Interface for Partition feature. More...
#include <FeaturesAPI_Partition.h>
| FeaturesAPI_Partition (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| FeaturesAPI_Partition (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theBaseObjects, const ModelHighAPI_Double &theFuzzy=ModelHighAPI_Double(-1)) | |
| virtual | ~FeaturesAPI_Partition () |
| Destructor. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelectionList > | baseObjects () const |
| Base objects. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeBoolean > | useFuzzy () const |
| Use Fuzzy parameter. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | fuzzyParam () const |
| void | setBase (const std::list< ModelHighAPI_Selection > &theBaseObjects) |
| Modify base attribute of the feature. More... | |
| void | setUseFuzzy (bool theUseFuzzy) |
| Set use fuzzy parameter. More... | |
| void | setFuzzy (const ModelHighAPI_Double &theFuzzy) |
| Modify fuzzy parameter attribute of the feature. More... | |
| bool | initialize () |
Protected Attributes | |
| std::shared_ptr< ModelAPI_AttributeSelectionList > | mybaseObjects |
| std::shared_ptr< ModelAPI_AttributeBoolean > | myuseFuzzy |
| std::shared_ptr< ModelAPI_AttributeDouble > | myfuzzyParam |
explicit |
explicit |
inlinevirtual |
Base objects.
inlinevirtual |
inlinevirtual |
Fuzzy parameter.
| void FeaturesAPI_Partition::setBase | ( | const std::list< ModelHighAPI_Selection > & | theBaseObjects | ) |
| void FeaturesAPI_Partition::setUseFuzzy | ( | bool | theUseFuzzy | ) |
| void FeaturesAPI_Partition::setFuzzy | ( | const ModelHighAPI_Double & | theFuzzy | ) |
protectedinherited |
