Filters usage
Filters allow picking only the mesh elements satisfying to a specific condition or a set of conditions. Filters can be used to create or edit mesh groups, remove elements from the mesh, control mesh quality by different parameters, etc.
Several filtering criteria can be combined together by using logical operators AND and OR. In addition, a filtering criterion can be reverted using logical operator NOT.
Mesh filters can use the functionality of mesh quality controls to filter mesh nodes / elements by a specific characteristic (Area, Length, etc).
This page provides a short description of the existing mesh filters, describes required parameters and gives simple examples of usage in Python scripts.
See also: Quality Controls
Aspect ratio
filters 2D mesh elements (faces) according to the aspect ratio value:
element type should be SMESH.FACE
functor type should be SMESH.FT_AspectRatio
threshold is floating point value (aspect ratio)
# Aspect ratio
# This script demonstrates various usages of filters
# create mesh
from mechanic import *
# get faces with aspect ratio > 2.5
filter = smesh_builder.GetFilter(SMESH.FACE, SMESH.FT_AspectRatio, SMESH.FT_MoreThan, 2.5)
ids = mesh.GetIdsFromFilter(filter)
print("Number of faces with aspect ratio > 2.5:", len(ids))
# get faces with aspect ratio > 1.5
filter = smesh_builder.GetFilter(SMESH.FACE, SMESH.FT_AspectRatio, '>', 1.5, mesh=mesh)
ids = filter.GetIDs()
print("Number of faces with aspect ratio > 1.5:", len(ids))
# copy the faces with aspect ratio > 1.5 to another mesh;
# this demonstrates that a filter can be used where usually a group or sub-mesh is acceptable
filter.SetMesh( mesh.GetMesh() ) # - actually non necessary as mesh is set at filter creation
mesh2 = smesh_builder.CopyMesh( filter, "AR > 1.5" )
print("Number of copied faces with aspect ratio > 1.5:", mesh2.NbFaces())
# create a group (Group on Filter) of faces with Aspect Ratio < 1.5
group = mesh.MakeGroup("AR < 1.5", SMESH.FACE, SMESH.FT_AspectRatio, '<', 1.5)
print("Number of faces with aspect ratio < 1.5:", group.Size())
# combine several criteria to Create a Group of only Triangular faces with Aspect Ratio < 1.5;
# note that contents of a GroupOnFilter is dynamically updated as the mesh changes
crit = [ smesh_builder.GetCriterion( SMESH.FACE, SMESH.FT_AspectRatio, '<', 1.5, BinaryOp=SMESH.FT_LogicalAND ),
smesh_builder.GetCriterion( SMESH.FACE, SMESH.FT_ElemGeomType,'=', SMESH.Geom_TRIANGLE ) ]
triaGroup = mesh.MakeGroupByCriteria( "Tria AR < 1.5", crit )
print("Number of triangles with aspect ratio < 1.5:", triaGroup.Size())
# get range of values of Aspect Ratio of all faces in the mesh
aspects = mesh.GetMinMax( SMESH.FT_AspectRatio )
print("MESH: Min aspect = %s, Max aspect = %s" % ( aspects[0], aspects[1] ))
# get max value of Aspect Ratio of faces in triaGroup
grAspects = mesh.GetMinMax( SMESH.FT_AspectRatio, triaGroup )
print("GROUP: Max aspect = %s" % grAspects[1])
# get Aspect Ratio of an element
aspect = mesh.FunctorValue( SMESH.FT_AspectRatio, ids[0] )
print("Aspect ratio of the face %s = %s" % ( ids[0], aspect ))
See also: Aspect Ratio
Aspect ratio 3D
filters 3D mesh elements (volumes) according to the aspect ratio value:
element type is SMESH.VOLUME
functor type is SMESH.FT_AspectRatio3D
# Aspect ratio 3D
# create mesh with volumes
# get volumes with aspect ratio < 2.0
filter = smesh_builder.GetFilter(SMESH.VOLUME, SMESH.FT_AspectRatio3D, SMESH.FT_LessThan, 2.0)
print("Number of volumes with aspect ratio < 2.0:", len(ids))
