeVertex(5., 0., 0.)
EdgeX = geom_builder.GetEdgeNearPoint(box, p5)
geom_builder.addToStudyInFather(box, EdgeX, "Edge [0,0,0 - 10,0,0]")
# set algorithms
hexa.Quadrangle()
hexa.Hexahedron()
# define "NumberOfSegments" hypothesis to cut an edge in a fixed number of segments
algo1D.NumberOfSegments(4)
# create a local hypothesis
algo_local = hexa.Segment(EdgeX)
# define "StartEndLength" hypothesis to cut an edge in several segments with increasing geometric length
algo_local.StartEndLength(1, 6)
# define "Propagation" hypothesis that propagates all other hypothesis
# on all edges on the opposite side in case of quadrangular faces
algo_local.Propagation()
# compute the mesh
Local Length
# Local Length
import salome
# create a box
# set algorithms
hexa.Quadrangle()
hexa.Hexahedron()
# define "NumberOfSegments" hypothesis to cut all edges in a fixed number of segments
# create a sub-mesh
# define "LocalLength" hypothesis to cut an edge in several segments with the same length
algo_local.LocalLength(2.)
# compute the mesh
Defining 2D and 3D hypotheses
# Maximum Element Area
import salome
# create a face
vxy = geom_builder.MakeVector(px, py)
wire = geom_builder.MakeWire([vxy, arc])
isPlanarFace = 1
face = geom_builder.MakeFace(wire, isPlanarFace)
# add the face in the study
id_face = geom_builder.addToStudy(face, "Face to be meshed")
# create a mesh
tria_mesh = smesh_builder.Mesh(face, "Face : triangulation")
# define 1D meshing:
algo = tria_mesh.Segment()
algo.NumberOfSegments(20)
# define 2D meshing:
# assign triangulation algorithm
algo = tria_mesh.Triangle()
# assign "Max Element Area" hypothesis
algo.MaxElementArea(100)
# compute the mesh
if not tria_mesh.Compute(): raise Exception("Error when computing Mesh")
# Maximum Element Volume
import salome
# create a cylinder
cyl = geom_builder.MakeCylinderRH(30., 50.)
geom_builder.addToStudy(cyl, "cyl")
# create a mesh on the cylinder
tetra = smesh_builder.Mesh(cyl, "Cylinder : tetrahedrical mesh")
# assign algorithms
algo1D = tetra.Segment()
algo2D = tetra.Triangle()
algo3D = tetra.Tetrahedron()
# assign 1D and 2D hypotheses
algo1D.NumberOfSegments(7)
algo2D.MaxElementArea(150.)
# assign Max Element Volume hypothesis
algo3D.MaxElementVolume(200.)
# compute the mesh
ret = tetra.Compute()
if ret == 0:
raise Exception("problem when computing the mesh")
print("Computation succeeded")
Length from Edges
# Length from Edges
import salome
# create sketchers
sketcher1 = geom_builder.MakeSketcher("Sketcher:F 0 0:TT 70 0:TT 70 70:TT 0 70:WW")
sketcher2 = geom_builder.MakeSketcher("Sketcher:F 20 20:TT 50 20:TT 50 50:TT 20 50:WW")
# create a face from two wires
isPlanarFace = 1
face1 = geom_builder.MakeFaces([sketcher1, sketcher2], isPlanarFace)
geom_builder.addToStudy(face1, "Face1")
# create a mesh
tria = smesh_builder.Mesh(face1, "Face : triangle 2D mesh")
# Define 1D meshing
algo1D = tria.Segment()
algo1D.LocalLength(3.)
# create and assign the algorithm for 2D meshing with triangles
algo2D = tria.Triangle()
# create and assign "LengthFromEdges" hypothesis to build triangles with
# linear size close to the length of the segments generated on the face wires (3.)
algo2D.LengthFromEdges()
# compute the mesh
if not tria.Compute(): raise Exception("Error when computing Mesh")
Renumber 3D hypothesis
# "Elements of a domain" filter and "Renumber" hypothesis
import salome
import SMESH
# create two boxes to have two domains in the mesh
box1 = geom_builder.MakeBoxDXDYDZ( 100,100,100 )
box2 = geom_builder.MakeTranslation( box1, 200, 0, 0 )
boxes = geom_builder.MakeCompound( [box1, box2] )
box1, box2 = geom_builder.SubShapeAll( boxes, geom_builder.ShapeType["SHAPE"], "box")
vertex = geom_builder.SubShape( box1, geom_builder.ShapeType["VERTEX"], [1] )
# create a mesh
mesh = smesh_builder.Mesh( boxes )
mesh.Segment(box1).NumberOfSegments( 5 ) # to have different nb of elements on the boxes
mesh.Segment(box2).NumberOfSegments( 10 )
mesh.Quadrangle()
ijkAlgo = mesh.Hexahedron()
