Modifying Meshes
Adding Nodes and Elements
Add Node
# Add Node
import salome
salome.salome_init_without_session()
from salome.smesh import smeshBuilder
smesh_builder = smeshBuilder.New()
mesh = smesh_builder.Mesh()
# add node
new_id = mesh.AddNode(50, 10, 0)
print("")
if new_id == 0: print("KO node addition.")
else: print("New Node has been added with ID ", new_id)
Add 0D Element
# Add 0D Element
import salome
# add node
node_id = mesh.AddNode(50, 10, 0)
# add 0D Element
new_id = mesh.Add0DElement(node_id)
print("")
else: print("New 0D Element has been added with ID ", new_id)
Add 0D Element on Element Nodes
# Add 0D Element on Element Nodes
import salome
import SMESH
geom_builder = geomBuilder.New()
# create a geometry
box = geom_builder.MakeBoxDXDYDZ( 10, 10, 10 )
face = geom_builder.SubShapeAll( box, geom_builder.ShapeType["FACE"])[0]
# make 3D mesh
mesh = smesh_builder.Mesh( box )
mesh.AutomaticHexahedralization(0)
# create 0D elements on all nodes of the mesh
res = mesh.Add0DElementsToAllNodes( mesh )
# find 0D elements on all nodes of the mesh, all found nodes are added to a new group
groupName = "0Dmesh"
res = mesh.Add0DElementsToAllNodes( mesh, groupName )
mesh.RemoveGroupWithContents( res ) # remove all found 0D elements
# create 0D elements on all nodes of a sub-mesh, with group creation
groupName = "0Dsubmesh"
submesh = mesh.GetSubMesh( face, "faceSM")
res = mesh.Add0DElementsToAllNodes( submesh, groupName )
# create 0D elements on all nodes of a group
group = mesh.Group( face, "faceGroup" )
res = mesh.Add0DElementsToAllNodes( group )
# remove all 0D elements
mesh.RemoveElements( mesh.GetIdsFromFilter( smesh_builder.GetFilter( SMESH.ELEM0D,
SMESH.FT_ElemGeomType,
"=",SMESH.Geom_POINT )))
# create 0D elements on all nodes of some elements
res = mesh.Add0DElementsToAllNodes( mesh.GetElementsId() )
mesh.RemoveElements( mesh.GetElementsByType( SMESH.ELEM0D ))
# create 0D elements on some nodes
nodes = list(range(1,10))
res = mesh.Add0DElementsToAllNodes( mesh.GetIDSource( nodes, SMESH.NODE ))
Add Edge
# Add Edge
from mechanic import *
# add node
n1 = mesh.AddNode(50, 10, 0)
if n1 == 0: print("KO node addition.")
# add edge
e1 = mesh.AddEdge([n1, 38])
if e1 == 0: print("KO edge addition.")
else: print("New Edge has been added with ID ", e1)
Add Triangle
# Add Triangle
# add node
# add triangle
t1 = mesh.AddFace([n1, 38, 39])
if t1 == 0: print("KO triangle addition.")
else: print("New Triangle has been added with ID ", t1)
Add Quadrangle
# Add Quadrangle
# add node
n2 = mesh.AddNode(40, 20, 0)
if n2 == 0: print("KO node addition.")
# add quadrangle
q1 = mesh.AddFace([n2, n1, 38, 39])
if q1 == 0: print("KO quadrangle addition.")
else: print("New Quadrangle has been added with ID ", q1)
Add Tetrahedron
# Add Tetrahedron
# add node
# add tetrahedron
t1 = mesh.AddVolume([n1, 38, 39, 246])
if t1 == 0: print("KO tetrahedron addition.")
else: print("New Tetrahedron has been added with ID ", t1)
Add Hexahedron
# Add Hexahedron
# add nodes
nId1 = mesh.AddNode(50, 10, 0)
nId2 = mesh.AddNode(47, 12, 0)
nId3 = mesh.AddNode(50, 10, 10)
nId4 = mesh.AddNode(47, 12, 10)
if nId1 == 0 or nId2 == 0 or nId3 == 0 or nId4 == 0: print("KO node addition.")
# add hexahedron
vId = mesh.AddVolume([nId2, nId1, 38, 39, nId4, nId3, 245, 246])
if vId == 0: print("KO Hexahedron addition.")
