FeaturesAPI_LimitTolerance.h
20#ifndef FEATURESAPI_LIMITTOLERANCE_H_
21#define FEATURESAPI_LIMITTOLERANCE_H_
23#include "FeaturesAPI.h"
24
25#include <FeaturesPlugin_LimitTolerance.h>
26
33
38{
39public:
41 FEATURESAPI_EXPORT
42 explicit FeaturesAPI_LimitTolerance(const std::shared_ptr<ModelAPI_Feature>& theFeature);
43
45 FEATURESAPI_EXPORT
46 explicit FeaturesAPI_LimitTolerance(const std::shared_ptr<ModelAPI_Feature>& theFeature,
47 const ModelHighAPI_Selection& theShape,
48 const ModelHighAPI_Double& theTolerance,
49 const bool theExactCheck);
50
52 FEATURESAPI_EXPORT
54
56
59
62
65
66
67 FEATURESAPI_EXPORT
68 void setMainObject(const ModelHighAPI_Selection& theMainObject);
69
71 FEATURESAPI_EXPORT
72 void setTolerance(const ModelHighAPI_Double& theTolerance);
73
75 FEATURESAPI_EXPORT
76 void setExactCheck(const bool theExactCheck);
77
79 FEATURESAPI_EXPORT
80 virtual void dump(ModelHighAPI_Dumper& theDumper) const;
81};
82
84typedef std::shared_ptr<FeaturesAPI_LimitTolerance> LimitTolerancePtr;
85
88FEATURESAPI_EXPORT
89LimitTolerancePtr addLimitTolerance(const std::shared_ptr<ModelAPI_Document>& thePart,
90 const ModelHighAPI_Selection& theMainObject,
91 const ModelHighAPI_Double& theTolerance,
92 const bool theExactCheck = false);
93
94#endif // FEATURESAPI_LIMITTOLERANCE_H_
Interface for LimitTolerance feature.
Definition: FeaturesAPI_LimitTolerance.h:38
virtual std::shared_ptr< ModelAPI_AttributeBoolean > exactCheck() const
Exact Check Flag.
Definition: FeaturesAPI_LimitTolerance.h:64
FeaturesAPI_LimitTolerance(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: FeaturesAPI_LimitTolerance.cpp:27
virtual std::shared_ptr< ModelAPI_AttributeSelection > mainObject() const
Main object.
Dump wrapped feature.
Definition: FeaturesAPI_LimitTolerance.cpp:75
void setTolerance(const ModelHighAPI_Double &theTolerance)
Set the tolerance.
Definition: FeaturesAPI_LimitTolerance.cpp:61
virtual std::shared_ptr< ModelAPI_AttributeDouble > tolerance() const
Tolerance.
Set the ExactCheck option.
Definition: FeaturesAPI_LimitTolerance.cpp:68
void setMainObject(const ModelHighAPI_Selection &theMainObject)
Set main object.
Definition: FeaturesAPI_LimitTolerance.cpp:54
virtual ~FeaturesAPI_LimitTolerance()
Definition: FeaturesAPI_LimitTolerance.cpp:49
LimitTolerance kind.
Definition: FeaturesPlugin_LimitTolerance.h:37
static const std::string & TOLERANCE_ID()
Attribute name for tolerance.
Definition: FeaturesPlugin_LimitTolerance.h:58
static const std::string & EXACT_CHECK_ID()
Attribute name for exact_check.
Definition: FeaturesPlugin_LimitTolerance.h:65
static const std::string & OBJECT_ID()
Attribute name of referenced object.
Definition: FeaturesPlugin_LimitTolerance.h:51
Dump engine for the model.
LimitTolerancePtr addLimitTolerance(const std::shared_ptr< ModelAPI_Document > &thePart, const ModelHighAPI_Selection &theMainObject, const ModelHighAPI_Double &theTolerance, const bool theExactCheck=false)
Create LimitTolerance feature.
Definition: FeaturesAPI_LimitTolerance.cpp:93