# Use Renumber hypothesis to get hexahedra and nodes numbered like in a structured mesh.
# k axis of box1 will be ( 100,100,0 ) - ( 100,100,100 )
# k axis of box2 will be ( 0,0,0 ) - (0,0,100), by default
v000 = geom_builder.MakeVertex( 100,100,0, theName='v000' ) # can use box sub-vertex or standalone one
v001 = geom_builder.GetVertexNearPoint( box1, geom_builder.MakeVertex(100,100,100), theName='v001')
ijkAlgo.Renumber([ smeshBuilder.BlockCS( box1, v000, v001 ) ])
# Create filters with FT_ConnectedElements criterion by pointing a domain in different ways:
# using point coordinates in box_1
nodeFilter = smesh_builder.GetFilter( SMESH.NODE, SMESH.FT_ConnectedElements, "=", "1.,2,10", mesh=mesh )
print("Nb. nodes in box_1:", len( nodeFilter.GetIDs()))
# using point coordinates in box_2
edgeFilter = smesh_builder.GetFilter( SMESH.EDGE, SMESH.FT_ConnectedElements, "=", [202,1,1 ], mesh=mesh )
print("Nb. segments in box_2:", len( edgeFilter.GetIDs()))
# using a geom vertex of box_1
faceFilter = smesh_builder.GetFilter( SMESH.FACE, SMESH.FT_ConnectedElements, "=", vertex, mesh=mesh )
print("Nb. faces in box_1:", len( edgeFilter.GetIDs()))
# using node ID in box_2
voluFilter = smesh_builder.GetFilter( SMESH.VOLUME, SMESH.FT_ConnectedElements, "=", 10, mesh=mesh )
print("Nb. volumes in box_2:", len( voluFilter.GetIDs()))
Defining Additional Hypotheses
Propagation
# Propagation
import salome
# create a box
base = geom_builder.MakeSketcher("Sketcher:F 0 0:TT 10 0:TT 20 10:TT 0 10:WF", theName="F")
box = geom_builder.MakePrismDXDYDZ( base, 0,0,10 )
hexa = smesh_builder.Mesh(box, "Propagation of hypothesis")
# set global algorithms and hypotheses
hexa.Quadrangle()
hexa.Hexahedron()
# create a sub-mesh with local 1D hypothesis and "Propagation of 1D Hypothesis"
# define "Arithmetic1D" hypothesis to cut an edge in several segments with increasing length
algo_local.Arithmetic1D(1, 4)
# define "Propagation" hypothesis that propagates "Arithmetic1D" hypothesis
# from 'EdgeX' on opposite sides of all quadilateral faces
# compute the mesh which contains prisms
# create another mesh on the box
mesh = smesh_builder.Mesh(box, "Propagation of distribution of nodes")
algo1D = mesh.Segment()
mesh.Quadrangle()
mesh.Hexahedron()
# create a sub-mesh with local 1D hypothesis and "Propagation of Node Distribution"
algo_local = mesh.Segment(EdgeX)
# define "Propagation Of Distribution" hypothesis that propagates
# distribution of nodes generated by "Arithmetic1D" hypothesis
algo_local.PropagationOfDistribution()
# compute the mesh which contains hexahedra only
Defining Meshing Algorithms
# Defining Meshing Algorithms
import salome
# create a box
# Create a hexahedral mesh on the box
algo2D = hexa.Quadrangle()
algo3D = hexa.Hexahedron()
# define hypotheses
algo1D.Arithmetic1D(1, 4)
# compute the mesh
# 2. Create a tetrahedral mesh on the box
tetra = smesh_builder.Mesh(box, "Box : tetrahedrical mesh")
# create a 1D algorithm for edges
# create a 2D algorithm for faces
# create a 3D algorithm for solids
# define hypotheses
# compute the mesh
if not tetra.Compute(): raise Exception("Error when computing Mesh")
Projection Algorithms
# Projection Algorithms
# Project prisms from one meshed box to another mesh on the same box
import salome
# Prepare geometry
# Create a parallelepiped
box = geom_builder.MakeBoxDXDYDZ(200, 100, 70)
geom_builder.addToStudy( box, "box" )
# Get geom faces to mesh with triangles in the 1ts and 2nd meshes
faces = geom_builder.SubShapeAll(box, geom_builder.ShapeType["FACE"])
# 2 adjacent faces of the box
f1 = faces[2]
f2 = faces[0]
# face opposite to f2
f2opp = geom_builder.GetOppositeFace( box, f2 )
