GEOM::GEOM_BoolFieldStep Interface Reference
Interface of the boolean field time step.
import"GEOM_Gen.idl";
Inheritance diagram for GEOM::GEOM_BoolFieldStep:
boolean SetValues (in short_array boolValues)
 Changes values of the field step. Returns false if number of values is wrong. More...
short_array GetValues ()
 Returns values of the field step. More...
- Public Member Functions inherited from GEOM::GEOM_FieldStep
void SetStamp (in long stamp)
 Changes the time of the field step. More...
long GetStamp ()
 Returns the time of the field step. More...
long GetID ()
 Returns the number of the field step. More...
GEOM_Field GetField ()
 Returns the field the step belongs to. More...
- Public Member Functions inherited from GEOM::GEOM_BaseObject
void SetName (in string theName)
 Set name of the object. More...
string GetName ()
 Get name of the object associated with this object. More...
string GetEntry ()
 Get internal (unique) entry of the object in the GEOM component's data tree. More...
long GetType ()
 Get internal type of operation created this object (POINT, BOX, CYLINDER, EXTRUSION...). More...
long GetTick ()
 Get value of a modification counter of the object. More...
void SetStudyEntry (in string theEntry)
 Set a Study entry where this object was published. More...
string GetStudyEntry ()
 Get a Study entry where this object was published. More...
ListOfGBO GetDependency ()
 Get a list of all GEOM_Object on which were the arguments when this object was constructed and modified. More...
ListOfGBO GetLastDependency ()
 Get a list of GEOM_Object on which the last function that created or modified the object depends. More...
boolean IsShape ()
boolean IsSame (in GEOM_BaseObject other)
void SetParameters (in string theParameters)
string GetParameters ()
 Return list of notebook variables used for object creation separated by ":" symbol. More...
CreationInformationSeq GetCreationInformation ()
 Return name of operation and values of parameters used for object creation. More...
GEOM_Gen GetGen ()
 Return the engine creating this object. More...
◆ GetValues()
short_array GEOM::GEOM_BoolFieldStep::GetValues ( )
◆ SetValues()
boolean GEOM::GEOM_BoolFieldStep::SetValues ( in short_array  boolValues)
The documentation for this interface was generated from the following file:
