Interface for Wire feature. More...
#include <BuildAPI_Wire.h>
| BuildAPI_Wire (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| BuildAPI_Wire (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects, const bool theComputeIntersections=false) | |
| virtual | ~BuildAPI_Wire () |
| Destructor. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelectionList > | baseObjects () const |
| Base objects. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeBoolean > | computeIntersections () const |
| Intersect edges. More... | |
| void | setBase (const std::list< ModelHighAPI_Selection > &theBaseObjects) |
| Modify base attribute of the feature. More... | |
| void | addContour () |
| Adds closed contour. More... | |
| bool | initialize () |
Protected Attributes | |
| std::shared_ptr< ModelAPI_AttributeSelectionList > | mybaseObjects |
| std::shared_ptr< ModelAPI_AttributeBoolean > | mycomputeIntersections |
explicit |
explicit |
inlinevirtual |
Base objects.
inlinevirtual |
Intersect edges.
| void BuildAPI_Wire::setBase | ( | const std::list< ModelHighAPI_Selection > & | theBaseObjects | ) |
| void BuildAPI_Wire::addContour | ( | ) |
protectedinherited |