# Get vertices used to specify how to associate sides of faces at projection
[v1F1, v2F1] = geom_builder.SubShapeAll(f1, geom_builder.ShapeType["VERTEX"])[:2]
[v1F2, v2F2] = geom_builder.SubShapeAll(f2, geom_builder.ShapeType["VERTEX"])[:2]
geom_builder.addToStudyInFather( box, v1F1, "v1F1" )
geom_builder.addToStudyInFather( box, v2F1, "v2F1" )
geom_builder.addToStudyInFather( box, v1F2, "v1F2" )
geom_builder.addToStudyInFather( box, v2F2, "v2F2" )
# Make group of 3 edges of f1 and f2
edgesF1 = geom_builder.CreateGroup(f1, geom_builder.ShapeType["EDGE"])
geom_builder.UnionList( edgesF1, geom_builder.SubShapeAll(f1, geom_builder.ShapeType["EDGE"])[:3])
edgesF2 = geom_builder.CreateGroup(f2, geom_builder.ShapeType["EDGE"])
geom_builder.UnionList( edgesF2, geom_builder.SubShapeAll(f2, geom_builder.ShapeType["EDGE"])[:3])
geom_builder.addToStudyInFather( box, edgesF1, "edgesF1" )
geom_builder.addToStudyInFather( box, edgesF2, "edgesF2" )
# Make the source mesh with prisms
src_mesh = smesh_builder.Mesh(box, "Source mesh")
src_mesh.Segment().NumberOfSegments(9,10)
src_mesh.Quadrangle()
src_mesh.Hexahedron()
src_mesh.Triangle(f1) # triangular sub-mesh
if not src_mesh.Compute(): raise Exception("Error when computing Mesh")
# Mesh the box using projection algorithms
# Define the same global 1D and 2D hypotheses
tgt_mesh = smesh_builder.Mesh(box, "Target mesh")
tgt_mesh.Segment().NumberOfSegments(9,10,UseExisting=True)
tgt_mesh.Quadrangle()
# Define Projection 1D algorithm to project 1d mesh elements from group edgesF2 to edgesF1
# It is actually not needed, just a demonstration
proj1D = tgt_mesh.Projection1D( edgesF1 )
# each vertex must be at the end of a connected group of edges (or a sole edge)
proj1D.SourceEdge( edgesF2, src_mesh, v2F1, v2F2 )
# Define 2D hypotheses to project triangles from f1 face of the source mesh to
# f2 face in the target mesh. Vertices specify how to associate sides of faces
proj2D = tgt_mesh.Projection2D( f2 )
proj2D.SourceFace( f1, src_mesh, v1F1, v1F2, v2F1, v2F2 )
# 2D hypotheses to project triangles from f2 of target mesh to the face opposite to f2.
# Association of face sides is default
proj2D = tgt_mesh.Projection2D( f2opp )
proj2D.SourceFace( f2 )
# 3D hypotheses to project prisms from the source to the target mesh
proj3D = tgt_mesh.Projection3D()
proj3D.SourceShape3D( box, src_mesh, v1F1, v1F2, v2F1, v2F2 )
if not tgt_mesh.Compute(): raise Exception("Error when computing Mesh")
# Move the source mesh to visually compare the two meshes
src_mesh.TranslateObject( src_mesh, smesh_builder.MakeDirStruct( 210, 0, 0 ), Copy=False)
Projection 1D2D
# Projection 1D2D
# Project triangles from one meshed face to another mesh on the same box
import salome
# Prepare geometry
# Create a box
box = geom_builder.MakeBoxDXDYDZ(100, 100, 100)
Face_1 = faces[2]
Face_2 = faces[0]
geom_builder.addToStudy( box, 'box' )
geom_builder.addToStudyInFather( box, Face_1, 'Face_1' )
geom_builder.addToStudyInFather( box, Face_2, 'Face_2' )
# Make the source mesh triangulated by default algorithm
src_mesh = smesh_builder.Mesh(Face_1, "Source mesh")
src_mesh.Segment().NumberOfSegments(15)
src_mesh.Triangle()
# Mesh the target mesh using the algorithm Projection1D2D
tgt_mesh = smesh_builder.Mesh(Face_2, "Target mesh")
tgt_mesh.Projection1D2D().SourceFace(Face_1,src_mesh)
1D Mesh with Fixed Points example
# 1D Mesh with Fixed Points example
import salome
# Create face and explode it on edges
face = geom_builder.MakeFaceHW(100, 100, 1)
edges = geom_builder.SubShapeAllSorted(face, geom_builder.ShapeType["EDGE"])
geom_builder.addToStudy( face, "Face" )
# get the first edge from exploded result
edge1 = geom_builder.GetSubShapeID(face, edges[0])
# Define Mesh on previously created face
Mesh_1 = smesh_builder.Mesh(face)