See also: Aspect Ratio 3D
Scaled Jacobian
filters 3D mesh elements (volumes) according to the scaled jacobian value:
functor type is SMESH.FT_ScaledJacobian
# Scaled Jacobian
# get volumes with scaled jacobian > 0.75
filter = smesh_builder.GetFilter(SMESH.VOLUME, SMESH.FT_ScaledJacobian, SMESH.FT_MoreThan, 0.75 )
print("Number of volumes with scaled jacobian > 0.75:", len(ids))
See also: Scaled Jacobian
Warping angle
filters 2D mesh elements (faces) according to the warping angle value:
element type is SMESH.FACE
functor type is SMESH.FT_Warping
threshold is floating point value (warping angle)
# Warping angle
# create mesh
# get faces with warping angle = 2.0e-13 with tolerance 5.0e-14
filter = smesh_builder.GetFilter(SMESH.FACE, SMESH.FT_Warping, "=", 2.0e-13, Tolerance=5.0e-14)
print("Number of faces with warping angle = 2.0e-13 (tolerance 5.0e-14):", len(ids))
See also: Warping
Warping 3D
filters 3D mesh elements (volumes) according to the maximum warping angle value of the faces of volumes:
functor type is SMESH.FT_Warping3D
# Warping 3D
# create mesh
filter = smesh_builder.GetFilter(SMESH.VOLUME, SMESH.FT_Warping3D, "=", 2.0e-13, Tolerance=5.0e-14)
print("Number of volumes with warping = 2.0e-13 (tolerance 5.0e-14):", len(ids))
See also: Warping 3D
Minimum angle
filters 2D mesh elements (faces) according to the minimum angle value:
functor type is SMESH.FT_MinimumAngle
threshold is floating point value (minimum angle)
# Minimum angle
# create mesh
# get faces with minimum angle > 75
filter = smesh_builder.GetFilter(SMESH.FACE, SMESH.FT_MinimumAngle,">", 75)
print("Number of faces with minimum angle > 75:", len(ids))
See also: Minimum Angle
Taper
filters 2D mesh elements (faces) according to the taper value:
functor type is SMESH.FT_Taper
threshold is floating point value (taper)
# Taper
# create mesh
# get faces with taper < 1.e-15
filter = smesh_builder.GetFilter(SMESH.FACE, SMESH.FT_Taper, SMESH.FT_LessThan, 1.e-15)
print("Number of faces with taper < 1.e-15:", len(ids))
See also: Taper
Skew
filters 2D mesh elements (faces) according to the skew value:
functor type is SMESH.FT_Skew
threshold is floating point value (skew)
# Skew
# create mesh
# get faces with skew > 50
filter = smesh_builder.GetFilter(SMESH.FACE, SMESH.FT_Skew, SMESH.FT_MoreThan, 50)
print("Number of faces with skew > 50:", len(ids))
See also: Skew
Area
filters 2D mesh elements (faces) according to the area value:
functor type is SMESH.FT_Area
threshold is floating point value (area)
# Area
# create mesh
# get faces with area > 60 and < 90
criterion1 = smesh_builder.GetCriterion(SMESH.FACE, SMESH.FT_Area, SMESH.FT_MoreThan, 60)
criterion2 = smesh_builder.GetCriterion(SMESH.FACE, SMESH.FT_Area, SMESH.FT_LessThan, 90)
filter = smesh_builder.GetFilterFromCriteria([criterion1,criterion2], SMESH.FT_LogicalAND)
print("Number of faces with area in range (60,90):", len(ids))
See also: Area
Volume
filters 3D mesh elements (volumes) according to the volume value:
functor type is SMESH.FT_Volume3D
threshold is floating point value (volume)
# Volume
# get volumes faces with volume > 100
filter = smesh_builder.GetFilter(SMESH.VOLUME, SMESH.FT_Volume3D, SMESH.FT_MoreThan, 100)
print("Number of volumes with volume > 100:", len(ids))
See also: Volume
Free borders
filters 1D mesh elements (edges) which represent free borders of a mesh:
element type is SMESH.EDGE
functor type is SMESH.FT_FreeBorders
threshold value is not required
# Free borders
import salome
salome.salome_init_without_session()
