ExchangeAPI_Import.h
20#ifndef SRC_EXCHANGEAPI_EXCHANGEAPI_IMPORT_H_
21#define SRC_EXCHANGEAPI_EXCHANGEAPI_IMPORT_H_
23//--------------------------------------------------------------------------------------
24#include "ExchangeAPI.h"
26#include <string>
27
28#include <ExchangePlugin_ImportFeature.h>
30#include <ModelHighAPI_Interface.h>
31#include <ModelHighAPI_Macro.h>
32#include <ModelHighAPI_Reference.h>
33#include <ModelHighAPI_Selection.h>
34
35#include <Python.h>
36//--------------------------------------------------------------------------------------
37
43{
44public:
46 EXCHANGEAPI_EXPORT
47 explicit ExchangeAPI_Import(const std::shared_ptr<ModelAPI_Feature> & theFeature);
48
50 EXCHANGEAPI_EXPORT
51 ExchangeAPI_Import(const std::shared_ptr<ModelAPI_Feature> & theFeature,
52 const std::string & theFilePath);
53
55 EXCHANGEAPI_EXPORT
56 ExchangeAPI_Import(const std::shared_ptr<ModelAPI_Feature> & theFeature,
57 const std::string & theFilePath,
58 const std::string & theBuffer);
59
61 EXCHANGEAPI_EXPORT
62 ExchangeAPI_Import(const std::shared_ptr<ModelAPI_Feature> & theFeature,
63 const std::string & theFilePath,
64 const bool theScalInterUnits,
65 const bool theMaterials,
66 const bool theColor);
68 EXCHANGEAPI_EXPORT
69 virtual ~ExchangeAPI_Import();
70
86 )
87
88
89 EXCHANGEAPI_EXPORT
90 void setFilePath(const std::string & theFilePath);
91
92 EXCHANGEAPI_EXPORT
93 void setParameters(const std::string & theFilePath,
94 const bool theScalInterUnits,
95 const bool theMaterials,
96 const bool theColor);
97
99 EXCHANGEAPI_EXPORT
100 virtual void dump(ModelHighAPI_Dumper& theDumper) const;
101};
102
104typedef std::shared_ptr<ExchangeAPI_Import> ImportPtr;
105
109EXCHANGEAPI_EXPORT
110ImportPtr addImport(const std::shared_ptr<ModelAPI_Document> & thePart,
111 const std::string & theFilePath);
112
116EXCHANGEAPI_EXPORT
117ImportPtr addImportXAOMem(const std::shared_ptr<ModelAPI_Document> & thePart,
118 PyObject* theBuffer);
119
123EXCHANGEAPI_EXPORT
124ImportPtr addImportSTEP(const std::shared_ptr<ModelAPI_Document> & thePart,
125 const std::string & theFilePath,
126 const bool theScalInterUnits,
127 const bool theMaterials,
128 const bool theColor);
129
130
134EXCHANGEAPI_EXPORT void importPart(
135 const std::shared_ptr<ModelAPI_Document> & thePart,
136 const std::string & theFilePath,
137 const ModelHighAPI_Reference & theAfterThis = ModelHighAPI_Reference());
138
139//--------------------------------------------------------------------------------------
140//--------------------------------------------------------------------------------------
146{
147public:
149 EXCHANGEAPI_EXPORT
150 explicit ExchangeAPI_Import_Image(const std::shared_ptr<ModelAPI_Feature> & theFeature);
152 EXCHANGEAPI_EXPORT
153 ExchangeAPI_Import_Image(const std::shared_ptr<ModelAPI_Feature> & theFeature,
154 const std::string & theFilePath);
155
157 EXCHANGEAPI_EXPORT
158 virtual ~ExchangeAPI_Import_Image() = default;
159
164
165
166 EXCHANGEAPI_EXPORT
167 void setFilePath(const std::string & theFilePath);
168
170 EXCHANGEAPI_EXPORT
171 virtual void dump(ModelHighAPI_Dumper& theDumper) const;
172
173};
174
176typedef std::shared_ptr<ExchangeAPI_Import_Image> ImportImagePtr;
177
178
179EXCHANGEAPI_EXPORT
180ImportImagePtr addImportImage(const std::shared_ptr<ModelAPI_Document> & thePart,
181 const std::string & theFilePath);
182
183//--------------------------------------------------------------------------------------
184#endif /* SRC_EXCHANGEAPI_EXCHANGEAPI_IMPORT_H_ */
Interface for Import feature.
