VTKViewer_InteractorStyle Class Reference
#include <VTKViewer_InteractorStyle.h>
Inheritance diagram for VTKViewer_InteractorStyle:
 vtkTypeMacro (VTKViewer_InteractorStyle, vtkInteractorStyle) virtual void SetInteractor(vtkRenderWindowInteractor *theInteractor)
void setViewWnd (VTKViewer_ViewWindow *theViewWnd)
void setGUIWindow (QWidget *theWindow)
void setTriedron (VTKViewer_Trihedron *theTrihedron)
void setPreselectionProp (const double &theRed=0, const double &theGreen=1, const double &theBlue=1, const int &theWidth=5)
void OnMouseMove (int ctrl, int shift, int x, int y)
void OnLeftButtonDown (int ctrl, int shift, int x, int y)
void OnLeftButtonUp (int ctrl, int shift, int x, int y)
void OnMiddleButtonDown (int ctrl, int shift, int x, int y)
void OnMiddleButtonUp (int ctrl, int shift, int x, int y)
void OnRightButtonDown (int ctrl, int shift, int x, int y)
void OnRightButtonUp (int ctrl, int shift, int x, int y)
 Handle (VTKViewer_Filter) GetFilter(const int)
int CurrentState () const
void SetTDxStyle (vtkTDxInteractorStyle *)
static VTKViewer_InteractorStyle * New ()
 VTKViewer_InteractorStyle ()
 ~VTKViewer_InteractorStyle ()
 VTKViewer_InteractorStyle (const VTKViewer_InteractorStyle &)
void operator= (const VTKViewer_InteractorStyle &)
void RotateXY (int dx, int dy)
void PanXY (int x, int y, int oldX, int oldY)
void DollyXY (int dx, int dy)
void SpinXY (int dx, int dy, int oldX, int oldY)
int State
double MotionFactor
double RadianToDegree
double myScale
VTKViewer_Actor * myPreViewActor
VTKViewer_Actor * myPreSelectionActor
VTKViewer_Actor * mySelectedActor
vtkIdType myElemId
int myEdgeId
vtkIdType myNodeId
QCursor myDefCursor
QCursor myPanCursor
QCursor myZoomCursor
QCursor myRotateCursor
QCursor mySpinCursor
QCursor myHandCursor
QCursor myGlobalPanCursor
QPoint myPoint
QPoint myOtherPoint
bool myCursorState
bool myShiftState
int ForcedState
VTKViewer_RenderWindowInteractor * m_Interactor
VTKViewer_ViewWindow * m_ViewWnd
VTKViewer_Trihedron * m_Trihedron
QWidget * myGUIWindow
std::map< int, Handle(VTKViewer_Filter) > myFilters
QRubberBand * myRectBand
 selection rectangle rubber band More...
members from old version
double DeltaElevation
double DeltaAzimuth
int LastPos [2]
XPM - x pixmaps.
void OnSelectionModeChanged ()
void ViewFitAll ()
void ViewFitSelection ()
void SetFilter (const Handle(VTKViewer_Filter)&)
bool IsFilterPresent (const int)
void RemoveFilter (const int)
bool IsValid (VTKViewer_Actor *theActor, const vtkIdType theId, const bool theIsNode=false)
void IncrementalPan (const int incrX, const int incrY)
void IncrementalZoom (const int incr)
void IncrementalRotate (const int incrX, const int incrY)
bool eventFilter (QObject *object, QEvent *event)
void startZoom ()
void startPan ()
void startGlobalPan ()
void startRotate ()
void startFitArea ()
void startSpin ()
bool needsRedrawing ()
void fitRect (const int left, const int top, const int right, const int bottom)
void Place (const int theX, const int theY)
void TranslateView (int toX, int toY, int fromX, int fromY)
bool IsInRect (vtkActor *theActor, const int left, const int top, const int right, const int bottom)
bool IsInRect (vtkCell *theCell, const int left, const int top, const int right, const int bottom)
bool IsInRect (double *thePoint, const int left, const int top, const int right, const int bottom)
void loadCursors ()
void startOperation (int operation)
virtual void onStartOperation ()
virtual void onFinishOperation ()
virtual void onOperation (QPoint mousePos)
virtual void onCursorMove (QPoint)
virtual void setCursor (const int operation)
void drawRect ()
void endDrawRect ()
 Delete rubber band on the end on the dragging operation. More...
Description:
This class must be supplied with a vtkRenderWindowInteractor wrapper or
parent. This class should not normally be instantiated by application
programmers.