else: print("New Hexahedron has been added with ID ", vId)
Add Polygon
# Add Polygon
import salome
# create an empty mesh structure
# a method to build a polygonal mesh element with <nb_vert> angles:
def MakePolygon (a_mesh, x0, y0, z0, radius, nb_vert, smesh_builder):
import math
al = 2.0 * math.pi / nb_vert
node_ids = []
# Create nodes for a polygon
for ii in range(nb_vert):
nid = smesh_builder.AddNode(x0 + radius * math.cos(ii*al),
y0 + radius * math.sin(ii*al),
z0)
node_ids.append(nid)
pass
# Create a polygon
return smesh_builder.AddPolygonalFace(node_ids)
# Create three polygons
f1 = MakePolygon(mesh, 0, 0, 0, 30, 13, smesh_builder=mesh)
f2 = MakePolygon(mesh, 0, 0, 10, 21, 9, smesh_builder=mesh)
f3 = MakePolygon(mesh, 0, 0, 20, 13, 6, smesh_builder=mesh)
Add Polyhedron
# Add Polyhedron
import math
import salome
# Create nodes for 12-hedron with pentagonal faces
al = 2 * math.pi / 5.0
cosal = math.cos(al)
aa = 13
rr = aa / (2.0 * math.sin(al/2.0))
dr = 2.0 * rr * cosal
r1 = rr + dr
dh = rr * math.sqrt(2.0 * (1.0 - cosal * (1.0 + 2.0 * cosal)))
hh = 2.0 * dh - dr * (rr*(cosal - 1) + (rr + dr)*(math.cos(al/2) - 1)) / dh
dd = [] # top
cc = [] # below top
bb = [] # above bottom
aa = [] # bottom
for i in range(5):
cos_bot = math.cos(i*al)
sin_bot = math.sin(i*al)
cos_top = math.cos(i*al + al/2.0)
sin_top = math.sin(i*al + al/2.0)
nd = mesh.AddNode(rr * cos_top, rr * sin_top, hh ) # top
nc = mesh.AddNode(r1 * cos_top, r1 * sin_top, hh - dh) # below top
nb = mesh.AddNode(r1 * cos_bot, r1 * sin_bot, dh) # above bottom
na = mesh.AddNode(rr * cos_bot, rr * sin_bot, 0) # bottom
dd.append(nd) # top
cc.append(nc) # below top
bb.append(nb) # above bottom
aa.append(na) # bottom
pass
# Create a polyhedral volume (12-hedron with pentagonal faces)
mesh.AddPolyhedralVolume([dd[0], dd[1], dd[2], dd[3], dd[4], # top
dd[0], cc[0], bb[1], cc[1], dd[1], # -
dd[1], cc[1], bb[2], cc[2], dd[2], # -
dd[2], cc[2], bb[3], cc[3], dd[3], # - below top
dd[3], cc[3], bb[4], cc[4], dd[4], # -
dd[4], cc[4], bb[0], cc[0], dd[0], # -
aa[4], bb[4], cc[4], bb[0], aa[0], # .
aa[3], bb[3], cc[3], bb[4], aa[4], # .
aa[2], bb[2], cc[2], bb[3], aa[3], # . above bottom
aa[1], bb[1], cc[1], bb[2], aa[2], # .
aa[0], bb[0], cc[0], bb[1], aa[1], # .
aa[0], aa[1], aa[2], aa[3], aa[4]], # bottom
[5,5,5,5,5,5,5,5,5,5,5,5])
Removing Nodes and Elements
Removing Nodes
# Removing Nodes
import salome
# create and mesh two boxes
box = geom_builder.MakeBoxDXDYDZ(10.0, 10.0, 10.0)
mesh = smesh_builder.Mesh(box, 'box')
mesh.Segment().NumberOfSegments(10)
mesh.Triangle().MaxElementArea(5)
if not mesh.Compute(): raise Exception("Error when computing Mesh")
print("After Compute(): %s nodes, %s faces" % ( mesh.NbNodes(), mesh.NbFaces()))
# remove nodes #246 and #255
res = mesh.RemoveNodes([246, 255])
print("After RemoveNodes(): %s nodes, %s faces" % ( mesh.NbNodes(), mesh.NbFaces()))
# removing node #100 with reconnection
mesh.RemoveNodeWithReconnection( 100 )
print("After RemoveNodeWithReconnection(): %s nodes, %s faces" % ( mesh.NbNodes(), mesh.NbFaces()))
Removing Elements
# Removing Elements
# remove three elements: #850, #859 and #814
res = mesh.RemoveElements([850, 859, 814])
if res == 1: print("Elements removing is OK!")
else: print("KO Elements removing.")
Removing Orphan Nodes
# Removing Orphan Nodes
# add orphan nodes
mesh.AddNode(0,0,0)
mesh.AddNode(1,1,1)
# remove just created orphan nodes
res = mesh.RemoveOrphanNodes()
if res == 1: print("Removed %d nodes!" % res)
else: print("KO nodes removing.")
Moving Nodes
# Moving Nodes
import salome
box = geom_builder.MakeBoxDXDYDZ(200, 200, 200)
mesh.Segment().AutomaticLength(0.1)
mesh.Quadrangle()
# find node at (0,0,0) which is located on a geom vertex
node000 = None
for vId in geom_builder.SubShapeAllIDs( box, geom_builder.ShapeType["VERTEX"]):
if node000: break
nodeIds = mesh.GetSubMeshNodesId( vId, True )
for node in nodeIds:
xyz = mesh.GetNodeXYZ( node )
if xyz[0] == 0 and xyz[1] == 0 and xyz[2] == 0 :
node000 = node
pass
pass
pass
if not node000:
raise Exception("node000 not found")
# find node000 using a dedicated function
n = mesh.FindNodeClosestTo( -1,-1,-1 )
if not n == node000:
raise Exception("FindNodeClosestTo() returns " + str( n ) + " != " + str( node000 ))
# move node000 to a new location
x,y,z = -10, -10, -10
n = mesh.MoveNode( n,x,y,z )
if not n:
raise Exception("MoveNode() returns " + n)
# check the coordinates of the node000
xyz = mesh.GetNodeXYZ( node000 )
if not ( xyz[0] == x and xyz[1] == y and xyz[2] == z) :
raise Exception("Wrong coordinates: " + str( xyz ) + " != " + str( [x,y,z] ))
Diagonal Inversion
# Diagonal Inversion
import salome
# create the following mesh:
bb = [0, 0, 0, 0]
tt = [0, 0, 0, 0]
ff = [0, 0, 0, 0, 0, 0]
bb[0] = mesh.AddNode( 0., 0., 0.)
