SMESH module
DriverMED_ReadStatus
class SMESH.DriverMED_ReadStatus
Enumeration for mesh read status
DRS_OK
Ok
DRS_EMPTY
a file contains no mesh with the given name
DRS_WARN_RENUMBER
a MED file has overlapped ranges of element numbers, so the numbers from the file are ignored
DRS_WARN_SKIP_ELEM
some elements were skipped due to incorrect file data
DRS_WARN_DESCENDING
some elements were skipped due to descending connectivity
DRS_FAIL
general failure (exception etc.)
ComputeErrorName
class SMESH.ComputeErrorName
Enumeration of computation errors
COMPERR_OK
Ok
COMPERR_BAD_INPUT_MESH
wrong mesh of lower sub-mesh
COMPERR_STD_EXCEPTION
some std exception raised
COMPERR_OCC_EXCEPTION
OCC exception raised
COMPERR_SLM_EXCEPTION
SALOME exception raised
COMPERR_EXCEPTION
other exception raised
COMPERR_MEMORY_PB
memory allocation problem
COMPERR_ALGO_FAILED
computation failed
COMPERR_BAD_SHAPE
bad geometry
COMPERR_WARNING
algo reports error but sub-mesh is computed anyway
COMPERR_CANCELED
compute canceled
COMPERR_NO_MESH_ON_SHAPE
no mesh elements assigned to sub-mesh
COMPERR_BAD_PARMETERS
incorrect hypotheses parameters
ComputeError
Error details
code
int - ComputeErrorName or, if negative, algo specific code
comment
str - textual problem description
algoName
str
subShapeID
int - id of sub-shape of a shape to mesh
hasBadMesh
boolean - there are elements preventing computation available for visualization
Measure
class SMESH.Measure
Data returned by measure operations
minX, minY, minZ
double - coordinates of one point
maxX, maxY, maxZ
double - coordinates of another point
node1, node2
long - IDs of two nodes
elem1, elem2
long - IDs of two elements
value
double - distance
NodePosition
class SMESH.NodePosition
Node location on a shape
shapeID
long - ID of a shape
shapeType
GEOM.shape_type - type of shape
params
list of float -
  • [U] on EDGE,
  • [U,V] on FACE,
  • [] on the rest shapes
ElementPosition
class SMESH.ElementPosition
Element location on a shape
shapeID
shapeType
PolySegment
class SMESH.PolySegment
Define a cutting plane passing through two points. Used in MakePolyLine()
node1ID1, node1ID2
int,int - point 1: if node1ID2 > 0, then the point is in the middle of a face edge defined
by two nodes, else it is at node1ID1
node2ID1, node2ID2
int,int - point 2: if node2ID2 > 0, then the point is in the middle of a face edge defined
by two nodes, else it is at node2ID1
vector
SMESH.DirStruct - vector on the plane; to use a default plane set vector = (0,0,0)
ElementType
class SMESH.ElementType
Enumeration for element type, like in SMDS
ALL
NODE
EDGE
FACE
VOLUME
ELEM0D
BALL
NB_ELEMENT_TYPES
EntityType
class SMESH.EntityType
Enumeration of entity type
Entity_Node
Entity_0D
Entity_Edge
Entity_Quad_Edge
Entity_Triangle
Entity_Quad_Triangle
Entity_BiQuad_Triangle
Entity_Quadrangle
Entity_Quad_Quadrangle
Entity_BiQuad_Quadrangle
Entity_Polygon
Entity_Quad_Polygon
Entity_Tetra
Entity_Quad_Tetra
Entity_Pyramid
Entity_Quad_Pyramid
Entity_Hexa
Entity_Quad_Hexa
Entity_TriQuad_Hexa
Entity_Penta
Entity_Quad_Penta
Entity_BiQuad_Penta
Entity_Hexagonal_Prism
Entity_Polyhedra
Entity_Quad_Polyhedra
Entity_Ball
Entity_Last
GeometryType
class SMESH.GeometryType
Enumeration of element geometry type
Geom_POINT
Geom_EDGE
Geom_TRIANGLE
Geom_QUADRANGLE
Geom_POLYGON
Geom_TETRA
Geom_PYRAMID
Geom_HEXA
Geom_PENTA
Geom_HEXAGONAL_PRISM
Geom_POLYHEDRA
Geom_BALL
Geom_LAST
Hypothesis_Status
class SMESH.Hypothesis_Status
Enumeration of result of hypothesis addition/removal
HYP_OK
Ok
HYP_MISSING
algo misses a hypothesis
HYP_CONCURRENT
several applicable hypotheses
HYP_BAD_PARAMETER
hypothesis has a bad parameter value
HYP_HIDDEN_ALGO
an algo is hidden by an upper dim algo generating all-dim elements
HYP_HIDING_ALGO
an algo hides lower dim algos by generating all-dim elements
HYP_UNKNOWN_FATAL
