Interface for LimitTolerance feature. More...
#include <FeaturesAPI_LimitTolerance.h>
| FeaturesAPI_LimitTolerance (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| FeaturesAPI_LimitTolerance (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theShape, const ModelHighAPI_Double &theTolerance, const bool theExactCheck) | |
| virtual | ~FeaturesAPI_LimitTolerance () |
| Destructor. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | mainObject () const |
| Main object. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | tolerance () const |
| Tolerance. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeBoolean > | exactCheck () const |
| Exact Check Flag. More... | |
| void | setMainObject (const ModelHighAPI_Selection &theMainObject) |
| Set main object. More... | |
| void | setTolerance (const ModelHighAPI_Double &theTolerance) |
| Set the tolerance. More... | |
| void | setExactCheck (const bool theExactCheck) |
| Set the ExactCheck option. More... | |
| bool | initialize () |
Protected Attributes | |
| std::shared_ptr< ModelAPI_AttributeSelection > | mymainObject |
| std::shared_ptr< ModelAPI_AttributeDouble > | mytolerance |
| std::shared_ptr< ModelAPI_AttributeBoolean > | myexactCheck |
explicit |
explicit |
inlinevirtual |
Main object.
inlinevirtual |
Tolerance.
inlinevirtual |
Exact Check Flag.
| void FeaturesAPI_LimitTolerance::setMainObject | ( | const ModelHighAPI_Selection & | theMainObject | ) |
Set main object.
| void FeaturesAPI_LimitTolerance::setTolerance | ( | const ModelHighAPI_Double & | theTolerance | ) |
Set the tolerance.
| void FeaturesAPI_LimitTolerance::setExactCheck | ( | const bool | theExactCheck | ) |
protectedinherited |