bb[1] = mesh.AddNode(10., 0., 0.)
bb[2] = mesh.AddNode(20., 0., 0.)
bb[3] = mesh.AddNode(30., 0., 0.)
tt[0] = mesh.AddNode( 0., 15., 0.)
tt[1] = mesh.AddNode(10., 15., 0.)
tt[2] = mesh.AddNode(20., 15., 0.)
tt[3] = mesh.AddNode(30., 15., 0.)
ff[0] = mesh.AddFace([bb[0], bb[1], tt[1]])
ff[1] = mesh.AddFace([bb[0], tt[1], tt[0]])
ff[2] = mesh.AddFace([bb[1], bb[2], tt[2]])
ff[3] = mesh.AddFace([bb[1], tt[2], tt[1]])
ff[4] = mesh.AddFace([bb[2], bb[3], tt[3]])
ff[5] = mesh.AddFace([bb[2], tt[3], tt[2]])
# inverse the diagonal bb[1] - tt[2]
print("\nDiagonal inversion ... ", end=' ')
res = mesh.InverseDiag(bb[1], tt[2])
if not res: print("failed!")
else: print("done.")
Uniting two Triangles
# Uniting two Triangles
import salome
bb = [0, 0, 0, 0]
tt = [0, 0, 0, 0]
# delete the diagonal bb[1] - tt[2]
print("\nUnite two triangles ... ", end=' ')
res = mesh.DeleteDiag(bb[1], tt[2])
Uniting a Set of Triangles
# Uniting a Set of Triangles
import salome
import SMESH
bb = [0, 0, 0, 0]
tt = [0, 0, 0, 0]
# unite a set of triangles
print("\nUnite a set of triangles ... ", end=' ')
res = mesh.TriToQuad([ff[2], ff[3], ff[4], ff[5]], SMESH.FT_MinimumAngle, 60.)
Orientation
# Orientation
import salome
# build five quadrangles:
dx = 10
dy = 20
n1 = mesh.AddNode(0.0 * dx, 0, 0)
n2 = mesh.AddNode(1.0 * dx, 0, 0)
n3 = mesh.AddNode(2.0 * dx, 0, 0)
n4 = mesh.AddNode(3.0 * dx, 0, 0)
n5 = mesh.AddNode(4.0 * dx, 0, 0)
n6 = mesh.AddNode(5.0 * dx, 0, 0)
n7 = mesh.AddNode(0.0 * dx, dy, 0)
n8 = mesh.AddNode(1.0 * dx, dy, 0)
n9 = mesh.AddNode(2.0 * dx, dy, 0)
n10 = mesh.AddNode(3.0 * dx, dy, 0)
n11 = mesh.AddNode(4.0 * dx, dy, 0)
n12 = mesh.AddNode(5.0 * dx, dy, 0)
f1 = mesh.AddFace([n1, n2, n8 , n7 ])
f2 = mesh.AddFace([n2, n3, n9 , n8 ])
f3 = mesh.AddFace([n3, n4, n10, n9 ])
f4 = mesh.AddFace([n4, n5, n11, n10])
f5 = mesh.AddFace([n5, n6, n12, n11])
# Change the orientation of the second and the fourth faces.
mesh.Reorient([2, 4])
Cutting Quadrangles
# Cutting Quadrangles
# cut two quadrangles: 405 and 406
mesh.QuadToTri([405, 406], SMESH.FT_MinimumAngle)
Cutting Triangles
# Cutting Triangles
import salome
# create 3 triangles and 1 segment all sharing edge 1-2
n1 = mesh.AddNode( 0, 0, 0)
n2 = mesh.AddNode( 0, 0, -10)
n3 = mesh.AddNode( 10, 0, 0)
n4 = mesh.AddNode( 0, 10, 0)
n5 = mesh.AddNode( 0, -10, 0)
mesh.AddFace([ n1, n2, n3])
mesh.AddFace([ n1, n2, n4])
mesh.AddFace([ n1, n2, n5])
mesh.AddEdge([ n1, n2] )
# cut all the triangles and the segment by setting a new node on the segment
mesh.AddNodeOnSegment( n1, n2, 0.6 )
assert mesh.NbNodes() == 6 # one new node created
assert mesh.NbTriangles() == 6 # each of the 3 triangles is split into two
assert mesh.NbEdges() == 2 # a segment is split into two
# cut a triangle into three by adding a new node on the triangle
triangleID = 1
mesh.AddNodeOnFace( triangleID, 2, 0, -6 )
assert mesh.NbNodes() == 7 # one new node created
assert mesh.NbTriangles() == 8 # the triangles is split into three
Split Volumes into Tetrahedra
# Split volumic elements into tetrahedrons
import salome
# mesh a hexahedral mesh
box = geom_builder.MakeBoxDXDYDZ (1, 1, 1 )
print("Nb volumes mesh: %s" % mesh.NbHexas())
# split each hexahedron into 6 tetrahedra
mesh.SplitVolumesIntoTetra( mesh, smesh_builder.Hex_6Tet )
print("Nb volumes mesh: %s" % mesh.NbTetras())
Smoothing
# Smoothing
# select the top face
faces = geom_builder.SubShapeAllSorted(mechanic, geom_builder.ShapeType["FACE"])
# create a group of faces to be smoothed
group_smooth = mesh.GroupOnGeom(faces[3], "Group of faces (smooth)", SMESH.FACE)
# perform smoothing
# boolean SmoothObject(Object, IDsOfFixedNodes, MaxNbOfIterations, MaxAspectRatio, Method)
res0 = mesh.SmoothObject(group_smooth, [], 20, 2., smesh_builder.CENTROIDAL_SMOOTH)
res1 = mesh.SmoothObject(group_smooth, [], 20, 2., smesh_builder.LAPLACIAN_SMOOTH)
print("\nSmoothing ... ", end=' ')
if not (res0 and res1): print("failed!")