◆ VTKViewer_InteractorStyle() [1/2]
VTKViewer_InteractorStyle::VTKViewer_InteractorStyle ( )
◆ ~VTKViewer_InteractorStyle()
VTKViewer_InteractorStyle::~VTKViewer_InteractorStyle ( )
◆ VTKViewer_InteractorStyle() [2/2]
VTKViewer_InteractorStyle::VTKViewer_InteractorStyle ( const VTKViewer_InteractorStyle &  )
inlineprotected
◆ CurrentState()
int VTKViewer_InteractorStyle::CurrentState ( ) const
◆ DollyXY()
void VTKViewer_InteractorStyle::DollyXY ( int  dx,
int  dy
Move the position of the camera along the direction of projection. (dx,dy)
References MotionFactor, myGUIWindow, and ResetCameraClippingRange().
◆ drawRect()
void VTKViewer_InteractorStyle::drawRect ( )
Draws rectangle by starting and current points
References myGUIWindow, myOtherPoint, myPoint, myRectBand, and Plot2d::Rectangle.
◆ endDrawRect()
void VTKViewer_InteractorStyle::endDrawRect ( )
References myRectBand.
◆ eventFilter()
bool VTKViewer_InteractorStyle::eventFilter ( QObject *  object,
QEvent *  event
event filter - controls mouse and keyboard events during viewer operations
References myGUIWindow, startOperation(), and VTK_INTERACTOR_STYLE_CAMERA_NONE.
◆ fitRect()
void VTKViewer_InteractorStyle::fitRect ( const int  left,
const int  top,
const int  right,
const int  bottom
fits viewer contents to rectangle
left- left side
top- top side
right- right side
bottom- bottom side
References myGUIWindow, ResetCameraClippingRange(), and TranslateView().
◆ Handle()
VTKViewer_InteractorStyle::Handle ( VTKViewer_Filter  ) const
◆ IncrementalPan()
void VTKViewer_InteractorStyle::IncrementalPan ( const int  incrX,
const int  incrY
Increment pan.
incrX- X coordinate increment.
incrY- Y coordinate increment.
References PanXY().
◆ IncrementalRotate()
void VTKViewer_InteractorStyle::IncrementalRotate ( const int  incrX,
const int  incrY
Increment rotate.
References RotateXY().
◆ IncrementalZoom()
void VTKViewer_InteractorStyle::IncrementalZoom ( const int  incr)
Increment zoom.
incr- zoom increment.
References DollyXY().
◆ IsFilterPresent()
bool VTKViewer_InteractorStyle::IsFilterPresent ( const int  theId)
Checks: is filter present (with id theId)
theId- filter id.
References myFilters.
◆ IsInRect() [1/3]
bool VTKViewer_InteractorStyle::IsInRect ( double *  thePoint,
const int  left,
const int  top,
const int  right,
const int  bottom
Checks: is given point thePoint in rectangle
◆ IsInRect() [2/3]
bool VTKViewer_InteractorStyle::IsInRect ( vtkActor *  theActor,
const int  left,
const int  top,
const int  right,
const int  bottom
Checks: is the given Actor within display coordinates?
◆ IsInRect() [3/3]
bool VTKViewer_InteractorStyle::IsInRect ( vtkCell *  theCell,
const int  left,
const int  top,
const int  right,
const int  bottom
Checks: is the given Cell within display coordinates?
◆ IsValid()
bool VTKViewer_InteractorStyle::IsValid ( VTKViewer_Actor *  theActor,
const bool  theIsNode = false
Checks: is valid cell(node) with id theId in actor theActor.
theActor- VTKViewer_Actor pointer.
theId- cell id.
theIsNode- boolean flag, if true - node, else - cell.
References Handle(), and myFilters.
◆ loadCursors()
void VTKViewer_InteractorStyle::loadCursors ( )
Loads cursors for viewer operations - zoom, pan, etc...
References imageRotateCursor, imageZoomCursor, myCursorState, myDefCursor, myGlobalPanCursor, myHandCursor, myPanCursor, myRotateCursor, mySpinCursor, and myZoomCursor.
◆ needsRedrawing()
bool VTKViewer_InteractorStyle::needsRedrawing ( )
◆ New()
static VTKViewer_InteractorStyle * VTKViewer_InteractorStyle::New ( )
◆ onCursorMove()
void VTKViewer_InteractorStyle::onCursorMove ( QPoint  )
called when user moves mouse inside viewer window and there is no active viewer operation
(!put necessary processing here!)
◆ onFinishOperation()
void VTKViewer_InteractorStyle::onFinishOperation ( )
called when viewer operation finished (!put necessary post-processing here!)
References myGUIWindow.
◆ OnLeftButtonDown()
void VTKViewer_InteractorStyle::OnLeftButtonDown ( int  ctrl,
int  shift,
int  x,
int  y
On Left button down event.
ctrl- CTRL (on/off - integer 0/1)
shift- SHIFT (on/off - integer 0/1)
x- x coordinate
y- y coordinate
References ForcedState, myOtherPoint, myPoint, myShiftState, onFinishOperation(), startOperation(), State, VTK_INTERACTOR_STYLE_CAMERA_NONE, VTK_INTERACTOR_STYLE_CAMERA_SELECT, and VTK_INTERACTOR_STYLE_CAMERA_ZOOM.
