ExchangeAPI_Import Class Reference
Interface for Import feature. More...
#include <ExchangeAPI_Import.h>
Inheritance diagram for ExchangeAPI_Import:
 ExchangeAPI_Import (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 ExchangeAPI_Import (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::string &theFilePath)
 ExchangeAPI_Import (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::string &theFilePath, const std::string &theBuffer)
 Constructor with values for XAO import from memory buffer. More...
 ExchangeAPI_Import (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::string &theFilePath, const bool theScalInterUnits, const bool theMaterials, const bool theColor)
 Constructor with values for Step file. More...
virtual ~ExchangeAPI_Import ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeString > filePath () const
 File path. More...
virtual std::shared_ptr< ModelAPI_AttributeString > importType () const
 import type More...
virtual std::shared_ptr< ModelAPI_AttributeString > stepFilePath () const
 step File path More...
virtual std::shared_ptr< ModelAPI_AttributeBoolean > scalInterUnits () const
 Scale internationals units. More...
virtual std::shared_ptr< ModelAPI_AttributeBoolean > materials () const
 Materials. More...
virtual std::shared_ptr< ModelAPI_AttributeBoolean > colors () const
 Colors. More...
virtual std::shared_ptr< ModelAPI_AttributeString > memoryBuffer () const
 Bytes. More...
void setFilePath (const std::string &theFilePath)
 Set point values. More...
void setParameters (const std::string &theFilePath, const bool theScalInterUnits, const bool theMaterials, const bool theColor)
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeString > myfilePath
std::shared_ptr< ModelAPI_AttributeString > myimportType
std::shared_ptr< ModelAPI_AttributeString > mystepFilePath
std::shared_ptr< ModelAPI_AttributeBoolean > myscalInterUnits
std::shared_ptr< ModelAPI_AttributeBoolean > mymaterials
std::shared_ptr< ModelAPI_AttributeBoolean > mycolors
std::shared_ptr< ModelAPI_AttributeString > mymemoryBuffer
◆ ExchangeAPI_Import() [1/4]
ExchangeAPI_Import::ExchangeAPI_Import ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ ExchangeAPI_Import() [2/4]
ExchangeAPI_Import::ExchangeAPI_Import ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const std::string &  theFilePath
◆ ExchangeAPI_Import() [3/4]
const std::string &  theFilePath,
const std::string &  theBuffer
◆ ExchangeAPI_Import() [4/4]
const bool  theColor
◆ ~ExchangeAPI_Import()
ExchangeAPI_Import::~ExchangeAPI_Import ( )
◆ filePath()
virtual std::shared_ptr< ModelAPI_AttributeString > ExchangeAPI_Import::filePath ( ) const
File path.
◆ importType()
virtual std::shared_ptr< ModelAPI_AttributeString > ExchangeAPI_Import::importType ( ) const
import type
◆ stepFilePath()
virtual std::shared_ptr< ModelAPI_AttributeString > ExchangeAPI_Import::stepFilePath ( ) const
step File path
◆ scalInterUnits()
virtual std::shared_ptr< ModelAPI_AttributeBoolean > ExchangeAPI_Import::scalInterUnits ( ) const
◆ materials()
virtual std::shared_ptr< ModelAPI_AttributeBoolean > ExchangeAPI_Import::materials ( ) const
Materials.
◆ colors()
virtual std::shared_ptr< ModelAPI_AttributeBoolean > ExchangeAPI_Import::colors ( ) const
Colors.
◆ memoryBuffer()
virtual std::shared_ptr< ModelAPI_AttributeString > ExchangeAPI_Import::memoryBuffer ( ) const
Bytes.
◆ setFilePath()
void ExchangeAPI_Import::setFilePath ( const std::string &  theFilePath)
Set point values.
◆ dump()
void ExchangeAPI_Import::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