Extrusion
# Extrusion
# There is a series of Extrusion Along Line methods added at different times;
# a fully functional method is ExtrusionSweepObjects()
import math
import salome
import SMESH
# add a node
mesh.AddNode( 0.,0.,0. )
# extrude a node into a line of 10 segments along the X axis
ids = mesh.GetNodesId()
stepVector = [1.,0.,0.]
nbSteps = 10
mesh.ExtrusionSweep( ids, stepVector, nbSteps, IsNodes=True )
# create some groups
lastNode = mesh.GetNodesId()[-1]
lastNodeGroup = mesh.MakeGroupByIds( "node %s"% lastNode, SMESH.NODE, [lastNode])
lineGroup = mesh.MakeGroupByIds( "line", SMESH.EDGE, mesh.GetElementsId() )
# rotate the segments around the first node to get a mesh of a disk quarter
axisZ = [0.,0.,0., 0.,0.,1.]
groups = mesh.RotationSweepObject( lineGroup, axisZ, math.pi/2., 10, 1e-3, MakeGroups=True, TotalAngle=True )
# extrude all faces into volumes
obj = mesh
stepVector = [0.,0.,-1.]
nbSteps = 5
groups = mesh.ExtrusionSweepObject2D( obj, stepVector, nbSteps, MakeGroups=True )
# remove all segments created by the last command
for g in groups:
if g.GetType() == SMESH.EDGE:
mesh.RemoveGroupWithContents( g )
# extrude all segments into faces along Z
obj = mesh
stepVector = [0.,0.,1.]
mesh.ExtrusionSweepObject1D( obj, stepVector, nbSteps )
# extrude a group
obj = mesh.GetGroupByName( "line_extruded", SMESH.FACE )[0]
stepVector = [0,-5.,0.]
nbSteps = 1
mesh.ExtrusionSweepObject( obj, stepVector, nbSteps )
# extrude all nodes and triangle faces of the disk quarter, applying a scale factor
diskGroup = mesh.GetGroupByName( "line_rotated", SMESH.FACE )[0]
crit = [ smesh_builder.GetCriterion( SMESH.FACE, SMESH.FT_ElemGeomType,'=',SMESH.Geom_TRIANGLE ),
smesh_builder.GetCriterion( SMESH.FACE, SMESH.FT_BelongToMeshGroup,'=', diskGroup )]
trianglesFilter = smesh_builder.GetFilterFromCriteria( crit )
nodes = [ diskGroup ]
edges = []
faces = [ trianglesFilter ]
stepVector = [0,0,1]
nbSteps = 10
mesh.ExtrusionSweepObjects( nodes, edges, faces, stepVector, nbSteps, scaleFactors=[0.5], linearVariation=True )
# extrude a cylindrical group of faces by normal
cylGroup = None
for g in mesh.GetGroups( SMESH.FACE ):
if g.GetName().startswith("node "):
cylGroup = g
break
elements = cylGroup
stepSize = 5.
