Interface of the double field time step.
import"GEOM_Gen.idl";
| boolean | SetValues (in ListOfDouble doubleValues) |
| Changes values of the field step. Returns false if number of values is wrong. More... | |
| ListOfDouble | GetValues () |
| Returns values of the field step. More... | |
Public Member Functions inherited from GEOM::GEOM_FieldStep | |
| void | SetStamp (in long stamp) |
| Changes the time of the field step. More... | |
| long | GetStamp () |
| Returns the time of the field step. More... | |
| long | GetID () |
| Returns the number of the field step. More... | |
| GEOM_Field | GetField () |
| Returns the field the step belongs to. More... | |
Public Member Functions inherited from GEOM::GEOM_BaseObject | |
| void | SetName (in string theName) |
| Set name of the object. More... | |
| string | GetName () |
| Get name of the object associated with this object. More... | |
| string | GetEntry () |
| Get internal (unique) entry of the object in the GEOM component's data tree. More... | |
| long | GetType () |
| Get internal type of operation created this object (POINT, BOX, CYLINDER, EXTRUSION...). More... | |
| long | GetTick () |
| Get value of a modification counter of the object. More... | |
| void | SetStudyEntry (in string theEntry) |
| Set a Study entry where this object was published. More... | |
| string | GetStudyEntry () |
| Get a Study entry where this object was published. More... | |
| ListOfGBO | GetDependency () |
| Get a list of all GEOM_Object on which were the arguments when this object was constructed and modified. More... | |
| ListOfGBO | GetLastDependency () |
| Get a list of GEOM_Object on which the last function that created or modified the object depends. More... | |
| boolean | IsShape () |
| boolean | IsSame (in GEOM_BaseObject other) |
| void | SetParameters (in string theParameters) |
| string | GetParameters () |
| Return list of notebook variables used for object creation separated by ":" symbol. More... | |
| CreationInformationSeq | GetCreationInformation () |
| Return name of operation and values of parameters used for object creation. More... | |
| GEOM_Gen | GetGen () |
| Return the engine creating this object. More... | |
| ListOfDouble GEOM::GEOM_DoubleFieldStep::GetValues | ( | ) |
| boolean GEOM::GEOM_DoubleFieldStep::SetValues | ( | in ListOfDouble | doubleValues | ) |