all statuses below should be considered as fatal for Add/RemoveHypothesis operations
HYP_INCOMPATIBLE
hypothesis does not fit algorithm
HYP_NOTCONFORM
not conform mesh is produced applying a hypothesis
HYP_ALREADY_EXIST
such hypothesis already exist
HYP_BAD_DIM
bad dimension
HYP_BAD_SUBSHAPE
shape is neither the main one, nor its sub-shape, nor a group
HYP_BAD_GEOMETRY
geometry mismatches algorithm’s expectation
HYP_NEED_SHAPE
algorithm can work on shape only
HYP_INCOMPAT_HYPS
several additional hypotheses are incompatible one with other
FunctorType
class SMESH.FunctorType
Enumeration of functor types
FT_AspectRatio
FT_AspectRatio3D
FT_Warping
FT_MinimumAngle
FT_Taper
FT_Skew
FT_Area
FT_Volume3D
FT_MaxElementLength2D
FT_MaxElementLength3D
FT_FreeBorders
FT_FreeEdges
FT_FreeNodes
FT_FreeFaces
FT_EqualNodes
FT_EqualEdges
FT_EqualFaces
FT_EqualVolumes
FT_MultiConnection
FT_MultiConnection2D
FT_Length
FT_Length2D
FT_Deflection2D
FT_NodeConnectivityNumber
FT_BelongToMeshGroup
FT_BelongToGeom
FT_BelongToPlane
FT_BelongToCylinder
FT_BelongToGenSurface
FT_LyingOnGeom
FT_RangeOfIds
FT_BadOrientedVolume
FT_BareBorderVolume
FT_BareBorderFace
FT_OverConstrainedVolume
FT_OverConstrainedFace
FT_LinearOrQuadratic
FT_GroupColor
FT_ElemGeomType
FT_EntityType
FT_CoplanarFaces
FT_BallDiameter
FT_ConnectedElements
FT_LessThan
FT_MoreThan
FT_EqualTo
FT_LogicalNOT
FT_LogicalAND
FT_LogicalOR
FT_Undefined
Filter.Criterion
class SMESH.Filter.Criterion
Structure containing information of a criterion
Type
long - value of item of SMESH.FunctorType
Compare
long - value of item of SMESH.FunctorType in ( FT_LessThan, FT_MoreThan, FT_EqualTo )
Threshold
double - threshold value
ThresholdStr
string - Threshold value defined as string. Used for:
  1. Diapason of identifiers. Example: “1,2,3,5-10,12,27-29”.
  2. Storing name of shape.
  3. Storing group color “0.2;0;0.5”.
  4. Storing point coordinates.
ThresholdID
string - One more threshold value defined as string. Used for storing id of shape
UnaryOp
long - unary logical operation: FT_LogicalNOT or FT_Undefined
BinaryOp
long - binary logical operation FT_LogicalAND, FT_LogicalOR etc.
Tolerance
double - Tolerance is used for
  1. Comparison of real values.
  2. Detection of geometrical coincidence.
TypeOfElement
ElementType - type of element SMESH.ElementType (SMESH.NODE, SMESH.FACE etc.)
Precision
long - Precision of numerical functors
FreeEdges.Border
class FreeEdges.Border
Free edge: edge connected to one face only
myElemId
long - ID of a face
myPnt1,myPnt2
PointStruct
class SMESH.PointStruct
3D point.
Use GetPointStruct() to convert a vertex (GEOM.GEOM_Object) to PointStruct
x,y,z
double - point coordinates
DirStruct
class SMESH.DirStruct
3D vector.
Use GetDirStruct() to convert a vector (GEOM.GEOM_Object) to DirStruct
PS
PointStruct - vector components
AxisStruct
class SMESH.AxisStruct
Axis defined by its origin and its vector.
Use GetAxisStruct() to convert a line or plane (GEOM.GEOM_Object) to AxisStruct
x,y,z
double - coordinates of the origin
vx,vy,vz
double - components of the vector
Filter
class SMESH.Filter
Filter of mesh entities
GetElementsId(mesh)
Return satisfying elements
Parameters:
mesh (SMESH.SMESH_Mesh) – the mesh; it can be obtained via GetMesh()
Returns:
list of IDs
GetIDs()
Return satisfying elements. A mesh to filter must be already set, either via SetMesh() method or via mesh argument of GetFilter()
Returns:
list of IDs
SetMesh(mesh)
Set mesh to filter
Parameters:
SetCriteria(criteria)
Define filtering criteria
Parameters:
criteria – list of SMESH.Filter.Criterion
NumericalFunctor
class SMESH.NumericalFunctor
Calculate value by ID of mesh entity. Base class of various functors
GetValue(elementID)
Compute a value
Parameters:
elementID – ID of element or node
Returns:
floating value
SMESH_Mesh
class SMESH.SMESH_Mesh
Mesh. It is a Python wrap over a CORBA interface of mesh.