nbSteps = 2
mesh.ExtrusionByNormal( elements, stepSize, nbSteps )
Extrusion along a Path
# Extrusion along a Path
import math
import salome
import SMESH
# 1. Create points
points = [[0, 0], [50, 30], [50, 110], [0, 150], [-80, 150], [-130, 70], [-130, -20]]
iv = 1
vertices = []
for point in points:
vert = geom_builder.MakeVertex(point[0], point[1], 0)
vertices.append(vert)
iv += 1
# 2. Create edges and wires
Edge_straight = geom_builder.MakeEdge(vertices[0], vertices[4])
Edge_bezierrr = geom_builder.MakeBezier(vertices)
Wire_polyline = geom_builder.MakePolyline(vertices)
Edge_Circle = geom_builder.MakeCircleThreePnt(vertices[0], vertices[1], vertices[2])
geom_builder.addToStudy(Edge_straight, "Edge_straight")
geom_builder.addToStudy(Edge_bezierrr, "Edge_bezierrr")
geom_builder.addToStudy(Wire_polyline, "Wire_polyline")
geom_builder.addToStudy(Edge_Circle , "Edge_Circle")
# 3. Explode wire on edges, as they will be used for mesh extrusion
Wire_polyline_edges = geom_builder.SubShapeAll(Wire_polyline, geom_builder.ShapeType["EDGE"])
for ii in range(len(Wire_polyline_edges)):
geom_builder.addToStudyInFather(Wire_polyline, Wire_polyline_edges[ii], "Edge_" + repr(ii + 1))
# Mesh
# Mesh the given shape with the given 1d hypothesis
def Mesh1D(shape1d, nbSeg, name):
mesh1d_tool = smesh_builder.Mesh(shape1d, name)
algo = mesh1d_tool.Segment()
hyp = algo.NumberOfSegments(nbSeg)
isDone = mesh1d_tool.Compute()
if not isDone: raise Exception('Mesh %s: computation failed' % name)
return mesh1d_tool
# Create a mesh with six nodes, seven edges and two quadrangle faces
def MakeQuadMesh2(mesh_name):
quad_1 = smesh_builder.Mesh(name = mesh_name)
# six nodes
n1 = quad_1.AddNode(0, 20, 10)
n2 = quad_1.AddNode(0, 40, 10)
n3 = quad_1.AddNode(0, 40, 30)
n4 = quad_1.AddNode(0, 20, 30)
n5 = quad_1.AddNode(0, 0, 30)
n6 = quad_1.AddNode(0, 0, 10)
# seven edges
quad_1.AddEdge([n1, n2]) # 1
quad_1.AddEdge([n2, n3]) # 2
quad_1.AddEdge([n3, n4]) # 3
quad_1.AddEdge([n4, n1]) # 4
quad_1.AddEdge([n4, n5]) # 5
quad_1.AddEdge([n5, n6]) # 6
quad_1.AddEdge([n6, n1]) # 7
# two quadrangle faces
quad_1.AddFace([n1, n2, n3, n4]) # 8
quad_1.AddFace([n1, n4, n5, n6]) # 9
return [quad_1, [1,2,3,4,5,6,7], [8,9]]
# Path meshes
Edge_straight_mesh = Mesh1D(Edge_straight, 7, "Edge_straight")
Edge_bezierrr_mesh = Mesh1D(Edge_bezierrr, 7, "Edge_bezierrr")
Wire_polyline_mesh = Mesh1D(Wire_polyline, 3, "Wire_polyline")
Edge_Circle_mesh = Mesh1D(Edge_Circle , 8, "Edge_Circle")
# Initial meshes (to be extruded)
[quad_1, ee_1, ff_1] = MakeQuadMesh2("quad_1")
[quad_2, ee_2, ff_2] = MakeQuadMesh2("quad_2")
[quad_3, ee_3, ff_3] = MakeQuadMesh2("quad_3")
[quad_4, ee_4, ff_4] = MakeQuadMesh2("quad_4")
[quad_5, ee_5, ff_5] = MakeQuadMesh2("quad_5")
[quad_6, ee_6, ff_6] = MakeQuadMesh2("quad_6")
[quad_7, ee_7, ff_7] = MakeQuadMesh2("quad_7")
# ExtrusionAlongPath
# IDsOfElements, PathMesh, PathShape, NodeStart,
# HasAngles, Angles, HasRefPoint, RefPoint
refPoint = SMESH.PointStruct(0, 0, 0)
a10 = math.radians( 10.0 )
a45 = math.radians( 45.0 )
# 1. Extrusion of two mesh edges along a straight path
error = quad_1.ExtrusionAlongPath([1,2], Edge_straight_mesh, Edge_straight, 1,
0, [], 0, refPoint)
# 2. Extrusion of one mesh edge along a curved path
error = quad_2.ExtrusionAlongPath([2], Edge_bezierrr_mesh, Edge_bezierrr, 1,
0, [], 0, refPoint)
# 3. Extrusion of one mesh edge along a curved path with usage of angles
error = quad_3.ExtrusionAlongPath([2], Edge_bezierrr_mesh, Edge_bezierrr, 1,
1, [a45, a45, a45, 0, -a45, -a45, -a45], 0, refPoint)
# 4. Extrusion of one mesh edge along the path, which is a part of a meshed wire
error = quad_4.ExtrusionAlongPath([4], Wire_polyline_mesh, Wire_polyline_edges[0], 1,
1, [a10, a10, a10], 0, refPoint)
# 5. Extrusion of two mesh faces along the path, which is a part of a meshed wire
error = quad_5.ExtrusionAlongPath(ff_5 , Wire_polyline_mesh, Wire_polyline_edges[2], 4,
0, [], 0, refPoint)