import SMESH
from salome.smesh import smeshBuilder
geom_builder = geomBuilder.New()
smesh_builder = smeshBuilder.New()
# create mesh
face = geom_builder.MakeFaceHW(100, 100, 1, theName="quadrangle")
mesh = smesh_builder.Mesh(face)
mesh.Segment().NumberOfSegments(10)
mesh.Triangle().MaxElementArea(25)
if not mesh.Compute(): raise Exception("Error when computing Mesh")
# get all free borders
filter = smesh_builder.GetFilter(SMESH.EDGE, SMESH.FT_FreeBorders)
print("Number of edges on free borders:", len(ids))
See also: Free Borders
Free edges
filters 2D mesh elements (faces) having edges (i.e. links between nodes, not mesh segments) belonging to one face of mesh only:
functor type is SMESH.FT_FreeEdges
# Free edges
import salome
import SMESH
# create mesh
face = geom_builder.MakeFaceHW(100, 100, 1)
geom_builder.addToStudy( face, "quadrangle" )
# get all faces with free edges
filter = smesh_builder.GetFilter(SMESH.FACE, SMESH.FT_FreeEdges)
print("Number of faces with free edges:", len(ids))
See also: Free Edges
Free nodes
filters free nodes:
element type is SMESH.NODE
functor type is SMESH.FT_FreeNodes
# Free nodes
# create mesh
# add node
mesh.AddNode(0,0,0)
# get all free nodes
filter = smesh_builder.GetFilter(SMESH.NODE, SMESH.FT_FreeNodes)
print("Number of free nodes:", len(ids))
See also: Free Nodes
Free faces
filters free faces:
functor type is SMESH.FT_FreeFaces
# Free faces
# create mesh
# get all free faces
filter = smesh_builder.GetFilter(SMESH.FACE, SMESH.FT_FreeFaces)
print("Number of free faces:", len(ids))
See also: Free Faces
Bare border faces
filters faces with bare borders:
functor type is SMESH.FT_BareBorderFace
# Bare border faces
# create mesh
# remove some faces to have faces with bare borders
mesh.RemoveElements( mesh.GetElementsByType(SMESH.FACE)[0:5] )
# get all faces with bare borders
filter = smesh_builder.GetFilter(SMESH.FACE, SMESH.FT_BareBorderFace)
print("Faces with bare borders:", ids)
See also: Bare border faces
Coplanar faces
filters coplanar faces:
functor type is SMESH.FT_CoplanarFaces
threshold value is the face ID
tolerance is in degrees
# Coplanar faces
# create mesh
faceID = mesh.GetElementsByType(SMESH.FACE)[0]
# get all faces co-planar to the first face with tolerance 5 degrees
filter = smesh_builder.GetFilter(SMESH.FACE, SMESH.FT_CoplanarFaces,faceID,Tolerance=5.0)
print("Number of faces coplanar with the first one:", len(ids))
Over-constrained faces
filters over-constrained faces:
functor type is SMESH.FT_OverConstrainedFace
# Over-constrained faces
# create mesh
# get all over-constrained faces
filter = smesh_builder.GetFilter(SMESH.FACE, SMESH.FT_OverConstrainedFace)
print("Over-constrained faces:", ids)
See also: Over-constrained faces
Double edges, Double faces, Double volumes
filters mesh elements basing on the same set of nodes:
element type is either SMESH.EDGE, SMESH.FACE or SMESH.VOLUME
functor type is either SMESH.FT_EqualEdges, SMESH.FT_EqualFaces or SMESH.FT_EqualVolumes,
# Double edges, Double faces, Double volumes
import salome
import SMESH
# make a mesh on a box
box = geom_builder.MakeBoxDXDYDZ(100,100,100)
mesh = smesh_builder.Mesh( box, "Box" )
mesh.Quadrangle()
mesh.Hexahedron()
# copy all elements with translation and Merge nodes
mesh.TranslateObject( mesh, smesh_builder.MakeDirStruct( 10,0,0), Copy=True )
mesh.MergeNodes( mesh.FindCoincidentNodes(1e-7) )
# create filters to find equal elements
equalEdgesFilter = smesh_builder.GetFilter(SMESH.EDGE, SMESH.FT_EqualEdges)