# Create Fixed Point 1D hypothesis and define parameters.
# Note: values greater than 1.0 and less than 0.0 are not taken into account;
# duplicated values are removed. Also, if not specified explicitly, values 0.0 and 1.0
# add added automatically.
# The number of segments should correspond to the number of points (NbSeg = NbPnt-1);
# extra values of segments splitting parameter are not taken into account,
# while missing values are considered to be equal to 1.
Fixed_points_1D_1 = smesh_builder.CreateHypothesis('FixedPoints1D')
Fixed_points_1D_1.SetPoints( [ 1.1, 0.9, 0.5, 0.0, 0.5, -0.3 ] )
Fixed_points_1D_1.SetNbSegments( [ 3, 1, 2 ] )
Fixed_points_1D_1.SetReversedEdges( [edge1] )
# Add hypothesis to mesh and define 2D parameters
Mesh_1.AddHypothesis(Fixed_points_1D_1)
Regular_1D = Mesh_1.Segment()
Quadrangle_2D = Mesh_1.Quadrangle()
# Compute mesh
if not Mesh_1.Compute(): raise Exception("Error when computing Mesh")
Radial Quadrangle 1D-2D example
# Radial Quadrangle 1D-2D example
import salome
# Create face from the wire and add to study
Face = geom_builder.MakeSketcher("Sketcher:F 0 0:TT 20 0:R 90:C 20 90:WF", [0, 0, 0, 1, 0, 0, 0, 0, 1])
geom_builder.addToStudy(Face,"Face")
circle, radius1, radius2 = geom_builder.SubShapeAllSorted(Face, geom_builder.ShapeType["EDGE"])
geom_builder.addToStudyInFather(Face, radius1,"radius1")
geom_builder.addToStudyInFather(Face, radius2,"radius2")
geom_builder.addToStudyInFather(Face, circle,"circle")
# Define geometry for mesh, and Radial Quadrange algorithm
mesh = smesh_builder.Mesh(Face)
radial_Quad_algo = mesh.Quadrangle(algo=smeshBuilder.RADIAL_QUAD)
# The Radial Quadrange algorithm can work without any hypothesis
# In this case it uses "Default Nb of Segments" preferences parameter to discretize edges
# So by default there will be 15 segments in both radial and circular directions
# The Radial Quadrange uses global or local 1d hypotheses if it does
# not have its own hypotheses.
# Define global hypotheses to discretize radial edges and a local one for circular edge
# So that there will be 5 radial layers and 10 circular segments
global_Nb_Segments = mesh.Segment().NumberOfSegments(5)
local_Nb_Segments = mesh.Segment(circle).NumberOfSegments(10)
# Define own parameters of Radial Quadrange algorithm
# The number of radial layers will be 4
radial_Quad_algo.NumberOfLayers( 4 )
Quadrangle Parameters example 1 (meshing a face with 3 edges)
# Quadrangle Parameters example 1 (meshing a face with 3 edges)
import salome
# Get 1/4 part from the disk face.
Box_1 = geom_builder.MakeBoxDXDYDZ(100, 100, 100)
Disk_1 = geom_builder.MakeDiskR(100, 1)
Common_1 = geom_builder.MakeCommon(Disk_1, Box_1)
triaVertex = geom_builder.GetVertexNearPoint( Common_1, geom_builder.MakeVertex(0,0,0) )
geom_builder.addToStudy( Common_1, "Common_1" )
geom_builder.addToStudyInFather( Common_1, triaVertex, "triaVertex" )
# Set the Geometry for meshing
Mesh_1 = smesh_builder.Mesh(Common_1)
# Define 1D hypothesis
Nb_Segments_1 = Regular_1D.NumberOfSegments(10)
# Create Quadrangle parameters and define the Base Vertex.
Quadrangle_2D = Mesh_1.Quadrangle().TriangleVertex( triaVertex )
# Compute the mesh
Quadrangle Parameters example 2 (using different types)
# Quadrangle Parameters example 2 (using different types)
import salome
# Make quadrangle face and explode it on edges.
Vertex_1 = geom_builder.MakeVertex(0, 0, 0)
Vertex_2 = geom_builder.MakeVertex(40, 0, 0)
Vertex_3 = geom_builder.MakeVertex(40, 30, 0)
Vertex_4 = geom_builder.MakeVertex(0, 30, 0)
Quadrangle_Face_1 = geom_builder.MakeQuad4Vertices(Vertex_1, Vertex_4, Vertex_3, Vertex_2)
[Edge_1,Edge_2,Edge_3,Edge_4] = geom_builder.SubShapeAllSorted(Quadrangle_Face_1, geom_builder.ShapeType["EDGE"])
geom_builder.addToStudy( Quadrangle_Face_1, "Quadrangle Face_1" )
geom_builder.addToStudyInFather( Quadrangle_Face_1, Edge_2, "Edge_2" )
Mesh_1 = smesh_builder.Mesh(Quadrangle_Face_1)
# define the Type as Quadrangle Preference
Quad_algo = Mesh_1.Quadrangle()
Quadrangle_Parameters_1 = Quad_algo.QuadrangleParameters( smeshBuilder.QUAD_QUADRANGLE_PREF )
# Define other hypotheses and algorithms
Nb_Segments_1 = Regular_1D.NumberOfSegments(4)
# Define submesh on one edge to provide different number of segments
Regular_1D_1 = Mesh_1.Segment(geom=Edge_2)
Nb_Segments_2 = Regular_1D_1.NumberOfSegments(10)
