PrimitivesAPI_Torus.h
20// File: PrimitivesAPI_Torus.h
21// Created: 20 Mar 2017
22// Author: Clarisse Genrault
23
24#ifndef PRIMITIVESAPI_TORUS_H_
25#define PRIMITIVESAPI_TORUS_H_
26
27#include "PrimitivesAPI.h"
28
29#include <PrimitivesPlugin_Torus.h>
30
31#include <ModelHighAPI_Interface.h>
32#include <ModelHighAPI_Macro.h>
33
36
41{
42public:
44 PRIMITIVESAPI_EXPORT
45 explicit PrimitivesAPI_Torus(const std::shared_ptr<ModelAPI_Feature>& theFeature);
46
48 PRIMITIVESAPI_EXPORT
49 explicit PrimitivesAPI_Torus(const std::shared_ptr<ModelAPI_Feature>& theFeature,
50 const ModelHighAPI_Selection& theBasePoint,
51 const ModelHighAPI_Selection& theAxis,
52 const ModelHighAPI_Double& theRadius,
53 const ModelHighAPI_Double& theRingRadius);
54
56 PRIMITIVESAPI_EXPORT
57 virtual ~PrimitivesAPI_Torus();
58
59 INTERFACE_4(PrimitivesPlugin_Torus::ID(),
68
69
70 PRIMITIVESAPI_EXPORT
71 void setRadius(const ModelHighAPI_Double& theRadius,
72 const ModelHighAPI_Double& theRingRadius);
73
75 PRIMITIVESAPI_EXPORT
76 virtual void dump(ModelHighAPI_Dumper& theDumper) const;
77};
78
80typedef std::shared_ptr<PrimitivesAPI_Torus> TorusPtr;
81
84PRIMITIVESAPI_EXPORT
85TorusPtr addTorus(const std::shared_ptr<ModelAPI_Document>& thePart,
86 const ModelHighAPI_Selection& theBasePoint,
87 const ModelHighAPI_Selection& theAxis,
88 const ModelHighAPI_Double& theRadius,
89 const ModelHighAPI_Double& theRingRadius);
90
93PRIMITIVESAPI_EXPORT
94TorusPtr addTorus(const std::shared_ptr<ModelAPI_Document>& thePart,
95 const ModelHighAPI_Double& theRadius,
96 const ModelHighAPI_Double& theRingRadius);
97
98#endif // PRIMITIVESAPI_TORUS_H_
Dump engine for the model.
Interface for primitive Torus feature.
Definition: PrimitivesAPI_Torus.h:41
virtual std::shared_ptr< ModelAPI_AttributeSelection > axis() const
Axis.
Definition: PrimitivesAPI_Torus.h:67
Dump wrapped feature.
Definition: PrimitivesAPI_Torus.cpp:67
virtual std::shared_ptr< ModelAPI_AttributeDouble > ringRadius() const
Ring radius.
virtual std::shared_ptr< ModelAPI_AttributeDouble > radius() const
Radius.
virtual std::shared_ptr< ModelAPI_AttributeSelection > basePoint() const
Base point.
PrimitivesAPI_Torus(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: PrimitivesAPI_Torus.cpp:31
void setRadius(const ModelHighAPI_Double &theRadius, const ModelHighAPI_Double &theRingRadius)
Set radius.
Definition: PrimitivesAPI_Torus.cpp:58
Definition: PrimitivesAPI_Torus.cpp:53
static const std::string & BASE_POINT_ID()
Attribute name of the base point.
Definition: PrimitivesPlugin_Torus.h:48
Attribute name of the radius.
Definition: PrimitivesPlugin_Torus.h:62
Torus kind.
Definition: PrimitivesPlugin_Torus.h:41
static const std::string & RING_RADIUS_ID()
Attribute name of the section radius.
Definition: PrimitivesPlugin_Torus.h:69
static const std::string & AXIS_ID()
Attribute name of the axis.
Definition: PrimitivesPlugin_Torus.h:55
TorusPtr addTorus(const std::shared_ptr< ModelAPI_Document > &thePart, const ModelHighAPI_Selection &theBasePoint, const ModelHighAPI_Selection &theAxis, const ModelHighAPI_Double &theRadius, const ModelHighAPI_Double &theRingRadius)
Create primitive Torus feature.
Definition: PrimitivesAPI_Torus.cpp:88