equalFacesFilter = smesh_builder.GetFilter(SMESH.FACE, SMESH.FT_EqualFaces)
equalVolumesFilter = smesh_builder.GetFilter(SMESH.VOLUME, SMESH.FT_EqualVolumes)
# get equal elements
print("Number of equal edges:", len( mesh.GetIdsFromFilter( equalEdgesFilter )))
print("Number of equal faces:", len( mesh.GetIdsFromFilter( equalFacesFilter )))
print("Number of equal volumes:", len( mesh.GetIdsFromFilter( equalVolumesFilter )))
Double nodes
filters mesh nodes which are coincident with other nodes (within a given tolerance):
functor type is SMESH.FT_EqualNodes
default tolerance is 1.0e-7
# Double nodes
import salome
import SMESH
mesh.Quadrangle()
mesh.Hexahedron()
mesh.TranslateObject( mesh, [10,0,0], Copy=True )
# create a filter to find nodes equal within tolerance of 1e-5
filter = smesh_builder.GetFilter(SMESH.NODE, SMESH.FT_EqualNodes, Tolerance=1e-5)
# get equal nodes
print("Number of equal nodes:", len( mesh.GetIdsFromFilter( filter )))
Node connectivity number
filters nodes according to a number of elements of highest dimension connected to a node:
element type should be SMESH.NODE
functor type should be SMESH.FT_NodeConnectivityNumber
threshold is an integer value (number of elements)
# Number of connectivities of a node
# create a mesh
# get nodes connected to more than 6 tetrahedra
conn_nb_filter = smesh_builder.GetFilter(SMESH.NODE, SMESH.FT_NodeConnectivityNumber,'>', 6 )
ids = mesh.GetIdsFromFilter( conn_nb_filter )
print("Number of nodes connected to more than 6 tetrahedra:", len(ids))
Borders at multi-connection
filters 1D mesh elements (segments) according to the specified number of connections (faces and volumes on whose border the segment lies):
functor type is SMESH.FT_MultiConnection
threshold is integer value (number of connections)
# Borders at multi-connection
import salome
import SMESH
mesh.Quadrangle()
mesh.Hexahedron()
# copy all elements with translation and merge nodes
mesh.MergeNodes( mesh.FindCoincidentNodes( 1e-5 ))
# get mesh edges with number of connected elements (faces and volumes) == 3
filter = smesh_builder.GetFilter(SMESH.EDGE, SMESH.FT_MultiConnection, 3)
print("Number of border edges with 3 faces connected:", len(ids))
See also: Borders at Multiconnection
Borders at multi-connection 2D
filters 2D mesh elements (faces) with the specified maximal number of faces connected to a border (link between nodes, not mesh segment):
functor type is SMESH.FT_MultiConnection2D
# Borders at multi-connection 2D
# create mesh
# get faces which consist of edges belonging to 2 mesh elements
filter = smesh_builder.GetFilter(SMESH.FACE, SMESH.FT_MultiConnection2D, 2)
print("Number of faces consisting of edges belonging to 2 faces:", len(ids))
See also: Borders at Multiconnection 2D
Length
filters 1D mesh elements (edges) according to the edge length value:
element type should be SMESH.EDGE
functor type should be SMESH.FT_Length
threshold is floating point value (length)
# Length
# create mesh
# get edges with length > 14
filter = smesh_builder.GetFilter(SMESH.EDGE, SMESH.FT_Length, SMESH.FT_MoreThan, 14)
print("Number of edges with length > 14:", len(ids))
See also: Length 1D
Length 2D
filters 2D mesh elements (faces) according to the maximum length of its edges (links between nodes):
functor type should be SMESH.FT_Length2D
threshold is floating point value (edge length)
# Length 2D
# create mesh
# get all faces that have edges with length > 14
filter = smesh_builder.GetFilter(SMESH.FACE, SMESH.FT_MaxElementLength2D, SMESH.FT_MoreThan, 14)
