BuildAPI_Edge.h
20#ifndef BuildAPI_Edge_H_
21#define BuildAPI_Edge_H_
23#include "BuildAPI.h"
24
25#include <BuildPlugin_Edge.h>
26
31
36{
37public:
39 BUILDAPI_EXPORT
40 explicit BuildAPI_Edge(const std::shared_ptr<ModelAPI_Feature>& theFeature);
41
43 BUILDAPI_EXPORT
44 explicit BuildAPI_Edge(const std::shared_ptr<ModelAPI_Feature>& theFeature,
45 const std::list<ModelHighAPI_Selection>& theBaseObjects,
46 const bool theComputeIntersections = false);
47
49 BUILDAPI_EXPORT
50 explicit BuildAPI_Edge(const std::shared_ptr<ModelAPI_Feature>& theFeature,
51 const ModelHighAPI_Selection& theFirstPoint,
52 const ModelHighAPI_Selection& theSecondPoint);
53
55 BUILDAPI_EXPORT
56 virtual ~BuildAPI_Edge();
57
58 INTERFACE_5(BuildPlugin_Edge::ID(),
69
70
71 BUILDAPI_EXPORT
72 void setBase(const std::list<ModelHighAPI_Selection>& theBaseObjects);
73
75 BUILDAPI_EXPORT
76 virtual void dump(ModelHighAPI_Dumper& theDumper) const;
77};
78
80typedef std::shared_ptr<BuildAPI_Edge> EdgePtr;
81
84BUILDAPI_EXPORT
85EdgePtr addEdge(const std::shared_ptr<ModelAPI_Document>& thePart,
86 const std::list<ModelHighAPI_Selection>& theBaseObjects,
87 const bool theComputeIntersection = false);
90BUILDAPI_EXPORT
91EdgePtr addEdge(const std::shared_ptr<ModelAPI_Document>& thePart,
92 const ModelHighAPI_Selection& theFirstPoint,
93 const ModelHighAPI_Selection& theSecondPoint);
94
95#endif // BuildAPI_Edge_H_
Interface for Edge feature.
Definition: BuildAPI_Edge.h:36
virtual std::shared_ptr< ModelAPI_AttributeSelection > firstPoint() const
First point.
Definition: BuildAPI_Edge.h:68
void setBase(const std::list< ModelHighAPI_Selection > &theBaseObjects)
Modify base attribute of the feature.
Definition: BuildAPI_Edge.cpp:67
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > baseObjects() const
Base objects.
virtual std::shared_ptr< ModelAPI_AttributeSelection > secondPoint() const
Second point.
virtual std::shared_ptr< ModelAPI_AttributeString > creationMethod() const
Creation method.
Dump wrapped feature.
Definition: BuildAPI_Edge.cpp:75
virtual std::shared_ptr< ModelAPI_AttributeBoolean > computeIntersections() const
Intersect edges.
BuildAPI_Edge(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: BuildAPI_Edge.cpp:26
Definition: BuildAPI_Edge.cpp:61
static const std::string & INTERSECT_ID()
Attribute name of "Compute intersections" checkbox.
Definition: BuildPlugin_Edge.h:93
Definition: BuildPlugin_Edge.h:58
Definition: BuildPlugin_Edge.h:44
static const std::string & FIRST_POINT()
Attribute name for the first point.
Definition: BuildPlugin_Edge.h:79
static const std::string & SECOND_POINT()
Attribute name for the second point.
Definition: BuildPlugin_Edge.h:86
Feature kind.
Definition: BuildPlugin_Edge.h:37
Dump engine for the model.
EdgePtr addEdge(const std::shared_ptr< ModelAPI_Document > &thePart, const std::list< ModelHighAPI_Selection > &theBaseObjects, const bool theComputeIntersection=false)
Create Edge feature.
Definition: BuildAPI_Edge.cpp:99