All its methods are exposed via smeshBuilder.Mesh class that you can obtain by calling:
smeshBuilder_mesh = smesh.Mesh( smesh_mesh )
SMESH_MeshEditor
class SMESH.SMESH_MeshEditor
Mesh editor. It is a Python wrap over a CORBA SMESH_MeshEditor interface. All its methods are exposed via smeshBuilder.Mesh class.
class Extrusion_Error
Enumeration of errors of ExtrusionAlongPathObjects()
EXTR_OK
EXTR_NO_ELEMENTS
EXTR_PATH_NOT_EDGE
EXTR_BAD_PATH_SHAPE
EXTR_BAD_STARTING_NODE
EXTR_BAD_ANGLES_NUMBER
EXTR_CANT_GET_TANGENT
class SMESH_MeshEditor.Sew_Error
Enumeration of errors of SMESH_MeshEditor.Sewing… methods
SEW_OK
SEW_BORDER1_NOT_FOUND
SEW_BORDER2_NOT_FOUND
SEW_BOTH_BORDERS_NOT_FOUND
SEW_BAD_SIDE_NODES
SEW_VOLUMES_TO_SPLIT
SEW_DIFF_NB_OF_ELEMENTS
SEW_TOPO_DIFF_SETS_OF_ELEMENTS
SEW_BAD_SIDE1_NODES
SEW_BAD_SIDE2_NODES
SEW_INTERNAL_ERROR
SMESH_Pattern
class SMESH.SMESH_Pattern
Pattern mapper. Use a pattern defined by user for
  • creating mesh elements on geometry, faces or blocks
  • refining existing mesh elements, faces or hexahedra
The pattern is defined by a string as explained here.
Usage work-flow is:
  • Define a pattern via Load… method
  • Compute future positions of nodes via Apply… method
  • Create nodes and elements in a mesh via MakeMesh() method
LoadFromFile(patternFileContents)
Load a pattern from the string patternFileContents
Parameters:
patternFileContents (str) – string defining a pattern
Returns:
True if succeeded
LoadFromFace(mesh, geomFace, toProject)
Create a 2D pattern from the mesh built on geomFace.
Parameters:
  • mesh (SMESH.SMESH_Mesh) – source mesh
  • geomFace (GEOM.GEOM_Object) – geometrical face whose mesh forms a pattern
  • toProject (boolean) – if True makes override nodes positions on geomFace computed by mesher
Returns:
True if succeeded
LoadFrom3DBlock(mesh, geomBlock)
Create a 3D pattern from the mesh built on geomBlock
Parameters:
  • geomBlock (GEOM.GEOM_Object) – geometrical block whose mesh forms a pattern
Returns:
True if succeeded
ApplyToFace(geomFace, vertexOnKeyPoint1, toReverse)
Compute nodes coordinates by applying the loaded pattern to geomFace. The first key-point will be mapped into vertexOnKeyPoint1, which must be in the outer wire of geomFace
Parameters:
  • geomFace (GEOM.GEOM_Object) – the geometrical face to generate faces on
  • vertexOnKeyPoint1 (GEOM.GEOM_Object) – the vertex to be at the 1st key-point
  • toReverse (boolean) – to reverse order of key-points
Returns:
list of SMESH.PointStruct - computed coordinates of points of the pattern
ApplyTo3DBlock(geomBlock, vertex000, vertex001)
Compute nodes coordinates by applying the loaded pattern to geomBlock. The (0,0,0) key-point will be mapped into vertex000. The (0,0,1) key-point will be mapped into vertex001.
Parameters:
  • geomBlock (GEOM.GEOM_Object) – the geometrical block to generate volume elements on
  • vertex000 (GEOM.GEOM_Object) – the vertex to superpose (0,0,0) key-point of pattern
  • vertex001 (GEOM.GEOM_Object) – the vertex to superpose (0,0,1) key-point of pattern
Returns:
ApplyToMeshFaces(mesh, facesIDs, nodeIndexOnKeyPoint1, toReverse)
Compute nodes coordinates by applying the loaded pattern to mesh faces. The first key-point will be mapped into nodeIndexOnKeyPoint1 -th node of each mesh face
Parameters:
  • mesh (SMESH.SMESH_Mesh) – the mesh where to refine faces
  • facesIDs (list_of_ids) – IDs of faces to refine
  • nodeIndexOnKeyPoint1 (int) – index of a face node to be at 1-st key-point of pattern
Returns:
ApplyToHexahedrons(mesh, volumesIDs, node000Index, node001Index)
Compute nodes coordinates by applying the loaded pattern to hexahedra. The (0,0,0) key-point will be mapped into Node000Index -th node of each volume. The (0,0,1) key-point will be mapped into node001Index -th node of each volume.
