SketchAPI_MacroCircle.h
20#ifndef SketchAPI_MacroCircle_H_
21#define SketchAPI_MacroCircle_H_
23#include "SketchAPI.h"
24#include "SketchAPI_SketchEntity.h"
26#include <SketchPlugin_MacroCircle.h>
27
34{
35public:
37 SKETCHAPI_EXPORT
38 explicit SketchAPI_MacroCircle(const std::shared_ptr<ModelAPI_Feature>& theFeature);
39
41 SKETCHAPI_EXPORT
42 SketchAPI_MacroCircle(const std::shared_ptr<ModelAPI_Feature>& theFeature,
43 double theCenterX,
44 double theCenterY,
45 double thePassedX,
46 double thePassedY,
47 bool theIsToAddPoint = false,
48 double theAngle = 0.0);
49
51 SKETCHAPI_EXPORT
52 SketchAPI_MacroCircle(const std::shared_ptr<ModelAPI_Feature>& theFeature,
53 const std::shared_ptr<GeomAPI_Pnt2d>& theCenterPoint,
54 const std::shared_ptr<GeomAPI_Pnt2d>& thePassedPoint,
55 bool theIsToAddPoint = false,
56 double theAngle = 0.0);
57
59 SKETCHAPI_EXPORT
60 SketchAPI_MacroCircle(const std::shared_ptr<ModelAPI_Feature>& theFeature,
61 double theX1, double theY1,
62 double theX2, double theY2,
63 double theX3, double theY3,
64 bool theIsToAddPoint = false,
65 double theAngle = 0.0);
66
68 SKETCHAPI_EXPORT
69 SketchAPI_MacroCircle(const std::shared_ptr<ModelAPI_Feature>& theFeature,
70 const std::shared_ptr<GeomAPI_Pnt2d>& thePoint1,
71 const std::shared_ptr<GeomAPI_Pnt2d>& thePoint2,
72 const std::shared_ptr<GeomAPI_Pnt2d>& thePoint3,
73 bool theIsToAddPoint = false,
74 double theAngle = 0.0);
75
77 SKETCHAPI_EXPORT
78 virtual ~SketchAPI_MacroCircle();
79
80 INTERFACE_8(SketchPlugin_MacroCircle::ID(),
81 circleType, SketchPlugin_MacroCircle::CIRCLE_TYPE(),
97
98private:
100 void setByCenterAndPassedPoints(double theCenterX, double theCenterY,
101 double thePassedX, double thePassedY,
102 bool theIsToAddPoint = false,
103 double theAngle = 0.0);
104
106 void setByCenterAndPassedPoints(const std::shared_ptr<GeomAPI_Pnt2d>& theCenterPoint,
107 const std::shared_ptr<GeomAPI_Pnt2d>& thePassedPoint,
108 bool theIsToAddPoint = false,
109 double theAngle = 0.0);
110
112 void setByThreePoints(double theX1, double theY1,
113 double theX2, double theY2,
114 double theX3, double theY3,
115 bool theIsToAddPoint = false,
116 double theAngle = 0.0);
117
119 void setByThreePoints(const std::shared_ptr<GeomAPI_Pnt2d>& thePoint1,
120 const std::shared_ptr<GeomAPI_Pnt2d>& thePoint2,
121 const std::shared_ptr<GeomAPI_Pnt2d>& thePoint3,
122 bool theIsToAddPoint = false,
123 double theAngle = 0.0);
124};
125
127typedef std::shared_ptr<SketchAPI_MacroCircle> MacroCirclePtr;
128
129#endif // SketchAPI_MacroCircle_H_
Interface for Circle feature.
Definition: SketchAPI_MacroCircle.h:34
virtual std::shared_ptr< ModelAPI_AttributeBoolean > addpoint() const
Is to add point.
Definition: SketchAPI_MacroCircle.h:96
virtual std::shared_ptr< GeomDataAPI_Point2D > thirdPoint() const
Third point.
virtual std::shared_ptr< GeomDataAPI_Point2D > passedPoint() const
Passed point.
virtual std::shared_ptr< GeomDataAPI_Point2D > firstPoint() const
First point.
Definition: SketchAPI_MacroCircle.cpp:96
virtual std::shared_ptr< ModelAPI_AttributeDouble > angle() const
Angle.
virtual std::shared_ptr< GeomDataAPI_Point2D > centerPoint() const
Center point.
virtual std::shared_ptr< GeomDataAPI_Point2D > secondPoint() const
Second point.
SketchAPI_MacroCircle(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: SketchAPI_MacroCircle.cpp:33
virtual std::shared_ptr< ModelAPI_AttributeString > circleType() const
Circle type.
static const std::string & CENTER_POINT_ID()
2D point - center of the circle.
Definition: SketchPlugin_MacroCircle.h:77
static const std::string & THIRD_POINT_ID()
Third point id.
Definition: SketchPlugin_MacroCircle.h:133
static const std::string & SECOND_POINT_ID()
Second point id.
Definition: SketchPlugin_MacroCircle.h:119
static const std::string & FIRST_POINT_ID()
First point id.
Definition: SketchPlugin_MacroCircle.h:105
static const std::string & ADD_CONSTRUCTION_POINT_ID()
Is to create construction point or not.
Definition: SketchPlugin_MacroCircle.h:154
static const std::string & PASSED_POINT_ID()
2D point - passed point of the circle
Definition: SketchPlugin_MacroCircle.h:91
static const std::string & CIRCLE_ROTATE_ANGLE_ID()
Rotate angle of the circle.
Definition: SketchPlugin_MacroCircle.h:161
Circle feature kind.
Definition: SketchPlugin_MacroCircle.h:44
