calcium_provides_port Class Referenceabstract
#include <calcium_provides_port.hxx>
Inheritance diagram for calcium_provides_port:
typedef CalciumTypes::DependencyType DependencyType
typedef CalciumTypes::DateCalSchem DateCalSchem
typedef CalciumTypes::InterpolationSchem InterpolationSchem
typedef CalciumTypes::ExtrapolationSchem ExtrapolationSchem
typedef CalciumTypes::DisconnectDirective DisconnectDirective
 calcium_provides_port ()
virtual ~calcium_provides_port ()
virtual void setDependencyType (DependencyType dependencyType)=0
virtual DependencyType getDependencyType () const =0
virtual void setStorageLevel (size_t storageLevel)=0
virtual size_t getStorageLevel () const =0
virtual void setDateCalSchem (DateCalSchem dateCalSchem)=0
virtual DateCalSchem getDateCalSchem () const =0
virtual void setAlpha (double alpha)=0
virtual double getAlpha () const =0
virtual void setDeltaT (double deltaT)=0
virtual double getDeltaT () const =0
virtual void setInterpolationSchem (InterpolationSchem interpolationSchem)=0
virtual void setExtrapolationSchem (ExtrapolationSchem extrapolationSchem)=0
virtual InterpolationSchem getInterpolationSchem () const =0
virtual ExtrapolationSchem getExtrapolationSchem () const =0
virtual void calcium_erase (float, long, bool)
virtual Ports::Port_ptr get_port_ref ()=0
 This method permits to get the CORBA reference of the port. More...
virtual void provides_port_changed (int, const Engines::DSC::Message)
 This method is the callback called by the component to inform the provides port of a new or a removed connection. More...
virtual Ports::PortProperties_ptr get_port_properties ()
 This is used to get the property object of the port. More...
PortProperties_i * default_properties
◆ DateCalSchem
◆ DependencyType
◆ DisconnectDirective
◆ ExtrapolationSchem
◆ InterpolationSchem
◆ calcium_provides_port()
calcium_provides_port::calcium_provides_port ( )
◆ ~calcium_provides_port()
calcium_provides_port::~calcium_provides_port ( )
◆ calcium_erase()
virtual void calcium_provides_port::calcium_erase ( float  ,
long  ,
bool
◆ get_port_properties()
Ports::PortProperties_ptr base_port::get_port_properties ( )
property's CORBA reference.
References base_port::default_properties.
◆ get_port_ref()
virtual Ports::Port_ptr provides_port::get_port_ref ( )
pure virtualinherited
port's CORBA reference.
Implemented in data_short_port_provides, palm_data_seq_short_port_provides, and palm_data_short_port_provides.
◆ getAlpha()
virtual double calcium_provides_port::getAlpha ( ) const
pure virtual
◆ getDateCalSchem()
virtual DateCalSchem calcium_provides_port::getDateCalSchem ( ) const
pure virtual
◆ getDeltaT()
virtual double calcium_provides_port::getDeltaT ( ) const
pure virtual
◆ getDependencyType()
virtual DependencyType calcium_provides_port::getDependencyType ( ) const
pure virtual
◆ getExtrapolationSchem()
virtual ExtrapolationSchem calcium_provides_port::getExtrapolationSchem ( ) const
pure virtual
◆ getInterpolationSchem()
virtual InterpolationSchem calcium_provides_port::getInterpolationSchem ( ) const
pure virtual
◆ getStorageLevel()
virtual size_t calcium_provides_port::getStorageLevel ( ) const
pure virtual
◆ provides_port_changed()
virtual void provides_port::provides_port_changed ( int  ,
connection_nbrcurrent connection number.
messagemessage associated with this connection.
◆ setAlpha()
virtual void calcium_provides_port::setAlpha ( double  alpha)
pure virtual
◆ setDateCalSchem()
virtual void calcium_provides_port::setDateCalSchem ( DateCalSchem  dateCalSchem)
pure virtual
◆ setDeltaT()
virtual void calcium_provides_port::setDeltaT ( double  deltaT)
pure virtual
◆ setDependencyType()
virtual void calcium_provides_port::setDependencyType ( DependencyType  dependencyType)
pure virtual
◆ setExtrapolationSchem()
virtual void calcium_provides_port::setExtrapolationSchem ( ExtrapolationSchem  extrapolationSchem)
pure virtual
◆ setInterpolationSchem()
virtual void calcium_provides_port::setInterpolationSchem ( InterpolationSchem  interpolationSchem)
pure virtual
◆ setStorageLevel()
virtual void calcium_provides_port::setStorageLevel ( size_t  storageLevel)
pure virtual
◆ default_properties
PortProperties_i* base_port::default_properties