print("Number of faces with maximum edge length > 14:", len(ids))
See also: Length 2D
Element Diameter 2D
filters 2D mesh elements (faces) according to the maximum length of its edges and diagonals:
functor type should be SMESH.FT_MaxElementLength2D
# Element Diameter 2D
# create mesh
# get all faces that have elements with length > 10
filter = smesh_builder.GetFilter(SMESH.FACE, SMESH.FT_MaxElementLength2D, SMESH.FT_MoreThan, 10)
print("Number of faces with maximum element length > 10:", len(ids))
See also: Element Diameter 2D
Element Diameter 3D
filters 3D mesh elements (volumes) according to the maximum length of its edges and diagonals:
element type should be SMESH.VOLUME
functor type should be SMESH.FT_MaxElementLength3D
threshold is floating point value (edge/diagonal length)
# Element Diameter 3D
# get all volumes that have elements with length > 10
filter = smesh_builder.GetFilter(SMESH.VOLUME, SMESH.FT_MaxElementLength3D, SMESH.FT_MoreThan, 10)
print("Number of volumes with maximum element length > 10:", len(ids))
See also: Element Diameter 3D
Bare border volumes
filters 3D mesh elements with bare borders, i.e. having a facet not shared with other volumes and without a face on it:
functor type is SMESH.FT_BareBorderVolume
# Bare border volumes
# create mesh
# remove some volumes to have volumes with bare borders
mesh.RemoveElements(mesh.GetElementsByType(SMESH.VOLUME)[0:5])
# get all volumes with bare borders
filter = smesh_builder.GetFilter(SMESH.VOLUME, SMESH.FT_BareBorderVolume)
print("Volumes with bare borders:", ids)
See also: Bare border volumes
Over-constrained volumes
filters over-constrained volumes, whose all nodes are on the mesh boundary:
functor type is SMESH.FT_OverConstrainedVolume
# Over-constrained volumes
# create mesh
# get all over-constrained volumes
filter = smesh_builder.GetFilter(SMESH.VOLUME, SMESH.FT_OverConstrainedVolume)
print("Over-constrained volumes:", ids)
Belong to Mesh Group
filters mesh entities (nodes or elements) included in a mesh group defined by threshold value:
element type can be any, from SMESH.NODE to SMESH.BALL
functor type should be SMESH.FT_BelongToMeshGroup
threshold is mesh group object
# Belong to Mesh Group criterion
# create mesh
# create a group of all faces (quadrangles) generated on sub_face3
quads_on_face3 = mesh.MakeGroup("quads_on_face3", SMESH.FACE, SMESH.FT_BelongToGeom,'=',sub_face3)
print("There are %s quadrangles generated on '%s' and included in the group '%s'" % ( quads_on_face3.Size(), sub_face3.GetName(), quads_on_face3.GetName() ))
# create a group of all the rest quadrangles, generated on other faces by combining 2 criteria:
# - negated FT_BelongToMeshGroup to select elements not included in quads_on_face3
# - FT_ElemGeomType to select quadrangles
not_on_face3 = smesh_builder.GetCriterion( SMESH.FACE, SMESH.FT_BelongToMeshGroup,'=',quads_on_face3, SMESH.FT_LogicalNOT )
quadrangles = smesh_builder.GetCriterion( SMESH.FACE, SMESH.FT_ElemGeomType,'=',SMESH.Geom_QUADRANGLE )
rest_quads = mesh.MakeGroupByCriteria("rest_quads", [ not_on_face3, quadrangles ])
print("'%s' group includes all the rest %s quadrangles" % ( rest_quads.GetName(), rest_quads.Size() ))
Belong to Geom
filters mesh entities (nodes or elements) which all nodes lie on the shape defined by threshold value:
functor type should be SMESH.FT_BelongToGeom
threshold is geometrical object
tolerance is a distance between a node and the geometrical object; it is used if an node is not associated to any geometry.
