ParametersAPI_Parameter.h
20#ifndef SRC_PARAMETERSAPI_PARAMETERSAPI_PARAMETER_H_
21#define SRC_PARAMETERSAPI_PARAMETERSAPI_PARAMETER_H_
23//--------------------------------------------------------------------------------------
24#include "ParametersAPI.h"
26#include <ParametersPlugin_Parameter.h>
27
28#include <ModelHighAPI_Interface.h>
29#include <ModelHighAPI_Macro.h>
30//--------------------------------------------------------------------------------------
32//--------------------------------------------------------------------------------------
38{
39public:
41 PARAMETERSAPI_EXPORT
42 explicit ParametersAPI_Parameter(const std::shared_ptr<ModelAPI_Feature> & theFeature);
44 PARAMETERSAPI_EXPORT
45 explicit ParametersAPI_Parameter(const std::shared_ptr<ModelAPI_Feature> & theFeature,
46 const std::string & theName,
47 const std::string & theExpression,
48 const std::wstring & theComment = std::wstring());
50 PARAMETERSAPI_EXPORT
52
60 )
61
62
63 PARAMETERSAPI_EXPORT void setValue(const double theValue);
65 PARAMETERSAPI_EXPORT double value();
66
68 PARAMETERSAPI_EXPORT
69 virtual void dump(ModelHighAPI_Dumper& theDumper) const;
70
71};
72
74typedef std::shared_ptr<ParametersAPI_Parameter> ParameterPtr;
75
79PARAMETERSAPI_EXPORT
80ParameterPtr addParameter(const std::shared_ptr<ModelAPI_Document> & thePart,
81 const std::string & theName,
82 const std::string & theExpression,
83 const std::wstring & theComment = std::wstring());
84
88PARAMETERSAPI_EXPORT
89void removeParameter(const std::shared_ptr<ModelAPI_Document> & thePart,
90 const ParameterPtr & theParameter);
91
92//--------------------------------------------------------------------------------------
93//--------------------------------------------------------------------------------------
94#endif /* SRC_PARAMETERSAPI_PARAMETERSAPI_PARAMETER_H_ */
Dump engine for the model.
Interface for Parameter feature.
Definition: ParametersAPI_Parameter.h:38
virtual ~ParametersAPI_Parameter()
Definition: ParametersAPI_Parameter.cpp:67
virtual std::shared_ptr< ModelAPI_AttributeString > name() const
Name.
Definition: ParametersAPI_Parameter.h:60
ParametersAPI_Parameter(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: ParametersAPI_Parameter.cpp:27
Dump wrapped feature.
Definition: ParametersAPI_Parameter.cpp:71
Just sets the numeric value to the parameter (it resets the previous expression)
Definition: ParametersAPI_Parameter.cpp:51
double value()
Returns the current value of the parameter: the expression result.
Definition: ParametersAPI_Parameter.cpp:60
virtual std::shared_ptr< ModelAPI_AttributeString > comment() const
Comment.
virtual std::shared_ptr< ModelAPI_AttributeString > expression() const
Expression.
Feature kind.
Definition: ParametersPlugin_Parameter.h:39
static const std::string & VARIABLE_ID()
attribute of parameter name
Definition: ParametersPlugin_Parameter.h:45
static const std::string & COMMENT_ID()
return comment attribute Id
Definition: ParametersPlugin_Parameter.h:70
static const std::string & EXPRESSION_ID()
attribute of parameter expression
Definition: ParametersPlugin_Parameter.h:51
ParameterPtr addParameter(const std::shared_ptr< ModelAPI_Document > &thePart, const std::string &theName, const std::string &theExpression, const std::wstring &theComment=std::wstring())
Create Parameter feature.
Definition: ParametersAPI_Parameter.cpp:87
void removeParameter(const std::shared_ptr< ModelAPI_Document > &thePart, const ParameterPtr &theParameter)
Remove Parameter feature and substitute it by the value in referred features.
Definition: ParametersAPI_Parameter.cpp:105