◆ OnLeftButtonUp()
void VTKViewer_InteractorStyle::OnLeftButtonUp ( int  ctrl,
int  shift,
int  x,
int  y
On left button up event.
ctrl- CTRL (not used)
x- x coordinate (not used)
y- y coordinate (not used)
References myShiftState, onFinishOperation(), startOperation(), State, and VTK_INTERACTOR_STYLE_CAMERA_NONE.
◆ OnMiddleButtonDown()
void VTKViewer_InteractorStyle::OnMiddleButtonDown ( int  ctrl,
int  shift,
int  x,
int  y
x- x coordinate
y- y coordinate
References ForcedState, myOtherPoint, myPoint, myShiftState, onFinishOperation(), startOperation(), State, VTK_INTERACTOR_STYLE_CAMERA_NONE, and VTK_INTERACTOR_STYLE_CAMERA_PAN.
◆ OnMiddleButtonUp()
void VTKViewer_InteractorStyle::OnMiddleButtonUp ( int  ctrl,
int  shift,
int  x,
int  y
On middle button up event.
◆ OnMouseMove()
void VTKViewer_InteractorStyle::OnMouseMove ( int  ctrl,
int  shift,
int  x,
int  y
On mouse move event.
x- x coordinate
y- y coordinate
References ForcedState, myShiftState, onCursorMove(), onOperation(), State, and VTK_INTERACTOR_STYLE_CAMERA_NONE.
◆ onOperation()
◆ OnRightButtonDown()
void VTKViewer_InteractorStyle::OnRightButtonDown ( int  ctrl,
int  shift,
int  x,
int  y
On right button down event.
x- x coordinate
y- y coordinate
References ForcedState, myOtherPoint, myPoint, myShiftState, onFinishOperation(), startOperation(), State, VTK_INTERACTOR_STYLE_CAMERA_NONE, and VTK_INTERACTOR_STYLE_CAMERA_ROTATE.
◆ OnRightButtonUp()
void VTKViewer_InteractorStyle::OnRightButtonUp ( int  ctrl,
int  shift,
int  x,
int  y
On right button up event.
◆ OnSelectionModeChanged()
void VTKViewer_InteractorStyle::OnSelectionModeChanged ( )
called when selection mode changed (!put necessary initialization here!)
References myEdgeId, myElemId, myNodeId, myPreSelectionActor, and mySelectedActor.
◆ onStartOperation()
void VTKViewer_InteractorStyle::onStartOperation ( )
◆ operator=()
void VTKViewer_InteractorStyle::operator= ( const VTKViewer_InteractorStyle &  )
inlineprotected
◆ PanXY()
void VTKViewer_InteractorStyle::PanXY ( int  x,
int  y,
int  oldX,
int  oldY
References myGUIWindow, and TranslateView().
◆ Place()
void VTKViewer_InteractorStyle::Place ( const int  theX,
const int  theY
called on finsh GlobalPan operation
References myGUIWindow, myScale, ResetCameraClippingRange(), and TranslateView().
◆ RemoveFilter()
void VTKViewer_InteractorStyle::RemoveFilter ( const int  theId)
Remove filter with id theId.
theId- filter id.
References IsFilterPresent(), and myFilters.
◆ RotateXY()
void VTKViewer_InteractorStyle::RotateXY ( int  dx,
int  dy
Rotate camera.
dx-
dy-
References DeltaAzimuth, DeltaElevation, MotionFactor, myGUIWindow, and ResetCameraClippingRange().
◆ setCursor()
◆ SetFilter()
void VTKViewer_InteractorStyle::SetFilter ( const Handle(VTKViewer_Filter)&  theFilter)
Set filter theFilter
◆ setGUIWindow()
void VTKViewer_InteractorStyle::setGUIWindow ( QWidget *  theWindow)
Set GUI window.
theWindow- QWidget window.
◆ setPreselectionProp()
void VTKViewer_InteractorStyle::setPreselectionProp ( const double &  theRed = 0,
const double &  theGreen = 1,
const double &  theBlue = 1,
const int &  theWidth = 5
Set preselection properties.
theRed- red color.
theGreen- green color.
theBlue- blue color.
theWidth- width..
References myPreSelectionActor, and VTKViewer_Actor::SetColor().
◆ SetTDxStyle()
void VTKViewer_InteractorStyle::SetTDxStyle ( vtkTDxInteractorStyle *  )
◆ setTriedron()
void VTKViewer_InteractorStyle::setTriedron ( VTKViewer_Trihedron *  theTrihedron)
Set trihedron.
theTrihedron- SALOME VTKViewer_Trihedron
References m_Trihedron.