# 6. Extrusion of two mesh faces along a closed path
error = quad_6.ExtrusionAlongPath(ff_6 , Edge_Circle_mesh, Edge_Circle, 1,
0, [], 0, refPoint)
# 7. Extrusion of two mesh faces along a closed path with usage of angles
error = quad_7.ExtrusionAlongPath(ff_7, Edge_Circle_mesh, Edge_Circle, 1,
1, [a45, -a45, a45, -a45, a45, -a45, a45, -a45], 0, refPoint)
# Make the same meshes using a fully functional method ExtrusionAlongPathObjects() having
# the following arguments:
# Nodes, Edges, Faces, PathObject, PathShape=None,
# NodeStart=1, HasAngles=False, Angles=[], LinearVariation=False,
# HasRefPoint=False, RefPoint=[0,0,0], MakeGroups=False,
# ScaleFactors=[], ScalesVariation=False
quad_1 = MakeQuadMesh2("quad_1")[0]
quad_2 = MakeQuadMesh2("quad_2")[0]
quad_3 = MakeQuadMesh2("quad_3")[0]
quad_4 = MakeQuadMesh2("quad_4")[0]
quad_5 = MakeQuadMesh2("quad_5")[0]
quad_6 = MakeQuadMesh2("quad_6")[0]
quad_7 = MakeQuadMesh2("quad_7")[0]
nn, ee, ff = [], [1,2], []
error = quad_1.ExtrusionAlongPathObjects( nn, ee, ff, Edge_straight_mesh )
nn, ee, ff = [], [2], []
error = quad_2.ExtrusionAlongPathObjects( nn, ee, ff, Edge_bezierrr_mesh )
error = quad_3.ExtrusionAlongPathObjects( nn, ee, ff, Edge_bezierrr_mesh,
Angles=[a45, a45, a45, 0, -a45, -a45, -a45])
nn, ee, ff = [], [4], []
error = quad_4.ExtrusionAlongPathObjects( nn, ee, ff, Wire_polyline_mesh, Wire_polyline_edges[0],
Angles=[a10, a10, a10])
nn, ee, ff = [], [], quad_5
error = quad_5.ExtrusionAlongPathObjects( nn, ee, ff, Wire_polyline_mesh, Wire_polyline_edges[2],
NodeStart=4 )
nn, ee, ff = [], [], quad_6
error = quad_6.ExtrusionAlongPathObjects( nn, ee, ff, Edge_Circle_mesh )
nn, ee, ff = [], [], quad_7
error = quad_7.ExtrusionAlongPathObjects( nn, ee, ff, Edge_Circle_mesh, Edge_Circle,
Angles=[a45, -a45, a45, -a45, a45, -a45, a45, -a45])
Revolution
# Revolution
import math
# create a group of faces to be revolved
FacesRotate = [492, 493, 502, 503]
GroupRotate = mesh.CreateEmptyGroup(SMESH.FACE,"Group of faces (rotate)")
GroupRotate.Add(FacesRotate)
# define revolution angle and axis
angle45 = 45 * math.pi / 180
axisXYZ = SMESH.AxisStruct(-38.3128, -73.3658, -23.321, -13.3402, -13.3265, 6.66632)
# perform revolution of an object
mesh.RotationSweepObject(GroupRotate, axisXYZ, angle45, 4, 1e-5)
Pattern Mapping
# Pattern Mapping
import salome
import SMESH
# define the geometry
Box_1 = geom_builder.MakeBoxDXDYDZ(200., 200., 200.)
geom_builder.addToStudy(Box_1, "Box_1")
faces = geom_builder.SubShapeAll(Box_1, geom_builder.ShapeType["FACE"])
Face_1 = faces[0]
Face_2 = faces[1]
geom_builder.addToStudyInFather(Box_1, Face_1, "Face_1")
geom_builder.addToStudyInFather(Box_1, Face_2, "Face_2")
# build a quadrangle mesh 3x3 on Face_1
Mesh_1 = smesh_builder.Mesh(Face_1)
algo1D = Mesh_1.Segment()
algo1D.NumberOfSegments(3)
Mesh_1.Quadrangle()
isDone = Mesh_1.Compute()
if not isDone: raise Exception('Mesh Mesh_1 : computation failed')
# build a triangle mesh on Face_2
Mesh_2 = smesh_builder.Mesh(Face_2)
algo1D = Mesh_2.Segment()
algo1D.NumberOfSegments(1)
algo2D = Mesh_2.Triangle()
algo2D.MaxElementArea(240)
isDone = Mesh_2.Compute()
if not isDone: raise Exception('Mesh Mesh_2 : computation failed')
# create a 2d pattern
pattern = smesh_builder.GetPattern()
isDone = pattern.LoadFromFace(Mesh_2.GetMesh(), Face_2, 0)
if (isDone != 1): print('LoadFromFace :', pattern.GetErrorCode())
# apply the pattern to a face of the first mesh
facesToSplit = Mesh_1.GetElementsByType(SMESH.FACE)
print("Splitting %d rectangular face(s) to %d triangles..."%(len(facesToSplit), 2*len(facesToSplit)))
pattern.ApplyToMeshFaces(Mesh_1.GetMesh(), facesToSplit, 0, 0)
isDone = pattern.MakeMesh(Mesh_1.GetMesh(), 0, 0)
if (isDone != 1): print('MakeMesh :', pattern.GetErrorCode())
# create quadrangle mesh
Mesh_3 = smesh_builder.Mesh(Box_1)
Mesh_3.Segment().NumberOfSegments(1)
Mesh_3.Quadrangle()
Mesh_3.Hexahedron()
isDone = Mesh_3.Compute()
if not isDone: raise Exception('Mesh Mesh_3 : computation failed')