# Belong to Geom
# create mesh
# get all faces which nodes lie on the face sub_face3
filter = smesh_builder.GetFilter(SMESH.FACE, SMESH.FT_BelongToGeom, sub_face3)
print("Number of faces which nodes lie on sub_face3:", len(ids))
Lying on Geom
filters mesh entities (nodes or elements) at least one node of which lies on the shape defined by threshold value:
functor type should be SMESH.FT_LyingOnGeom
# Lying on Geom
# create mesh
# get all faces at least one node of each lies on the face sub_face3
filter = smesh_builder.GetFilter(SMESH.FACE, SMESH.FT_LyingOnGeom, sub_face3)
print("Number of faces at least one node of each lies on sub_face3:", len(ids))
Belong to Plane
filters mesh entities (nodes or elements) which all nodes belong to the plane defined by threshold value with the given tolerance:
element type can be any except SMESH.VOLUME
functor type should be SMESH.FT_BelongToPlane
threshold is geometrical object (plane)
# Belong to Plane
# create mesh
# create plane
plane_1 = geom_builder.MakePlane(p3,seg1,2000)
geom_builder.addToStudy(plane_1, "plane_1")
# get all nodes which lie on the plane \a plane_1
filter = smesh_builder.GetFilter(SMESH.NODE, SMESH.FT_BelongToPlane, plane_1)
print("Number of nodes which lie on the plane plane_1:", len(ids))
Belong to Cylinder
filters mesh entities (nodes or elements) which all nodes belong to the cylindrical face defined by threshold value with the given tolerance:
functor type should be SMESH.FT_BelongToCylinder
threshold is geometrical object (cylindrical face)
# Belong to Cylinder
# create mesh
# get all faces which lie on the cylindrical face \a sub_face1
filter = smesh_builder.GetFilter(SMESH.FACE, SMESH.FT_BelongToCylinder, sub_face1)
print("Number of faces which lie on the cylindrical surface sub_face1:", len(ids))
Belong to Surface
filters mesh entities (nodes or elements) which all nodes belong to the arbitrary surface defined by threshold value with the given tolerance:
functor type should be SMESH.FT_BelongToGenSurface
threshold is geometrical object (arbitrary surface)
# Belong to Surface
# create mesh
# create b-spline
spline_1 = geom_builder.MakeInterpol([p4,p6,p3,p1])
surface_1 = geom_builder.MakePrismVecH( spline_1, vz, 70.0 )
geom_builder.addToStudy(surface_1, "surface_1")
# get all nodes which lie on the surface \a surface_1
filter = smesh_builder.GetFilter(SMESH.NODE, SMESH.FT_BelongToGenSurface, surface_1)
print("Number of nodes which lie on the surface surface_1:", len(ids))
Range of IDs
filters mesh entities elements (nodes or elements) according to the specified identifiers range:
functor type is SMESH.FT_RangeOfIds
threshold is string listing required IDs and/or ranges of IDs, e.g.”1,2,3,50-60,63,67,70-78”
# Range of IDs
# create mesh
# get nodes with identifiers [5-10] and [15-30]
criterion1 = smesh_builder.GetCriterion(SMESH.NODE, SMESH.FT_RangeOfIds, Threshold="5-10",\
BinaryOp=SMESH.FT_LogicalOR)
criterion2 = smesh_builder.GetCriterion(SMESH.NODE, SMESH.FT_RangeOfIds, Threshold="15-30")
filter = smesh_builder.CreateFilterManager().CreateFilter()
filter.SetCriteria([criterion1,criterion2])
print("Number of nodes in ranges [5-10] and [15-30]:", len(ids))
Badly oriented volume
filters 3D mesh elements (volumes), which are incorrectly oriented from the point of view of MED convention.
functor type is SMESH.FT_BadOrientedVolume
threshold is not required
# Badly oriented volume
# get all badly oriented volumes
filter = smesh_builder.GetFilter(SMESH.VOLUME, SMESH.FT_BadOrientedVolume)
print("Number of badly oriented volumes:", len(ids))
Linear / quadratic
filters linear / quadratic mesh elements:
element type should be either SMESH.EDGE, SMESH.FACE or SMESH.VOLUME
functor type is SMESH.FT_LinearOrQuadratic
if unary operator is set to SMESH.FT_LogicalNOT, the quadratic elements are selected, otherwise (by default) linear elements are selected
# Linear / quadratic
# create mesh
# get linear and quadratic edges
filter_linear = smesh_builder.GetFilter(SMESH.EDGE, SMESH.FT_LinearOrQuadratic)
filter_quadratic = smesh_builder.GetFilter(SMESH.EDGE, SMESH.FT_LinearOrQuadratic, SMESH.FT_LogicalNOT)
ids_linear = mesh.GetIdsFromFilter(filter_linear)
ids_quadratic = mesh.GetIdsFromFilter(filter_quadratic)
print("Number of linear edges:", len(ids_linear), "; number of quadratic edges:", len(ids_quadratic))
# convert mesh to quadratic
print("Convert to quadratic...")
