Base class for Sketch feature interfaces. More...
#include <SketchAPI_SketchEntity.h>
| SketchAPI_SketchEntity (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| virtual | ~SketchAPI_SketchEntity () |
| Destructor. More... | |
| std::shared_ptr< ModelAPI_AttributeBoolean > | auxiliary () const |
| Auxiliary. More... | |
| void | setAuxiliary (bool theAuxiliary) |
| Set auxiliary. More... | |
| static std::list< std::shared_ptr< SketchAPI_SketchEntity > > | wrap (const std::list< std::shared_ptr< ModelAPI_Feature > > &theFeatures) |
| Convert list of features to list of appropriate wrappers. More... | |
| bool | initialize () |
| bool | isCopy () const |
| Check the entity is a copy of another feature. More... | |
Protected Attributes | |
| std::shared_ptr< ModelAPI_AttributeBoolean > | myAuxiliary |
explicit |
| std::shared_ptr< ModelAPI_AttributeBoolean > SketchAPI_SketchEntity::auxiliary | ( | ) | const |
Auxiliary.
| void SketchAPI_SketchEntity::setAuxiliary | ( | bool | theAuxiliary | ) |
Set auxiliary.
Reimplemented in SketchAPI_Arc, SketchAPI_BSpline, SketchAPI_Circle, SketchAPI_Ellipse, SketchAPI_EllipticArc, SketchAPI_IntersectionPoint, SketchAPI_Line, SketchAPI_Point, and SketchAPI_Projection.
static |
protected |
protectedinherited |
