ParametersAPI_Parameter Class Reference
Interface for Parameter feature. More...
#include <ParametersAPI_Parameter.h>
Inheritance diagram for ParametersAPI_Parameter:
 ParametersAPI_Parameter (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 ParametersAPI_Parameter (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::string &theName, const std::string &theExpression, const std::wstring &theComment=std::wstring())
virtual ~ParametersAPI_Parameter ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeString > name () const
 Name. More...
virtual std::shared_ptr< ModelAPI_AttributeString > expression () const
 Expression. More...
virtual std::shared_ptr< ModelAPI_AttributeString > comment () const
 Comment. More...
void setValue (const double theValue)
 Just sets the numeric value to the parameter (it resets the previous expression) More...
double value ()
 Returns the current value of the parameter: the expression result. More...
 Dump wrapped feature. More...
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeString > myname
std::shared_ptr< ModelAPI_AttributeString > myexpression
std::shared_ptr< ModelAPI_AttributeString > mycomment
◆ ParametersAPI_Parameter() [1/2]
ParametersAPI_Parameter::ParametersAPI_Parameter ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ ParametersAPI_Parameter() [2/2]
ParametersAPI_Parameter::ParametersAPI_Parameter ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const std::string &  theName,
const std::string &  theExpression,
const std::wstring &  theComment = std::wstring()
explicit
◆ ~ParametersAPI_Parameter()
ParametersAPI_Parameter::~ParametersAPI_Parameter ( )
virtual std::shared_ptr< ModelAPI_AttributeString > ParametersAPI_Parameter::name ( ) const
Name.
◆ expression()
virtual std::shared_ptr< ModelAPI_AttributeString > ParametersAPI_Parameter::expression ( ) const
Expression.
◆ comment()
virtual std::shared_ptr< ModelAPI_AttributeString > ParametersAPI_Parameter::comment ( ) const
Comment.
◆ setValue()
void ParametersAPI_Parameter::setValue ( const double  theValue)
◆ value()
double ParametersAPI_Parameter::value ( )
◆ dump()
void ParametersAPI_Parameter::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