# Compute mesh (with Quadrangle Preference type)
# Change type to Reduced and compute again
Quadrangle_Parameters_1.SetQuadType( smeshBuilder.QUAD_REDUCED )
“Import 1D-2D Elements from Another Mesh” example
# "Import 2D Elements from Another Mesh" example
import salome
import SMESH
# Make a patritioned box
box = geom_builder.MakeBoxDXDYDZ(100,100,100)
N = geom_builder.MakeVectorDXDYDZ( 1,0,0 )
O = geom_builder.MakeVertex( 50,0,0 )
plane = geom_builder.MakePlane( O, N, 200 ) # plane YOZ
shape2boxes = geom_builder.MakeHalfPartition( box, plane )
boxes = geom_builder.SubShapeAllSorted(shape2boxes, geom_builder.ShapeType["SOLID"])
geom_builder.addToStudy( boxes[0], "boxes[0]")
geom_builder.addToStudy( boxes[1], "boxes[1]")
midFace0 = geom_builder.SubShapeAllSorted(boxes[0], geom_builder.ShapeType["FACE"])[5]
geom_builder.addToStudyInFather( boxes[0], midFace0, "middle Face")
midFace1 = geom_builder.SubShapeAllSorted(boxes[1], geom_builder.ShapeType["FACE"])[0]
geom_builder.addToStudyInFather( boxes[1], midFace1, "middle Face")
# Mesh one of boxes with quadrangles. It is a source mesh
srcMesh = smesh_builder.Mesh(boxes[0], "source mesh") # box coloser to CS origin
nSeg1 = srcMesh.Segment().NumberOfSegments(4)
srcMesh.Quadrangle()
if not srcMesh.Compute(): raise Exception("Error when computing Mesh")
srcFaceGroup = srcMesh.GroupOnGeom( midFace0, "src faces", SMESH.FACE )
# Import faces from midFace0 to the target mesh
tgtMesh = smesh_builder.Mesh(boxes[1], "target mesh")
importAlgo = tgtMesh.UseExisting2DElements(midFace1)
import2hyp = importAlgo.SourceFaces( [srcFaceGroup] )
tgtMesh.Segment().NumberOfSegments(3)
tgtMesh.Quadrangle()
if not tgtMesh.Compute(): raise Exception("Error when computing Mesh")
# Import the whole source mesh with groups
import2hyp.SetCopySourceMesh(True,True)
Viscous layers construction
# Viscous layers construction
import salome
import SMESH
X = geom_builder.MakeVectorDXDYDZ( 1,0,0 )
O = geom_builder.MakeVertex( 100,50,50 )
plane = geom_builder.MakePlane( O, X, 200 ) # plane YZ
box = geom_builder.MakeBoxDXDYDZ(200,100,100)
shape = geom_builder.MakeHalfPartition( box, plane )
faces = geom_builder.SubShapeAllSorted(shape, geom_builder.ShapeType["FACE"])
face1 = faces[1]
ignoreFaces = [ faces[0], faces[-1]]
geom_builder.addToStudy( shape, "shape" )
geom_builder.addToStudyInFather( shape, face1, "face1")
# 3D Viscous layers
mesh = smesh_builder.Mesh(shape, "CFD")
mesh.Segment().NumberOfSegments( 4 )
mesh.Triangle()
mesh.Quadrangle(face1)
algo3D = mesh.Tetrahedron()
thickness = 20
numberOfLayers = 10
stretchFactor = 1.5
groupName = "Boundary layers"
layersHyp = algo3D.ViscousLayers(thickness,numberOfLayers,stretchFactor,
ignoreFaces, # optional
groupName = groupName) # optional
# retrieve boundary prisms created by mesh.Compute()
boundaryGroup = mesh.GetGroupByName( layersHyp.GetGroupName() )[0]
print( "Nb boundary prisms", boundaryGroup.Size() )
mesh.MakeGroup("Tetras",SMESH.VOLUME,SMESH.FT_ElemGeomType,"=",SMESH.Geom_TETRA)
mesh.MakeGroup("Pyras",SMESH.VOLUME,SMESH.FT_ElemGeomType,"=",SMESH.Geom_PYRAMID)
mesh.MakeGroup("Prims",SMESH.VOLUME,SMESH.FT_ElemGeomType,"=",SMESH.Geom_PENTA)
# 2D Viscous layers
# 3 edges of the 4 edges of face1
edgeIds = geom_builder.SubShapeAllIDs( face1, geom_builder.ShapeType["EDGE"])[:-1]
mesh = smesh_builder.Mesh(face1,"VicsousLayers2D")
mesh.Segment().NumberOfSegments( 5 )
# viscous layers will be created on 1 edge, as we set 3 edges to ignore
vlHyp = mesh.Triangle().ViscousLayers2D( 2, 3, 1.5,
edgeIds, isEdgesToIgnore=True, # optional
groupName=groupName) # optional
# retrieve boundary elements created by mesh.Compute()
quadrangles = mesh.GetGroupByName( vlHyp.GetGroupName() )[0]
print( "Nb boundary quadrangles", quadrangles.Size() )
# viscous layers will be created on 3 edges, as we pass isEdgesToIgnore=False
vlHyp.SetEdges( edgeIds, False )
Viscous layers API construction
import salome
import SMESH
face1 = faces[1]
# 4 left, 34 middle, 50 right
# Have to pass the middle face id, otherwise it is going to create two disjoint boxes
# because the common face is not going to be ignored and both boxes are going to shrink
# in this direction too
ignoreFaces = [4,34,50]
# 3D Viscous layers
ViscousBuilder = mesh.ViscousLayerBuilder()
thickness = 20
numberOfLayers = 10
stretchFactor = 1.5