mesh.ConvertToQuadratic()
Group color
filters mesh entities, belonging to the group with the color defined by the threshold value.
functor type is SMESH.FT_GroupColor
threshold should be of SALOMEDS.Color type
# Group color
# create mesh
# create group of edges
all_edges = mesh.GetElementsByType(SMESH.EDGE)
grp = mesh.MakeGroupByIds("edges group", SMESH.EDGE, all_edges[:len(all_edges) // 4])
import SALOMEDS
c = SALOMEDS.Color(0.1, 0.5, 1.0)
grp.SetColor(c)
# get number of the edges not belonging to the group with the given color
filter = smesh_builder.GetFilter(SMESH.EDGE, SMESH.FT_GroupColor, c, SMESH.FT_LogicalNOT)
print ("Number of edges not belonging to the group with color (0.1, 0.5, 1.0):", len(ids))
Geometry type
filters mesh elements by the geometric type defined with the threshold value. The list of available geometric types depends on the element entity type.
element type can be any, e.g.: SMESH.EDGE, SMESH.FACE, SMESH.VOLUME, etc.
functor type should be SMESH.FT_ElemGeomType
threshold is either of smesh.GeometryType values. Type SMESH.GeometryType._items in the Python Console to see all geometric types.
# Geometry type
# get all triangles, quadrangles, tetrahedrons, pyramids
filter_tri = smesh_builder.GetFilter(SMESH.FACE, SMESH.FT_ElemGeomType, SMESH.Geom_TRIANGLE)
filter_qua = smesh_builder.GetFilter(SMESH.FACE, SMESH.FT_ElemGeomType, SMESH.Geom_QUADRANGLE)
filter_tet = smesh_builder.GetFilter(SMESH.VOLUME, SMESH.FT_ElemGeomType, SMESH.Geom_TETRA)
filter_pyr = smesh_builder.GetFilter(SMESH.VOLUME, SMESH.FT_ElemGeomType, SMESH.Geom_PYRAMID)
ids_tri = mesh.GetIdsFromFilter(filter_tri)
ids_qua = mesh.GetIdsFromFilter(filter_qua)
ids_tet = mesh.GetIdsFromFilter(filter_tet)
ids_pyr = mesh.GetIdsFromFilter(filter_pyr)
print("Number of triangles:", len(ids_tri))
print("Number of quadrangles:", len(ids_qua))
print("Number of tetrahedrons:", len(ids_tet))
print("Number of pyramids:", len(ids_pyr))
Entity type
filters mesh elements by the geometric type and number of nodes.
functor type should be SMESH.FT_EntityType
threshold is either of SMESH.EntityType values. Type SMESH.EntityType._items in the Python Console to see all entity types.
# Entity type
# create a mesh
# make the mesh quadratic
# make some elements bi-quadratic
for face in shape_faces[: len(shape_faces) // 2]:
mesh.ConvertToQuadratic( theSubMesh=mesh.Group( face ), theToBiQuad=True )
# get triangles with 7 nodes
filter_tri = smesh_builder.GetFilter(SMESH.FACE, SMESH.FT_EntityType,'=', SMESH.Entity_BiQuad_Triangle )
print("Number of bi-quadratic triangles:", len(ids_tri))
Ball diameter
filters ball elements by diameter.
element type should be SMESH.BALL
functor type should be SMESH.FT_BallDiameter
threshold is floating point value (ball diameter)
# Ball diameter
# create a mesh
# create several balls with increasing diameter
for i in range(1,10):
diameter = float( i )
mesh.AddBall( i, diameter )
pass
# get balls with diameter > 5.
diam_filter = smesh_builder.GetFilter(SMESH.BALL, SMESH.FT_BallDiameter,'>', 5. )
ids = mesh.GetIdsFromFilter( diam_filter )
print("Number of balls with diameter > 5:", len(ids))
Elements of a domain
filters elements of a specified domain.
functor type should be SMESH.FT_ConnectedElements
threshold is either (1) node ID or (2) geometrical vertex or (3) 3 coordinates of a point.
