STD_TabDesktop Class Reference
#include <STD_TabDesktop.h>
Inheritance diagram for STD_TabDesktop:
enum  { SplitVertical , SplitHorizontal }
 STD_TabDesktop ()
virtual ~STD_TabDesktop ()
virtual SUIT_ViewWindow * activeWindow () const
virtual void setActiveWindow (SUIT_ViewWindow *)
virtual QList< SUIT_ViewWindow * > windows () const
void windowOperation (const int)
void setWindowOperations (const int,...)
void setWindowOperations (const QList< int > &)
QtxWorkstack * workstack () const
- Public Member Functions inherited from SUIT_Desktop
 SUIT_Desktop ()
virtual ~SUIT_Desktop ()
QtxActionMenuMgr * menuMgr () const
QtxActionToolMgr * toolMgr () const
QtxLogoMgr * logoMgr () const
virtual SUIT_ViewWindow * activeWindow () const =0
virtual QList< SUIT_ViewWindow * > windows () const =0
int logoCount () const
void logoClear ()
void logoRemove (const QString &)
void logoInsert (const QString &, QMovie *, const int=-1)
void logoInsert (const QString &, const QPixmap &, const int=-1)
void emitActivated ()
void emitMessage (const QString &)
- Public Member Functions inherited from QtxMainWindow
 QtxMainWindow (QWidget *=0, Qt::WindowFlags=0)
virtual ~QtxMainWindow ()
bool isOpaqueResize () const
void setOpaqueResize (bool)
bool isDockableMenuBar () const
 Check if the menu bar is dockable. More...
void setDockableMenuBar (const bool)
 Set menu bar dockable/undockable. More...
bool isDockableStatusBar () const
 Check if the status bar is dockable. More...
void setDockableStatusBar (const bool)
 Set status bar dockable/undockable. More...
QString storeGeometry () const
 Dump main window geometry to the string. More...
void retrieveGeometry (const QString &)
 Restore main window geometry from the string. More...
bool isFullScreenAllowed () const
 FullScreenAllowed flag allowed dump in the main window geometry Qt::WindowFullScreen parameter. More...
void setFullScreenAllowed (const bool)
 Set FullScreenAllowed flag. The default value is true. More...
bool isMinimizeAllowed () const
 MinimizeAllowed flag allowed dump in the main window geometry Qt::WindowMinimized parameter. More...
void setMinimizeAllowed (const bool)
 Set MinimizeAllowed flag. The default value is true. More...
void createActions ()
virtual void addWindow (QWidget *)
- Protected Member Functions inherited from SUIT_Desktop
virtual bool event (QEvent *)
virtual void customEvent (QEvent *)
virtual void closeEvent (QCloseEvent *)
virtual void childEvent (QChildEvent *)
virtual void addWindow (QWidget *)=0
Private Slots
void onWindowActivated (QWidget *)
void onArrangeViews ()
int operationFlag (const int) const
QtxWorkstack * myWorkstack
QtxWorkstackAction * myWorkstackAction
- Signals inherited from SUIT_Desktop
void activated ()
void deactivated ()
void windowActivated (SUIT_ViewWindow *)
void closing (SUIT_Desktop *, QCloseEvent *)
void message (const QString &)
◆ anonymous enum
anonymous enum
SplitVertical
SplitHorizontal
◆ STD_TabDesktop()
◆ ~STD_TabDesktop()
STD_TabDesktop::~STD_TabDesktop ( )
◆ activeWindow()
SUIT_ViewWindow * STD_TabDesktop::activeWindow ( ) const
SUIT_ViewWindow- return const active window.
Implements SUIT_Desktop.
References QtxWorkstack::activeWindow(), and myWorkstack.
◆ addWindow()
void STD_TabDesktop::addWindow ( QWidget *  w)
Insert new widget into desktop.
References QtxWorkstack::addWindow(), and workstack().
◆ createActions()
◆ onArrangeViews
void STD_TabDesktop::onArrangeViews ( )
privateslot
Emit Arrange Views menu activated.
References ArrangeViews, and workstack().
◆ onWindowActivated
void STD_TabDesktop::onWindowActivated ( QWidget *  w)
privateslot
Emit window activated.
References SUIT_Desktop::windowActivated().
◆ operationFlag()
int STD_TabDesktop::operationFlag ( const int  type) const
◆ setActiveWindow()
void STD_TabDesktop::setActiveWindow ( SUIT_ViewWindow *  wnd)
Set active window
wnd- view window
Reimplemented from SUIT_Desktop.
References myWorkstack, and QtxWorkstack::setActiveWindow().
◆ setWindowOperations() [1/2]
void STD_TabDesktop::setWindowOperations ( const int  first,
Sets window operations by first ... parameters.
References setWindowOperations().
◆ setWindowOperations() [2/2]
void STD_TabDesktop::setWindowOperations ( const QList< int > &  opList)
Sets window operations by variable opList - operation list.
References operationFlag().
◆ windowOperation()
void STD_TabDesktop::windowOperation ( const int  type)
Call method perform for operation type.
References myWorkstackAction, operationFlag(), and QtxWorkstackAction::perform().
◆ windows()
QList< SUIT_ViewWindow * > STD_TabDesktop::windows ( ) const
QPtrList<SUIT_ViewWindow>- return const active window list.
References myWorkstack, and QtxWorkstack::windowList().
◆ workstack()
QtxWorkstack * STD_TabDesktop::workstack ( ) const
QtxWorkstackpointer - Qt work stack.
References myWorkstack.
◆ myWorkstack
QtxWorkstack* STD_TabDesktop::myWorkstack
◆ myWorkstackAction
QtxWorkstackAction* STD_TabDesktop::myWorkstackAction
