Interface for primitive Torus feature. More...
#include <PrimitivesAPI_Torus.h>
| PrimitivesAPI_Torus (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| PrimitivesAPI_Torus (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theBasePoint, const ModelHighAPI_Selection &theAxis, const ModelHighAPI_Double &theRadius, const ModelHighAPI_Double &theRingRadius) | |
| virtual | ~PrimitivesAPI_Torus () |
| Destructor. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | basePoint () const |
| Base point. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | axis () const |
| Axis. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | radius () const |
| Radius. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | ringRadius () const |
| Ring radius. More... | |
| void | setRadius (const ModelHighAPI_Double &theRadius, const ModelHighAPI_Double &theRingRadius) |
| Set radius. More... | |
| bool | initialize () |
Protected Attributes | |
| std::shared_ptr< ModelAPI_AttributeSelection > | mybasePoint |
| std::shared_ptr< ModelAPI_AttributeSelection > | myaxis |
| std::shared_ptr< ModelAPI_AttributeDouble > | myradius |
| std::shared_ptr< ModelAPI_AttributeDouble > | myringRadius |
explicit |
explicit |
inlinevirtual |
Base point.
inlinevirtual |
Axis.
inlinevirtual |
Radius.
inlinevirtual |
Ring radius.
| void PrimitivesAPI_Torus::setRadius | ( | const ModelHighAPI_Double & | theRadius, |
| const ModelHighAPI_Double & | theRingRadius | ||
Set radius.
protectedinherited |
