ModelHighAPI_Folder.h
20#ifndef SRC_MODELHIGHAPI_MODELHIGHAPI_FOLDER_H_
21#define SRC_MODELHIGHAPI_MODELHIGHAPI_FOLDER_H_
23//--------------------------------------------------------------------------------------
24#include <ModelHighAPI_Interface.h>
26#include <ModelAPI_Folder.h>
27
28#include <memory>
29//--------------------------------------------------------------------------------------
33//--------------------------------------------------------------------------------------
39{
40public:
42 MODELHIGHAPI_EXPORT
43 explicit ModelHighAPI_Folder(const std::shared_ptr<ModelAPI_Folder>& theFolder);
45 MODELHIGHAPI_EXPORT virtual ~ModelHighAPI_Folder();
46
47 static std::string ID() { return ModelAPI_Folder::ID(); }
48 virtual std::string getID() { return ID(); }
49 const std::shared_ptr<ModelAPI_Folder>& folder() const {return myFolder;}
50
52 std::shared_ptr<ModelAPI_AttributeReference> firstFeature() const
53 { return myFirstFeature; }
54
56 std::shared_ptr<ModelAPI_AttributeReference> lastFeature() const
57 { return myLastFeature; }
58
60 MODELHIGHAPI_EXPORT
61 void setName(const std::wstring& theName);
62
64 MODELHIGHAPI_EXPORT
65 std::wstring name() const;
66
69 //MODELHIGHAPI_EXPORT void execute();
70
71
73 MODELHIGHAPI_EXPORT virtual void dump(ModelHighAPI_Dumper& theDumper) const;
74
75protected:
76 bool initialize();
77
78private:
79 std::shared_ptr<ModelAPI_Folder> myFolder;
80
81 std::shared_ptr<ModelAPI_AttributeReference> myFirstFeature;
82 std::shared_ptr<ModelAPI_AttributeReference> myLastFeature;
83};
84
85//--------------------------------------------------------------------------------------
89MODELHIGHAPI_EXPORT
90std::shared_ptr<ModelHighAPI_Folder> addFolder(const std::shared_ptr<ModelAPI_Document>& theDoc);
91
95MODELHIGHAPI_EXPORT
96std::shared_ptr<ModelHighAPI_Folder> addFolder(const std::shared_ptr<ModelAPI_Document>& theDoc,
97 const ModelHighAPI_Reference& theFirstFeature,
98 const ModelHighAPI_Reference& theLastFeature);
102MODELHIGHAPI_EXPORT
103void removeFolder(std::shared_ptr<ModelHighAPI_Folder>& theFolder);
104//--------------------------------------------------------------------------------------
105#endif /* SRC_MODELHIGHAPI_MODELHIGHAPI_FOLDER_H_ */
Attribute that contains reference to feature (located in the same document).
Definition: ModelAPI_AttributeReference.h:32
Folder feature ID.
Definition: ModelAPI_Folder.h:38
Dump engine for the model.
Class for filling ModelAPI_Folder.
Definition: ModelHighAPI_Folder.h:39
void setName(const std::wstring &theName)
Shortcut for data()->setName()
Definition: ModelHighAPI_Folder.cpp:62
ModelHighAPI_Folder(const std::shared_ptr< ModelAPI_Folder > &theFolder)
Constructor for a folder.
Definition: ModelHighAPI_Folder.cpp:31
std::shared_ptr< ModelAPI_AttributeReference > lastFeature() const
Last feature reference.
Definition: ModelHighAPI_Folder.h:56
std::shared_ptr< ModelAPI_AttributeReference > firstFeature() const
First feature reference.
Definition: ModelHighAPI_Folder.h:52
To update the folder state.
Definition: ModelHighAPI_Folder.cpp:73
Definition: ModelHighAPI_Folder.cpp:38
Shortcut for data()->name()
Definition: ModelHighAPI_Folder.cpp:68
Class for filling ModelAPI_AttributeReference.
Definition: ModelHighAPI_Reference.h:41
void removeFolder(std::shared_ptr< ModelHighAPI_Folder > &theFolder)
Removes Folder feature.
Definition: ModelHighAPI_Folder.cpp:119
std::shared_ptr< ModelHighAPI_Folder > addFolder(const std::shared_ptr< ModelAPI_Document > &theDoc)
Create empty Folder feature.
Definition: ModelHighAPI_Folder.cpp:95
