FeaturesAPI_Union.h
20#ifndef FeaturesAPI_Union_H_
21#define FeaturesAPI_Union_H_
23#include "FeaturesAPI.h"
24
25#include <FeaturesPlugin_Union.h>
26
29#include <ModelHighAPI_Double.h>
30
33
38{
39public:
41 FEATURESAPI_EXPORT
42 explicit FeaturesAPI_Union(const std::shared_ptr<ModelAPI_Feature>& theFeature);
43
45 FEATURESAPI_EXPORT
46 explicit FeaturesAPI_Union(const std::shared_ptr<ModelAPI_Feature>& theFeature,
47 const std::list<ModelHighAPI_Selection>& theBaseObjects,
48 const ModelHighAPI_Double& theFuzzy = ModelHighAPI_Double(-1));
49
51 FEATURESAPI_EXPORT
52 virtual ~FeaturesAPI_Union();
53
54 INTERFACE_3(FeaturesPlugin_Union::ID(),
61
62
63 FEATURESAPI_EXPORT
64 void setBase(const std::list<ModelHighAPI_Selection>& theBaseObjects);
65
67 FEATURESAPI_EXPORT
68 void setUseFuzzy(bool theUseFuzzy);
69
71 FEATURESAPI_EXPORT
72 void setFuzzyValue(const ModelHighAPI_Double& theFuzzy);
73
75 FEATURESAPI_EXPORT
76 virtual void dump(ModelHighAPI_Dumper& theDumper) const;
77};
78
80typedef std::shared_ptr<FeaturesAPI_Union> UnionPtr;
81
84FEATURESAPI_EXPORT
85UnionPtr addUnion(const std::shared_ptr<ModelAPI_Document>& thePart,
86 const std::list<ModelHighAPI_Selection>& theBaseObjects,
88 const bool keepSubResults = false);
89
90#endif // FeaturesAPI_Union_H_
Interface for Union feature.
Definition: FeaturesAPI_Union.h:38
Set use fuzzy parameter.
Definition: FeaturesAPI_Union.cpp:73
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > baseObjects() const
Base objects.
Definition: FeaturesAPI_Union.h:60
Definition: FeaturesAPI_Union.cpp:59
virtual std::shared_ptr< ModelAPI_AttributeBoolean > useFuzzy() const
Use Fuzzy parameter.
void setBase(const std::list< ModelHighAPI_Selection > &theBaseObjects)
Modify base attribute of the feature.
Definition: FeaturesAPI_Union.cpp:65
virtual std::shared_ptr< ModelAPI_AttributeDouble > fuzzyParam() const
Fuzzy parameter.
FeaturesAPI_Union(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: FeaturesAPI_Union.cpp:30
Dump wrapped feature.
Definition: FeaturesAPI_Union.cpp:89
void setFuzzyValue(const ModelHighAPI_Double &theFuzzy)
Set fuzzy parameter.
Definition: FeaturesAPI_Union.cpp:81
static const std::string & USE_FUZZY_ID()
Attribute name of use fuzzy parameter.
Definition: FeaturesPlugin_Union.h:47
Definition: FeaturesPlugin_Union.h:40
static const std::string & FUZZY_PARAM_ID()
Attribute name of fuzzy parameter.
Definition: FeaturesPlugin_Union.h:54
Feature kind.
Definition: FeaturesPlugin_Union.h:33
Dump engine for the model.
UnionPtr addUnion(const std::shared_ptr< ModelAPI_Document > &thePart, const std::list< ModelHighAPI_Selection > &theBaseObjects, const ModelHighAPI_Double &fuzzyParam=ModelHighAPI_Double(-1), const bool keepSubResults=false)
Create Union feature.
Definition: FeaturesAPI_Union.cpp:111