Definition: ExchangeAPI_Import.h:146
virtual ~ExchangeAPI_Import_Image()=default
Definition: ExchangeAPI_Import.h:43
virtual std::shared_ptr< ModelAPI_AttributeString > importType() const
import type
Definition: ExchangeAPI_Import.h:86
virtual std::shared_ptr< ModelAPI_AttributeBoolean > scalInterUnits() const
Scale internationals units.
ExchangeAPI_Import(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: ExchangeAPI_Import.cpp:43
Definition: ExchangeAPI_Import.cpp:84
virtual std::shared_ptr< ModelAPI_AttributeString > memoryBuffer() const
Bytes.
virtual std::shared_ptr< ModelAPI_AttributeString > stepFilePath() const
step File path
Dump wrapped feature.
Definition: ExchangeAPI_Import.cpp:118
virtual std::shared_ptr< ModelAPI_AttributeBoolean > colors() const
Colors.
void setFilePath(const std::string &theFilePath)
Set point values.
Definition: ExchangeAPI_Import.cpp:104
virtual std::shared_ptr< ModelAPI_AttributeBoolean > materials() const
Materials.
virtual std::shared_ptr< ModelAPI_AttributeString > filePath() const
File path.
static const std::string & FILE_PATH_ID()
attribute name of file path
Definition: ExchangePlugin_ImportFeature.h:42
static const std::string & IMPORT_TYPE_ID()
Feature kind.
Definition: ExchangePlugin_ImportFeature.h:117
static const std::string & STEP_COLORS_ID()
attribute name of step colors
Definition: ExchangePlugin_ImportFeature.h:147
Feature kind.
Definition: ExchangePlugin_ImportFeature.h:111
static const std::string & STEP_SCALE_INTER_UNITS_ID()
attribute name of step Scale to International System Units
Definition: ExchangePlugin_ImportFeature.h:135
static const std::string & MEMORY_BUFFER_ID()
attribute memory buffer
Definition: ExchangePlugin_ImportFeature.h:153
static const std::string & STEP_FILE_PATH_ID()
Definition: ExchangePlugin_ImportFeature.h:123
static const std::string & STEP_MATERIALS_ID()
attribute name of step materiels
Definition: ExchangePlugin_ImportFeature.h:141
Feature kind.
Definition: ExchangePlugin_ImportFeature.h:201
Dump engine for the model.
Class for filling ModelAPI_AttributeReference.
Definition: ModelHighAPI_Reference.h:41
ImportPtr addImportXAOMem(const std::shared_ptr< ModelAPI_Document > &thePart, PyObject *theBuffer)
Create Import feature to import XAO data from bytes buffer.
Definition: ExchangeAPI_Import.cpp:192
ImportPtr addImport(const std::shared_ptr< ModelAPI_Document > &thePart, const std::string &theFilePath)
Create Import feature.
Definition: ExchangeAPI_Import.cpp:184
void importPart(const std::shared_ptr< ModelAPI_Document > &thePart, const std::string &theFilePath, const ModelHighAPI_Reference &theAfterThis=ModelHighAPI_Reference())
Import features from the file to the document after the current feature (or to the end).
Definition: ExchangeAPI_Import.cpp:212
ImportPtr addImportSTEP(const std::shared_ptr< ModelAPI_Document > &thePart, const std::string &theFilePath, const bool theScalInterUnits, const bool theMaterials, const bool theColor)
Create Import Step feature.
Definition: ExchangeAPI_Import.cpp:200
