20#ifndef FeaturesAPI_Partition_H_
21#define FeaturesAPI_Partition_H_
23#include "FeaturesAPI.h"
25#include <FeaturesPlugin_Partition.h>
29#include <ModelHighAPI_Double.h>
47 const std::list<ModelHighAPI_Selection>& theBaseObjects,
88 const
bool keepSubResults = false);
Interface for Partition feature.
Definition: FeaturesAPI_Partition.h:38
Dump wrapped feature.
Definition: FeaturesAPI_Partition.cpp:90
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > baseObjects() const
Base objects.
Definition: FeaturesAPI_Partition.h:60
void setBase(const std::list< ModelHighAPI_Selection > &theBaseObjects)
Modify base attribute of the feature.
Definition: FeaturesAPI_Partition.cpp:66
virtual std::shared_ptr< ModelAPI_AttributeBoolean > useFuzzy() const
Use Fuzzy parameter.
void setUseFuzzy(bool theUseFuzzy)
Set use fuzzy parameter.
Definition: FeaturesAPI_Partition.cpp:74
virtual std::shared_ptr< ModelAPI_AttributeDouble > fuzzyParam() const
Fuzzy parameter.
virtual ~FeaturesAPI_Partition()
Definition: FeaturesAPI_Partition.cpp:60
FeaturesAPI_Partition(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: FeaturesAPI_Partition.cpp:30
void setFuzzy(const ModelHighAPI_Double &theFuzzy)
Modify fuzzy parameter attribute of the feature.
Definition: FeaturesAPI_Partition.cpp:82
static const std::string & FUZZY_PARAM_ID()
Attribute name of fuzzy parameter.
Definition: FeaturesPlugin_Partition.h:57
Definition: FeaturesPlugin_Partition.h:43
Feature kind.
Definition: FeaturesPlugin_Partition.h:36
static const std::string & USE_FUZZY_ID()
Attribute name of use fuzzy parameter.
Definition: FeaturesPlugin_Partition.h:50
Dump engine for the model.
PartitionPtr addPartition(const std::shared_ptr< ModelAPI_Document > &thePart, const std::list< ModelHighAPI_Selection > &theBaseObjects, const ModelHighAPI_Double &fuzzyParam=ModelHighAPI_Double(-1), const bool keepSubResults=false)
Create Partition feature.
Definition: FeaturesAPI_Partition.cpp:112
