SketchAPI_Arc Class Reference
Interface for Arc feature. More...
#include <SketchAPI_Arc.h>
Inheritance diagram for SketchAPI_Arc:
 SketchAPI_Arc (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 SketchAPI_Arc (const std::shared_ptr< ModelAPI_Feature > &theFeature, double theCenterX, double theCenterY, double theStartX, double theStartY, double theEndX, double theEndY, bool theInversed)
 SketchAPI_Arc (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::shared_ptr< GeomAPI_Pnt2d > &theCenter, const std::shared_ptr< GeomAPI_Pnt2d > &theStart, const std::shared_ptr< GeomAPI_Pnt2d > &theEnd, bool theInversed)
 SketchAPI_Arc (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theExternal)
 SketchAPI_Arc (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::wstring &theExternalName)
virtual ~SketchAPI_Arc ()
virtual std::string getID ()
virtual std::shared_ptr< GeomDataAPI_Point2D > center () const
 Center point. More...
virtual std::shared_ptr< GeomDataAPI_Point2D > startPoint () const
 Start point. More...
virtual std::shared_ptr< GeomDataAPI_Point2D > endPoint () const
 End point. More...
virtual std::shared_ptr< ModelAPI_AttributeBoolean > reversed () const
 Inversed flag. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > radius () const
 Radius. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > angle () const
 Angle. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > external () const
 External. More...
void setByCenterStartEnd (double theCenterX, double theCenterY, double theStartX, double theStartY, double theEndX, double theEndY, bool theInversed)
 Set by center and start, end point. More...
void setByCenterStartEnd (const std::shared_ptr< GeomAPI_Pnt2d > &theCenter, const std::shared_ptr< GeomAPI_Pnt2d > &theStart, const std::shared_ptr< GeomAPI_Pnt2d > &theEnd, bool theInversed)
void setByExternal (const ModelHighAPI_Selection &theExternal)
 Set by external. More...
void setByExternalName (const std::wstring &theExternalName)
 Set by external name. More...
 Dump wrapped feature. More...
std::shared_ptr< ModelAPI_AttributeBoolean > auxiliary () const
 Auxiliary. More...
void setAuxiliary (bool theAuxiliary)
 Set auxiliary. More...
std::wstring name () const
static std::string ID ()
static std::list< std::shared_ptr< SketchAPI_SketchEntity > > wrap (const std::list< std::shared_ptr< ModelAPI_Feature > > &theFeatures)
 Convert list of features to list of appropriate wrappers. More...
bool initialize ()
bool isCopy () const
 Check the entity is a copy of another feature. More...
std::shared_ptr< GeomDataAPI_Point2D > mycenter
std::shared_ptr< GeomDataAPI_Point2D > mystartPoint
std::shared_ptr< GeomDataAPI_Point2D > myendPoint
std::shared_ptr< ModelAPI_AttributeBoolean > myreversed
std::shared_ptr< ModelAPI_AttributeDouble > myradius
std::shared_ptr< ModelAPI_AttributeDouble > myangle
std::shared_ptr< ModelAPI_AttributeSelection > myexternal
std::shared_ptr< ModelAPI_AttributeBoolean > myAuxiliary
◆ SketchAPI_Arc() [1/5]
SketchAPI_Arc::SketchAPI_Arc ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ SketchAPI_Arc() [2/5]
SketchAPI_Arc::SketchAPI_Arc ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
double  theCenterX,
double  theCenterY,
double  theStartX,
double  theStartY,
double  theEndX,
double  theEndY,
bool  theInversed
◆ SketchAPI_Arc() [3/5]
const std::shared_ptr< GeomAPI_Pnt2d > &  theCenter,
const std::shared_ptr< GeomAPI_Pnt2d > &  theStart,
const std::shared_ptr< GeomAPI_Pnt2d > &  theEnd,
bool  theInversed
◆ SketchAPI_Arc() [4/5]
const ModelHighAPI_Selection &  theExternal
◆ SketchAPI_Arc() [5/5]
const std::wstring &  theExternalName
◆ ~SketchAPI_Arc()
SketchAPI_Arc::~SketchAPI_Arc ( )
◆ center()
virtual std::shared_ptr< GeomDataAPI_Point2D > SketchAPI_Arc::center ( ) const
Center point.
◆ startPoint()
virtual std::shared_ptr< GeomDataAPI_Point2D > SketchAPI_Arc::startPoint ( ) const
Start point.
◆ endPoint()
virtual std::shared_ptr< GeomDataAPI_Point2D > SketchAPI_Arc::endPoint ( ) const
End point.
◆ reversed()
virtual std::shared_ptr< ModelAPI_AttributeBoolean > SketchAPI_Arc::reversed ( ) const
Inversed flag.
◆ radius()
virtual std::shared_ptr< ModelAPI_AttributeDouble > SketchAPI_Arc::radius ( ) const
Radius.
◆ angle()
virtual std::shared_ptr< ModelAPI_AttributeDouble > SketchAPI_Arc::angle ( ) const
Angle.
◆ external()
virtual std::shared_ptr< ModelAPI_AttributeSelection > SketchAPI_Arc::external ( ) const
External.
◆ setByCenterStartEnd() [1/2]
void SketchAPI_Arc::setByCenterStartEnd ( double  theCenterX,
double  theCenterY,
double  theStartX,
double  theStartY,
double  theEndX,
double  theEndY,
bool  theInversed
◆ setByCenterStartEnd() [2/2]
void SketchAPI_Arc::setByCenterStartEnd ( const std::shared_ptr< GeomAPI_Pnt2d > &  theCenter,
bool  theInversed
◆ setByExternal()
void SketchAPI_Arc::setByExternal ( const ModelHighAPI_Selection &  theExternal)
Set by external.
◆ setByExternalName()
void SketchAPI_Arc::setByExternalName ( const std::wstring &  theExternalName)
◆ dump()
void SketchAPI_Arc::dump ( ModelHighAPI_Dumper &  theDumper) const
Reimplemented from SketchAPI_SketchEntity.
◆ auxiliary()
std::shared_ptr< ModelAPI_AttributeBoolean > SketchAPI_SketchEntity::auxiliary ( ) const
Auxiliary.
◆ setAuxiliary()
void SketchAPI_SketchEntity::setAuxiliary ( bool  theAuxiliary)
Set auxiliary.
◆ wrap()
std::list< std::shared_ptr< SketchAPI_SketchEntity > > SketchAPI_SketchEntity::wrap ( const std::list< std::shared_ptr< ModelAPI_Feature > > &  theFeatures)
◆ isCopy()
bool SketchAPI_SketchEntity::isCopy ( ) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