◆ setViewWnd()
void VTKViewer_InteractorStyle::setViewWnd ( VTKViewer_ViewWindow *  theViewWnd)
Set view window.
theViewWnd- SALOME VTKViewer_ViewWindow
References VTKViewer_ViewWindow::AddActor(), m_ViewWnd, and myPreSelectionActor.
◆ SpinXY()
void VTKViewer_InteractorStyle::SpinXY ( int  dx,
int  dy,
int  oldX,
int  oldY
References myGUIWindow, and RadianToDegree.
◆ startFitArea()
void VTKViewer_InteractorStyle::startFitArea ( )
starts Fit Area operation (e.g. through menu command)
References ForcedState, onFinishOperation(), setCursor(), startOperation(), State, VTK_INTERACTOR_STYLE_CAMERA_FIT, and VTK_INTERACTOR_STYLE_CAMERA_NONE.
◆ startGlobalPan()
void VTKViewer_InteractorStyle::startGlobalPan ( )
◆ startOperation()
◆ startPan()
void VTKViewer_InteractorStyle::startPan ( )
◆ startRotate()
void VTKViewer_InteractorStyle::startRotate ( )
◆ startSpin()
void VTKViewer_InteractorStyle::startSpin ( )
◆ startZoom()
void VTKViewer_InteractorStyle::startZoom ( )
◆ TranslateView()
void VTKViewer_InteractorStyle::TranslateView ( int  toX,
int  toY,
int  fromX,
int  fromY
Translates view from Point to Point
◆ ViewFitAll()
◆ ViewFitSelection()
void VTKViewer_InteractorStyle::ViewFitSelection ( )
◆ vtkTypeMacro()
VTKViewer_InteractorStyle::vtkTypeMacro ( VTKViewer_InteractorStyle  ,
vtkInteractorStyle
◆ DeltaAzimuth
double VTKViewer_InteractorStyle::DeltaAzimuth
◆ DeltaElevation
double VTKViewer_InteractorStyle::DeltaElevation
◆ ForcedState
int VTKViewer_InteractorStyle::ForcedState
◆ LastPos
int VTKViewer_InteractorStyle::LastPos[2]
◆ m_Interactor
VTKViewer_RenderWindowInteractor* VTKViewer_InteractorStyle::m_Interactor
◆ m_Trihedron
VTKViewer_Trihedron* VTKViewer_InteractorStyle::m_Trihedron
◆ m_ViewWnd
VTKViewer_ViewWindow* VTKViewer_InteractorStyle::m_ViewWnd
◆ MotionFactor
double VTKViewer_InteractorStyle::MotionFactor
◆ myCursorState
bool VTKViewer_InteractorStyle::myCursorState
◆ myDefCursor
QCursor VTKViewer_InteractorStyle::myDefCursor
◆ myEdgeId
int VTKViewer_InteractorStyle::myEdgeId
◆ myElemId
vtkIdType VTKViewer_InteractorStyle::myElemId
◆ myFilters
std::map<int, Handle(VTKViewer_Filter) > VTKViewer_InteractorStyle::myFilters
◆ myGlobalPanCursor
QCursor VTKViewer_InteractorStyle::myGlobalPanCursor
◆ myGUIWindow
QWidget* VTKViewer_InteractorStyle::myGUIWindow
◆ myHandCursor
QCursor VTKViewer_InteractorStyle::myHandCursor
◆ myNodeId
vtkIdType VTKViewer_InteractorStyle::myNodeId
◆ myOtherPoint
QPoint VTKViewer_InteractorStyle::myOtherPoint
◆ myPanCursor
QCursor VTKViewer_InteractorStyle::myPanCursor
◆ myPoint
QPoint VTKViewer_InteractorStyle::myPoint
◆ myPreSelectionActor
VTKViewer_Actor * VTKViewer_InteractorStyle::myPreSelectionActor
◆ myPreViewActor
VTKViewer_Actor* VTKViewer_InteractorStyle::myPreViewActor
◆ myRectBand
QRubberBand* VTKViewer_InteractorStyle::myRectBand
◆ myRotateCursor
QCursor VTKViewer_InteractorStyle::myRotateCursor
◆ myScale
double VTKViewer_InteractorStyle::myScale
◆ mySelectedActor
VTKViewer_Actor * VTKViewer_InteractorStyle::mySelectedActor
◆ myShiftState
bool VTKViewer_InteractorStyle::myShiftState
◆ mySpinCursor
QCursor VTKViewer_InteractorStyle::mySpinCursor
◆ myZoomCursor
QCursor VTKViewer_InteractorStyle::myZoomCursor
◆ RadianToDegree
double VTKViewer_InteractorStyle::RadianToDegree
◆ State
int VTKViewer_InteractorStyle::State