# create a 3d pattern (hexahedrons)
pattern_hexa = smesh_builder.GetPattern()
smp_hexa = """!!! Nb of points:
15
0 0 0 !- 0
1 0 0 !- 1
0 1 0 !- 2
1 1 0 !- 3
0 0 1 !- 4
1 0 1 !- 5
0 1 1 !- 6
1 1 1 !- 7
0.5 0 0.5 !- 8
0.5 0 1 !- 9
0.5 0.5 0.5 !- 10
0.5 0.5 1 !- 11
1 0 0.5 !- 12
1 0.5 0.5 !- 13
1 0.5 1 !- 14
!!! Indices of points of 4 elements:
8 12 5 9 10 13 14 11
0 8 9 4 2 10 11 6
2 10 11 6 3 13 14 7
0 1 12 8 2 3 13 10"""
pattern_hexa.LoadFromFile(smp_hexa)
# apply the pattern to a mesh
volsToSplit = Mesh_3.GetElementsByType(SMESH.VOLUME)
print("Splitting %d hexa volume(s) to %d hexas..."%(len(volsToSplit), 4*len(volsToSplit)))
pattern_hexa.ApplyToHexahedrons(Mesh_3.GetMesh(), volsToSplit,0,3)
isDone = pattern_hexa.MakeMesh(Mesh_3.GetMesh(), True, True)
if (isDone != 1): print('MakeMesh :', pattern_hexa.GetErrorCode())
# create one more quadrangle mesh
Mesh_4 = smesh_builder.Mesh(Box_1)
Mesh_4.Segment().NumberOfSegments(1)
Mesh_4.Quadrangle()
Mesh_4.Hexahedron()
isDone = Mesh_4.Compute()
if not isDone: raise Exception('Mesh Mesh_4 : computation failed')
# create another 3d pattern (pyramids)
pattern_pyra = smesh_builder.GetPattern()
smp_pyra = """!!! Nb of points:
9
0 0 0 !- 0
1 0 0 !- 1
0 1 0 !- 2
1 1 0 !- 3
0 0 1 !- 4
1 0 1 !- 5
0 1 1 !- 6
1 1 1 !- 7
0.5 0.5 0.5 !- 8
!!! Indices of points of 6 elements:
0 1 5 4 8
7 5 1 3 8
3 2 6 7 8
2 0 4 6 8
0 2 3 1 8
4 5 7 6 8"""
pattern_pyra.LoadFromFile(smp_pyra)
# apply the pattern to a face mesh
volsToSplit = Mesh_4.GetElementsByType(SMESH.VOLUME)
print("Splitting %d hexa volume(s) to %d hexas..."%(len(volsToSplit), 6*len(volsToSplit)))
pattern_pyra.ApplyToHexahedrons(Mesh_4.GetMesh(), volsToSplit,1,0)
isDone = pattern_pyra.MakeMesh(Mesh_4.GetMesh(), True, True)
if (isDone != 1): print('MakeMesh :', pattern_pyra.GetErrorCode())
Convert mesh to/from quadratic
# Convert mesh to/from quadratic
import salome
# create sphere of radius 100
Sphere = geom_builder.MakeSphereR( 100 )
geom_builder.addToStudy( Sphere, "Sphere" )
# create simple tetrahedral mesh
Mesh = smesh_builder.Mesh(Sphere)
Mesh.Segment().NumberOfSegments(5)
Mesh.Triangle()
Mesh.Tetrahedron()
# compute mesh
if not Mesh.Compute(): raise Exception("Error when computing Mesh")
# convert to quadratic
# theForce3d = 1; this results in the medium node lying at the
# middle of the line segments connecting start and end node of a mesh
# element
Mesh.ConvertToQuadratic( theForce3d=1 )
# revert back to the non-quadratic mesh
Mesh.ConvertFromQuadratic()
# theForce3d = 0; this results in the medium node lying at the
# geometrical edge from which the mesh element is built
Mesh.ConvertToQuadratic( theForce3d=0 )
# to convert not the whole mesh but a sub-mesh, provide it as
# an additional argument to the functions:
# Mesh.ConvertToQuadratic( 0, subMesh )
# Mesh.ConvertFromQuadratic( subMesh )
# Note that the mesh becomes non-conformal at conversion of sub-mesh.
Split bi-quadratic into linear
# Split bi-quadratic to linear
import salome
# make a shape consisting of two quadranges
OY = geom_builder.MakeVectorDXDYDZ(0, 1, 0)
OY1 = geom_builder.MakeTranslation( OY, 1, 0, 0 )
OY2 = geom_builder.MakeTranslation( OY, 2, 0, 0 )
q1 = geom_builder.MakeQuad2Edges( OY, OY1 )
q2 = geom_builder.MakeQuad2Edges( OY1, OY2 )
shape = geom_builder.Partition( [q1,q2], theName='shape' )
ff = geom_builder.SubShapeAll( shape, geom_builder.ShapeType["FACE"], theName="quad" )
# mesh one quadrange with quadrangless and the other with triangles
mesh = smesh_builder.Mesh( shape )
mesh.Segment().NumberOfSegments(1)
mesh.Quadrangle()
mesh.Triangle( ff[1] )
# make group of quadrangles and extrude them into a hexahedron
quadGroup = mesh.Group( ff[0], "quads")
mesh.ExtrusionSweepObject2D( quadGroup, [0,0,1], 1 )
# make the mesh bi-quadratic
mesh.ConvertToQuadratic( theToBiQuad=True )
# split all elements into linear ones
mesh.SplitBiQuadraticIntoLinear()
Double nodes on groups boundaries
Double nodes on shared faces between groups of volumes and create flat elements on demand.