# "Elements of a domain" filter and "Renumber" hypothesis
import salome
import SMESH
# create two boxes to have two domains in the mesh
box1 = geom_builder.MakeBoxDXDYDZ( 100,100,100 )
box2 = geom_builder.MakeTranslation( box1, 200, 0, 0 )
boxes = geom_builder.MakeCompound( [box1, box2] )
box1, box2 = geom_builder.SubShapeAll( boxes, geom_builder.ShapeType["SHAPE"], "box")
vertex = geom_builder.SubShape( box1, geom_builder.ShapeType["VERTEX"], [1] )
# create a mesh
mesh = smesh_builder.Mesh( boxes )
mesh.Segment(box1).NumberOfSegments( 5 ) # to have different nb of elements on the boxes
mesh.Segment(box2).NumberOfSegments( 10 )
mesh.Quadrangle()
ijkAlgo = mesh.Hexahedron()
# Use Renumber hypothesis to get hexahedra and nodes numbered like in a structured mesh.
# k axis of box1 will be ( 100,100,0 ) - ( 100,100,100 )
# k axis of box2 will be ( 0,0,0 ) - (0,0,100), by default
v000 = geom_builder.MakeVertex( 100,100,0, theName='v000' ) # can use box sub-vertex or standalone one
v001 = geom_builder.GetVertexNearPoint( box1, geom_builder.MakeVertex(100,100,100), theName='v001')
ijkAlgo.Renumber([ smeshBuilder.BlockCS( box1, v000, v001 ) ])
# Create filters with FT_ConnectedElements criterion by pointing a domain in different ways:
# using point coordinates in box_1
nodeFilter = smesh_builder.GetFilter( SMESH.NODE, SMESH.FT_ConnectedElements, "=", "1.,2,10", mesh=mesh )
print("Nb. nodes in box_1:", len( nodeFilter.GetIDs()))
# using point coordinates in box_2
edgeFilter = smesh_builder.GetFilter( SMESH.EDGE, SMESH.FT_ConnectedElements, "=", [202,1,1 ], mesh=mesh )
print("Nb. segments in box_2:", len( edgeFilter.GetIDs()))
# using a geom vertex of box_1
faceFilter = smesh_builder.GetFilter( SMESH.FACE, SMESH.FT_ConnectedElements, "=", vertex, mesh=mesh )
print("Nb. faces in box_1:", len( edgeFilter.GetIDs()))
# using node ID in box_2
voluFilter = smesh_builder.GetFilter( SMESH.VOLUME, SMESH.FT_ConnectedElements, "=", 10, mesh=mesh )
print("Nb. volumes in box_2:", len( voluFilter.GetIDs()))
How to combine several criteria into a filter?
Several criteria can be combined into a filter.
# Combine several criteria into a filter
# create mesh
# get all the quadrangle faces ...
criterion1 = smesh_builder.GetCriterion(SMESH.FACE, SMESH.FT_ElemGeomType, SMESH.Geom_QUADRANGLE, SMESH.FT_LogicalAND)
# ... but those from sub_face3
criterion2 = smesh_builder.GetCriterion(SMESH.FACE, SMESH.FT_BelongToGeom, sub_face3, SMESH.FT_LogicalNOT)
quadFilter = smesh_builder.GetFilterFromCriteria([criterion1,criterion2])
# get faces satisfying the criteria
ids = mesh.GetIdsFromFilter(quadFilter)
# create a group of faces satisfying the criteria
myGroup = mesh.GroupOnFilter(SMESH.FACE,"Quads_on_cylindrical_faces",quadFilter)