Parameters:
  • mesh (SMESH.SMESH_Mesh) – the mesh where to refine hexahedra
  • volumesIDs (list_of_ids) – IDs of volumes to refine
  • node000Index (long) – index of a volume node to be at (0,0,0) key-point of pattern
  • node001Index (long) – index of a volume node to be at (0,0,1) key-point of pattern
Returns:
MakeMesh(mesh, createPolygons, createPolyedrs)
Create nodes and elements in mesh using nodes coordinates computed by either of Apply…() methods. If createPolygons is True, replace adjacent faces by polygons to keep mesh conformity. If createPolyedrs is True, replace adjacent volumes by polyedrs to keep mesh conformity.
Parameters:
  • mesh (SMESH.SMESH_Mesh) – the mesh to create nodes and elements in
  • createPolygons (boolean) – to create polygons to to keep mesh conformity
  • createPolyedrs (boolean) – to create polyherda to to keep mesh conformity
Returns:
True if succeeded
SMESH_subMesh
class SMESH.SMESH_subMesh
Sub-mesh
GetNumberOfElements()
Return number of elements in the sub-mesh
GetNumberOfNodes(all)
Return number of nodes in the sub-mesh
Parameters:
all (boolean) – if True, also return nodes assigned to boundary sub-meshes
GetElementsId()
Return IDs of elements in the sub-mesh
GetNodesId()
Return IDs of nodes in the sub-mesh
GetSubShape()
Return geom shape the sub-mesh is dedicated to
GetId()
Return ID of the geom shape the sub-mesh is dedicated to
GetMeshInfo()
Return number of mesh elements of each SMESH.EntityType. Use EnumToLong() to get an integer from an item of SMESH.EntityType.
Returns:
array of number of elements per SMESH.EntityType
GetMesh()
Return the SMESH.SMESH_Mesh
SMESH_GroupBase
class SMESH.SMESH_GroupBase
Mesh group. Base class of standalone group, group on geometry and group on filter. Inherit all methods from SMESH_IDSource.
SetName(name)
Set group name
GetName()
Return group name
GetType()
Return group type (type of elements in the group)
Size()
Return the number of elements in the group
IsEmpty()
Return True if the group does not contain any elements
Contains(elem_id)
Return True if the group contains an element with ID == elem_id
GetID(elem_index)
Return ID of an element at position elem_index counted from 1
GetNumberOfNodes()
Return the number of nodes of cells included to the group. For a nodal group return the same value as Size() function
GetNodeIDs()
Return IDs of nodes of cells included to the group. For a nodal group return result of GetListOfID() function
SetColor(color)
Set group color
Parameters:
color (SALOMEDS.Color) – color
GetColor()
Return group color
Returns:
SALOMEDS.Color
SMESH_Group
Standalone mesh group. Inherits all methods of SMESH.SMESH_GroupBase
Clear()
Clears the group’s contents
Add(elem_ids)
Adds elements or nodes with specified identifiers to the group
Parameters:
elem_ids (list_of_ids) – IDs to add
AddFrom(idSource)
Add all elements or nodes from the specified source to the group
Parameters:
idSource (SMESH.SMESH_IDSource) – an object to retrieve IDs from
Remove(elem_ids)
Removes elements or nodes with specified identifiers from the group
Parameters:
elem_ids (list_of_ids) – IDs to remove
SMESH_GroupOnGeom
class SMESH.SMESH_GroupOnGeom
Group linked to geometry. Inherits all methods of SMESH.SMESH_GroupBase
GetShape()
Return an associated geometry
Returns:
GEOM.GEOM_Object
SMESH_GroupOnFilter
class SMESH.SMESH_GroupOnFilter
Group defined by filter. Inherits all methods of SMESH.SMESH_GroupBase
SetFilter(filter)
Set the filter
GetFilter()
Return the filter
SMESH_IDSource
class SMESH.SMESH_IDSource
Base class for classes able to return IDs of mesh entities. These classes are:
GetIDs()
Return a sequence of all element IDs
GetMeshInfo()
GetNbElementsByType()
Return number of mesh elements of each SMESH.ElementType. Use EnumToLong() to get an integer from an item of SMESH.ElementType.
GetTypes()
Return types of elements it contains. It’s empty if the object contains no IDs
Returns:
list of SMESH.ElementType
GetMesh()
SMESH_Hypothesis
class SMESH.SMESH_Hypothesis
Base class of all hypotheses
GetName()
Return string of hypothesis type name, something like “Regular_1D”
GetLibName()
Return string of plugin library name
