BuildAPI_Wire.h
20#ifndef BuildAPI_Wire_H_
21#define BuildAPI_Wire_H_
23#include "BuildAPI.h"
24
25#include <BuildPlugin_Wire.h>
26
31
36{
37public:
39 BUILDAPI_EXPORT
40 explicit BuildAPI_Wire(const std::shared_ptr<ModelAPI_Feature>& theFeature);
41
43 BUILDAPI_EXPORT
44 explicit BuildAPI_Wire(const std::shared_ptr<ModelAPI_Feature>& theFeature,
45 const std::list<ModelHighAPI_Selection>& theBaseObjects,
46 const bool theComputeIntersections = false);
47
49 BUILDAPI_EXPORT
50 virtual ~BuildAPI_Wire();
51
52 INTERFACE_2(BuildPlugin_Wire::ID(),
57
58
59 BUILDAPI_EXPORT
60 void setBase(const std::list<ModelHighAPI_Selection>& theBaseObjects);
61
63 BUILDAPI_EXPORT
64 void addContour();
65
67 BUILDAPI_EXPORT
68 virtual void dump(ModelHighAPI_Dumper& theDumper) const;
69};
70
72typedef std::shared_ptr<BuildAPI_Wire> WirePtr;
73
76BUILDAPI_EXPORT
77WirePtr addWire(const std::shared_ptr<ModelAPI_Document>& thePart,
78 const std::list<ModelHighAPI_Selection>& theBaseObjects,
79 const bool theComputeIntersections = false);
80
81#endif // BuildAPI_Wire_H_
Interface for Wire feature.
Definition: BuildAPI_Wire.h:36
void addContour()
Adds closed contour.
Definition: BuildAPI_Wire.cpp:75
virtual std::shared_ptr< ModelAPI_AttributeBoolean > computeIntersections() const
Intersect edges.
Definition: BuildAPI_Wire.h:56
Definition: BuildAPI_Wire.cpp:45
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > baseObjects() const
Base objects.
Dump wrapped feature.
Definition: BuildAPI_Wire.cpp:59
void setBase(const std::list< ModelHighAPI_Selection > &theBaseObjects)
Modify base attribute of the feature.
Definition: BuildAPI_Wire.cpp:51
BuildAPI_Wire(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: BuildAPI_Wire.cpp:26
Feature kind.
Definition: BuildPlugin_Wire.h:37
Definition: BuildPlugin_Wire.h:44
static const std::string & INTERSECT_ID()
Attribute name of "Compute intersections" checkbox.
Definition: BuildPlugin_Wire.h:58
Dump engine for the model.
WirePtr addWire(const std::shared_ptr< ModelAPI_Document > &thePart, const std::list< ModelHighAPI_Selection > &theBaseObjects, const bool theComputeIntersections=false)
Create Wire feature.
Definition: BuildAPI_Wire.cpp:81