ViscousBuilder.setBuilderParameters( thickness, numberOfLayers, stretchFactor,
groupName = groupName ) # optional
Shrinkshape = ViscousBuilder.GetShrinkGeometry()
shrinkMesh = smesh_builder.Mesh(Shrinkshape, "Shrink")
shrinkMesh.Segment().NumberOfSegments( 4 )
faces = geom_builder.SubShapeAllSorted(Shrinkshape, geom_builder.ShapeType["FACE"])
shrinkFace1 = faces[1]
shrinkMesh.Triangle()
shrinkMesh.Quadrangle(shrinkFace1)
algo3D = shrinkMesh.Tetrahedron()
if not shrinkMesh.Compute(): raise Exception("Error when computing Mesh")
#Add viscous layer
FinalMesh = ViscousBuilder.AddLayers( shrinkMesh )
# 2D Viscous layers
mesh = smesh_builder.Mesh(face1,"Face1")
ViscousBuilder.setBuilderParameters( 2, 3, 1.5,
edgeIds, True, # optional
#For 2D, edges are not selectable (to be developed in occt) the entire face is shrink
shrinkFace = ViscousBuilder.GetShrinkGeometry()
shrinkMesh = smesh_builder.Mesh(shrinkFace, "VicsousLayers2D")
shrinkMesh.Segment().NumberOfSegments( 5 )
algo2D = shrinkMesh.Triangle()
if not shrinkMesh.Compute(): raise Exception("Error when computing Mesh of shrink face")
FinalMeshFace = ViscousBuilder.AddLayers( shrinkMesh )
Radial Prism example
# Usage of Radial Prism 3D meshing algorithm
import salome
# Create geometry: hollow sphere
sphere_1 = geom_builder.MakeSphereR( 100 )
sphere_2 = geom_builder.MakeSphereR( 50 )
hollow_sphere = geom_builder.MakeCut( sphere_1, sphere_2, theName="hollow sphere")
faces = geom_builder.ExtractShapes( hollow_sphere, geom_builder.ShapeType["FACE"] )
# Create mesh
mesh = smesh_builder.Mesh( hollow_sphere, "Mesh of hollow sphere" )
# assign Global Radial Prism algorithm
prism_algo = mesh.Prism()
# define projection between the inner and outer spheres
mesh.Triangle( smeshBuilder.NETGEN_1D2D, faces[0] ) # NETGEN on faces[0]
mesh.Projection1D2D( faces[1] ).SourceFace( faces[0] ) # projection faces[0] -> faces[1]
# define distribution of layers using Number of Segments hypothesis in logarithmic mode
prism_algo.NumberOfSegments( 4, 5. )
# compute the mesh
Usage of Body Fitting algorithm
# Usage of Body Fitting algorithm
import salome
# create a sphere
sphere = geom_builder.MakeSphereR( 50 )
# cut the sphere by a box
partition = geom_builder.MakePartition([ sphere ], [ box ], theName="partition")
# create a mesh and assign a "Body Fitting" algo
mesh = smesh_builder.Mesh( partition )
cartAlgo = mesh.BodyFitted()
# define a cartesian grid using Coordinates
coords = list(range(-100,100,10))
cartHyp = cartAlgo.SetGrid( coords,coords,coords, 1000000)
# compute the mesh
print("nb hexahedra",mesh.NbHexas())
print("nb tetrahedra",mesh.NbTetras())
print("nb polyhedra",mesh.NbPolyhedrons())
print()
# define the grid by setting constant spacing
cartHyp = cartAlgo.SetGrid( "10","10","10", 1000000)
print("nb faces",mesh.NbFaces())
print()
# activate creation of faces
cartHyp.SetToCreateFaces( True )
print()
# enable consideration of shared faces
cartHyp.SetToConsiderInternalFaces( True )
print()
# define the grid by setting different spacing in 2 sub-ranges of geometry
spaceFuns = ["5","10+10*t"]
cartAlgo.SetGrid( [spaceFuns, [0.5]], [spaceFuns, [0.5]], [spaceFuns, [0.25]], 10 )
print()
# Example of customization of dirtections of the grid axes
# make a box with non-orthogonal edges
xDir = geom_builder.MakeVectorDXDYDZ( 1.0, 0.1, 0.0, "xDir" )
yDir = geom_builder.MakeVectorDXDYDZ(-0.1, 1.0, 0.0, "yDir" )
zDir = geom_builder.MakeVectorDXDYDZ( 0.2, 0.3, 1.0, "zDir" )
face = geom_builder.MakePrismVecH( xDir, yDir, 1.0 )
box = geom_builder.MakePrismVecH( face, zDir, 1.0, theName="box" )
spc = "0.1" # spacing
# default axes
mesh = smesh_builder.Mesh( box, "custom axes")
algo = mesh.BodyFitted()
algo.SetGrid( spc, spc, spc, 10000 )
print("Default axes")
print(" nb hex:",mesh.NbHexas())
# set axes using edges of the box
algo.SetAxesDirs( xDir, [-0.1,1,0], zDir )
print("Manual axes")
# set optimal orthogonal axes
algo.SetOptimalAxesDirs( isOrthogonal=True )
print("Optimal orthogonal axes")
# set optimal non-orthogonal axes
algo.SetOptimalAxesDirs( isOrthogonal=False )
print("Optimal non-orthogonal axes")
Usage of “Use Faces to be Created Manually” algorithm
This sample demonstrates how to use Use Faces to be Created Manually algorithm, which is actually just a stub allowing to use your own 2D algorithm implemented in Python.
