Class for filling ModelAPI_Folder. More...
#include <ModelHighAPI_Folder.h>
| ModelHighAPI_Folder (const std::shared_ptr< ModelAPI_Folder > &theFolder) | |
| Constructor for a folder. More... | |
| virtual | ~ModelHighAPI_Folder () |
| Destructor. More... | |
| const std::shared_ptr< ModelAPI_Folder > & | folder () const |
| std::shared_ptr< ModelAPI_AttributeReference > | firstFeature () const |
| First feature reference. More... | |
| std::shared_ptr< ModelAPI_AttributeReference > | lastFeature () const |
| Last feature reference. More... | |
| Shortcut for data()->setName() More... | |
| Shortcut for data()->name() More... | |
| To update the folder state. More... | |
| bool | initialize () |
Protected Attributes | |
explicit |
inline |
inline |
| void ModelHighAPI_Folder::setName | ( | const std::wstring & | theName | ) |
| std::wstring ModelHighAPI_Folder::name | ( | ) | const |
| isForce | start execution of feature instead of sending events Dump wrapped feature |
protectedinherited |