The list of groups must contain at least two groups. The groups have to be disjoint: no common element into two different groups.
The nodes of the internal faces at the boundaries of the groups are doubled. Optionally, the internal faces are replaced by flat elements.
Triangles are transformed into prisms, and quadrangles into hexahedrons.
The flat elements are stored in groups of volumes.
These groups are named according to the position of the group in the list: the group j_n_p is the group of the flat elements that are built between the group #n and the group #p in the list. If there is no shared faces between the group #n and the group #p in the list, the group j_n_p is not created. All the flat elements are gathered into the group named “joints3D” (or “joints2D” in 2D situation). The flat element of the multiple junctions between the simple junction are stored in a group named “jointsMultiples”.
This example represents an iron cable (a thin cylinder) in a concrete block (a big cylinder). The big cylinder is defined by two geometric volumes.
# Double nodes on groups boundaries
# This example represents an iron cable (a thin cylinder) in a concrete block (a big cylinder).
# The big cylinder is defined by two geometric volumes.
import salome
import GEOM
import SMESH
# geometry
O = geom_builder.MakeVertex(0, 0, 0)
OX = geom_builder.MakeVectorDXDYDZ(1, 0, 0)
OZ = geom_builder.MakeVectorDXDYDZ(0, 0, 1)
Vertex_1 = geom_builder.MakeVertex(50, 0, 0)
Cylinder_1 = geom_builder.MakeCylinder(O, OX, 10, 500)
Cylinder_2 = geom_builder.MakeCylinder(Vertex_1, OX, 100, 400)
Vertex_2 = geom_builder.MakeVertex(-200, -200, -200)
Vertex_3 = geom_builder.MakeVertex(250, 200, 200)
Box_1 = geom_builder.MakeBoxTwoPnt(Vertex_2, Vertex_3)
Fuse_1 = geom_builder.MakeFuse(Cylinder_1, Cylinder_2)
Partition_1 = geom_builder.MakePartition([Fuse_1], [Cylinder_1, Box_1], [], [], geom_builder.ShapeType["SOLID"], 0, [], 0)
[Solid_1,Solid_2] = geom_builder.GetShapesOnShape(Cylinder_1, Partition_1, geom_builder.ShapeType["SOLID"], GEOM.ST_IN)
[Solid_3,Solid_4] = geom_builder.GetShapesOnShape(Cylinder_2, Partition_1, geom_builder.ShapeType["SOLID"], GEOM.ST_IN)
Vertex_4 = geom_builder.MakeVertex(450, 0, 0)
Vertex_5 = geom_builder.MakeVertex(500, 0, 0)
Vertex_6 = geom_builder.MakeVertex(550, 0, 0)
vec1 = geom_builder.MakeVector(Vertex_4, Vertex_5)
vec2 = geom_builder.MakeVector(Vertex_5, Vertex_6)
[Face_1] = geom_builder.GetShapesOnPlane(Partition_1, geom_builder.ShapeType["FACE"], vec1, GEOM.ST_ON)
[Face_2] = geom_builder.GetShapesOnPlane(Partition_1, geom_builder.ShapeType["FACE"], vec2, GEOM.ST_ON)
# meshing (we have linear tetrahedrons here, but other elements are OK)
Mesh_1 = smesh_builder.Mesh(Partition_1)
Mesh_1.Segment().NumberOfSegments(15)
Mesh_1.Triangle().LengthFromEdges()
Mesh_1.Tetrahedron()
if not Mesh_1.Compute(): raise Exception("Error when computing Mesh")
# relevant groups of volumes and faces
Solid_1_1 = Mesh_1.GroupOnGeom(Solid_1,'Solid_1',SMESH.VOLUME)
Solid_2_1 = Mesh_1.GroupOnGeom(Solid_2,'Solid_2',SMESH.VOLUME)
Solid_3_1 = Mesh_1.GroupOnGeom(Solid_3,'Solid_3',SMESH.VOLUME)
Solid_4_1 = Mesh_1.GroupOnGeom(Solid_4,'Solid_4',SMESH.VOLUME)
Face_1_1 = Mesh_1.GroupOnGeom(Face_1,'Face_1',SMESH.FACE)
Face_2_1 = Mesh_1.GroupOnGeom(Face_2,'Face_2',SMESH.FACE)
# Building of flat elements
Mesh_1.DoubleNodesOnGroupBoundaries([Solid_1_1, Solid_2_1, Solid_3_1, Solid_4_1], 1)
Mesh_1.CreateFlatElementsOnFacesGroups([Face_1_1, Face_2_1])
Here, the 4 groups of volumes [Solid_1_1, Solid_2_1, Solid_3_1, Solid_4_1] constitute a partition of the mesh. The flat elements on group boundaries and on faces are built with the 2 last lines of the code above.
If the last argument (Boolean) in DoubleNodesOnGroupBoundaries is set to 1, the flat elements are built, otherwise, there is only a duplication of the nodes.
To observe flat element groups, save the resulting mesh on a MED file and reload it.