# Usage of "Use Faces to be Created Manually" algorithm
import salome
# define my 2D algorithm
def my2DMeshing(geomFace, mesh):
import numpy as np
# find gravity center of geomFace
gcXYZ = geom_builder.PointCoordinates( geom_builder.MakeCDG( geomFace ))
# define order and orientation of edges
sortedEdges = []
geomEdges = geom_builder.SubShapeAll( geomFace, geom_builder.ShapeType["EDGE"])
sortedEdges.append(( geomEdges.pop(0), True ))
while geomEdges:
prevEdge_rev = sortedEdges[ -1 ]
prevVV = geom_builder.SubShapeAll( prevEdge_rev[0], geom_builder.ShapeType["VERTEX"])
prevV2 = prevVV[ prevEdge_rev[1] ]
found = False
for iE in range( len( geomEdges )):
v1,v2 = geom_builder.SubShapeAll( geomEdges[ iE ], geom_builder.ShapeType["VERTEX"])
same1,same2 = [( geom_builder.MinDistance( prevV2, v ) < 1e-7 ) for v in [v1,v2] ]
if not same1 and not same2: continue
sortedEdges.append(( geomEdges.pop( iE ), same1 ))
found = True
break
assert found
sortedEdges.reverse()
# put nodes on edges in a right order
nodes = []
for edge, isForward in sortedEdges:
v1,v2 = geom_builder.SubShapeAll( edge, geom_builder.ShapeType["VERTEX"])
edgeNodes = mesh.GetSubMeshNodesId( v2, all=False ) + \
mesh.GetSubMeshNodesId( edge, all=False ) + \
mesh.GetSubMeshNodesId( v1, all=False )
if not isForward: edgeNodes.reverse()
nodes.extend( edgeNodes[:-1] )
# create nodes inside the geomFace
r1 = 0.6
r2 = 1 - r1
nodesInside = []
for n in nodes:
nXYZ = mesh.GetNodeXYZ( n )
newXYZ = np.add( np.multiply( r1, gcXYZ ), np.multiply( r2, nXYZ ))
nodesInside.append( mesh.AddNode( newXYZ[0], newXYZ[1], newXYZ[2] ))
mesh.SetNodeOnFace( nodesInside[-1], geomFace, 0, 0 )
# find out orientation of faces to create
# geomFace normal
faceNorm = geom_builder.GetNormal( geomFace )
v1,v2 = [ geom_builder.PointCoordinates( v ) \
for v in geom_builder.SubShapeAll( faceNorm, geom_builder.ShapeType["VERTEX"]) ]
faceNormXYZ = np.subtract( v2, v1 )
outDirXYZ = np.subtract( v1, [ 50, 50, 50 ] )
if np.dot( faceNormXYZ, outDirXYZ ) < 0: # reversed face
faceNormXYZ = np.multiply( -1., faceNormXYZ )
# mesh face normal
e1 = np.subtract( mesh.GetNodeXYZ( nodes[0] ), mesh.GetNodeXYZ( nodes[1] ))
e2 = np.subtract( mesh.GetNodeXYZ( nodes[0] ), mesh.GetNodeXYZ( nodesInside[0] ))
meshNorm = np.cross( e1, e2 )
# faces orientation
reverse = ( np.dot( faceNormXYZ, meshNorm ) < 0 )
# create mesh faces
iN = len( nodes )
while iN:
n1, n2, n3, n4 = nodes[iN-1], nodes[iN-2], nodesInside[iN-2], nodesInside[iN-1]
iN -= 1
if reverse:
f = mesh.AddFace( [n1, n2, n3, n4] )
else:
f = mesh.AddFace( [n4, n3, n2, n1] )
# new faces must be assigned to geometry to allow 3D algorithm finding them
mesh.SetMeshElementOnShape( f, geomFace )
if reverse:
nodesInside.reverse()
polygon = mesh.AddPolygonalFace( nodesInside )
mesh.SetMeshElementOnShape( polygon, geomFace )
return
# create geometry and get faces to mesh with my2DMeshing()
f1 = geom_builder.SubShapeAll( box, geom_builder.ShapeType["FACE"])[0]
f2 = geom_builder.GetOppositeFace( box, f1 )
geom_builder.addToStudy( f1, "f1" )
geom_builder.addToStudy( f2, "f2" )
# compute 1D mesh
mesh = smesh_builder.Mesh( box )
# compute 2D mesh
mesh.Quadrangle()
mesh.UseExistingFaces(f1) # UseExistingFaces() allows using my2DMeshing();
mesh.UseExistingFaces(f2) # assign UseExistingFaces() BEFORE calling my2DMeshing()!
my2DMeshing(f1, mesh)
my2DMeshing(f2, mesh)
# compute 3D mesh
mesh.Prism()
Resulting mesh:
Usage of Extrusion 3D meshing algorithm
# Usage of Extrusion 3D meshing algorithm
import salome
OX = geom_builder.MakeVectorDXDYDZ(1,0,0)
OY = geom_builder.MakeVectorDXDYDZ(0,1,0)
OZ = geom_builder.MakeVectorDXDYDZ(0,0,1)
# Y ^ Make geometry of a "pipe" with the following base (cross section).
# | Big central quadrangles will be meshed with triangles, walls
# of the pipe will be meshed with quadrilaterals
# +--+--+--+--+--+--+ X
quadBig = geom_builder.MakeFaceHW( 20,20, 1 )
quadBig = geom_builder.MakeTranslation( quadBig, 15,15,0 )
quadSmall = geom_builder.MakeFaceHW( 10,10, 1 )
smallQuads1 = geom_builder.MakeMultiTranslation1D( quadSmall, OX, 10, 3 )
smallQuads2 = geom_builder.MakeMultiTranslation1D( quadSmall, OY, 10, 3 )
smallQuads2 = geom_builder.SubShapeAllSortedCentres( smallQuads2, geom_builder.ShapeType["FACE"])[1:]
base = geom_builder.MakeCompound( smallQuads2 + [smallQuads1, quadBig])
axis = geom_builder.MakeLine( geom_builder.MakeVertex( 25,25,0), OZ )
base = geom_builder.MultiRotate1DNbTimes( base, axis, 4)
base = geom_builder.MakePartition( [base], theName="base")
path = geom_builder.MakeSketcher("Sketcher:F 0 0:TT 0 100:R 0:C -90 180:T 0 -150",[0,0,0, 0,-1,0, 1,0,0])
# Make the pipe, each quadrangle of the base turns into a prism with composite wall faces
pipe = geom_builder.MakePipe( base, path )
prisms = geom_builder.MakePartition( [pipe], theName="prisms")
# get base faces of the prism to define sub-mesh on them
smallQuad = geom_builder.GetFaceNearPoint( prisms, geom_builder.MakeVertex( 0,0,0 ), "smallQuad")
bigQuad = geom_builder.GetFaceNearPoint( prisms, geom_builder.MakeVertex( 15,15,0 ), "bigQuad")
mesh = smesh_builder.Mesh( prisms )
# assign Global hypotheses
# 1D algorithm and hypothesis for division along the pipe
# Extrusion 3D algo
mesh.Prism()
# assign Local hypotheses
# 1D and 2D algos and hyps to mesh smallQuad with quadrilaterals
mesh.Segment(smallQuad).LocalLength( 3 )
mesh.Quadrangle(smallQuad)
# 1D and 2D algos and hyps to mesh bigQuad with triangles
mesh.Segment(bigQuad).LocalLength( 3 )
mesh.Triangle(bigQuad)
# compute the mesh
The result geometry and mesh is shown below
Usage of Medial Axis Projection algorithm
# Usage of Medial Axis Projection algorithm
# for meshing a ring face with quadrangles
import salome
# create a ring face
circleEdge1 = geom_builder.MakeCircleR( 3 )
circleEdge2 = geom_builder.MakeCircleR( 7 )
ring = geom_builder.MakeFaceWires( [ circleEdge1, circleEdge2 ], True, theName='Ring' )
circleLen1 = geom_builder.BasicProperties( circleEdge1 )[0]
circleLen2 = geom_builder.BasicProperties( circleEdge2 )[0]
# make a mesh
mesh = smesh_builder.Mesh( ring )
circNbSeg = 60
algo1d = mesh.Segment()
algo1d.NumberOfSegments( circNbSeg ) # division of circle edges
algo2d = mesh.Quadrangle( smeshBuilder.QUAD_MA_PROJ )
algo2d.StartEndLength( circleLen2 / circNbSeg, circleLen1 / circNbSeg ) # radial division
Usage of Segments around Vertex algorithm
# Usage of Segments around Vertex algorithm
# for meshing a box with quadrangles with refinement near vertices
import salome
# create a box
box = geom_builder.MakeBoxDXDYDZ( 10, 10, 10 )
# make a mesh
# define quadrangle meshing
algo1d.LocalLength( 1. )
mesh.Quadrangle()
# add Hexahedron algo to assure that there are no triangles
mesh.Hexahedron()
# define refinement near vertices
algo1d.LengthNearVertex( 0.2 )
