SketchAPI_Arc.h
20#ifndef SketchAPI_Arc_H_
21#define SketchAPI_Arc_H_
23#include "SketchAPI.h"
24#include "SketchAPI_SketchEntity.h"
26#include <GeomDataAPI_Point2D.h>
27
28#include <SketchPlugin_Arc.h>
32
37{
38public:
40 SKETCHAPI_EXPORT
41 explicit SketchAPI_Arc(const std::shared_ptr<ModelAPI_Feature>& theFeature);
42
44 SKETCHAPI_EXPORT
45 SketchAPI_Arc(const std::shared_ptr<ModelAPI_Feature>& theFeature,
46 double theCenterX, double theCenterY,
47 double theStartX, double theStartY,
48 double theEndX, double theEndY,
49 bool theInversed);
50
52 SKETCHAPI_EXPORT
53 SketchAPI_Arc(const std::shared_ptr<ModelAPI_Feature>& theFeature,
54 const std::shared_ptr<GeomAPI_Pnt2d>& theCenter,
55 const std::shared_ptr<GeomAPI_Pnt2d>& theStart,
56 const std::shared_ptr<GeomAPI_Pnt2d>& theEnd,
57 bool theInversed);
58
60 SKETCHAPI_EXPORT
61 SketchAPI_Arc(const std::shared_ptr<ModelAPI_Feature>& theFeature,
62 const ModelHighAPI_Selection& theExternal);
63
65 SKETCHAPI_EXPORT
66 SketchAPI_Arc(const std::shared_ptr<ModelAPI_Feature>& theFeature,
67 const std::wstring& theExternalName);
68
70 SKETCHAPI_EXPORT
71 virtual ~SketchAPI_Arc();
72
73 INTERFACE_7(SketchPlugin_Arc::ID(),
88
89
90 SKETCHAPI_EXPORT
91 void setByCenterStartEnd(double theCenterX, double theCenterY,
92 double theStartX, double theStartY,
93 double theEndX, double theEndY,
94 bool theInversed);
95
97 SKETCHAPI_EXPORT
98 void setByCenterStartEnd(const std::shared_ptr<GeomAPI_Pnt2d>& theCenter,
99 const std::shared_ptr<GeomAPI_Pnt2d>& theStart,
100 const std::shared_ptr<GeomAPI_Pnt2d>& theEnd,
101 bool theInversed);
102
104 SKETCHAPI_EXPORT
105 void setByExternal(const ModelHighAPI_Selection& theExternal);
106
108 SKETCHAPI_EXPORT
109 void setByExternalName(const std::wstring& theExternalName);
110
112 SKETCHAPI_EXPORT
113 virtual void dump(ModelHighAPI_Dumper& theDumper) const;
114};
115
117typedef std::shared_ptr<SketchAPI_Arc> ArcPtr;
118
119#endif // SketchAPI_Arc_H_
Dump engine for the model.
Class for filling ModelAPI_AttributeRefAttr.
Definition: ModelHighAPI_RefAttr.h:41
Interface for Arc feature.
Definition: SketchAPI_Arc.h:37
virtual std::shared_ptr< ModelAPI_AttributeDouble > radius() const
Radius.
Definition: SketchAPI_Arc.h:87
virtual std::shared_ptr< GeomDataAPI_Point2D > endPoint() const
End point.
void setByCenterStartEnd(double theCenterX, double theCenterY, double theStartX, double theStartY, double theEndX, double theEndY, bool theInversed)
Set by center and start, end point.
Definition: SketchAPI_Arc.cpp:93
virtual std::shared_ptr< ModelAPI_AttributeDouble > angle() const
Angle.
virtual std::shared_ptr< GeomDataAPI_Point2D > startPoint() const
Start point.
void setByExternal(const ModelHighAPI_Selection &theExternal)
Set by external.
Definition: SketchAPI_Arc.cpp:121
virtual std::shared_ptr< GeomDataAPI_Point2D > center() const
Center point.
virtual std::shared_ptr< ModelAPI_AttributeBoolean > reversed() const
Inversed flag.
void setByExternalName(const std::wstring &theExternalName)
Set by external name.
Definition: SketchAPI_Arc.cpp:129
virtual std::shared_ptr< ModelAPI_AttributeSelection > external() const
External.
SketchAPI_Arc(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: SketchAPI_Arc.cpp:33
Definition: SketchAPI_Arc.cpp:87
Dump wrapped feature.
Definition: SketchAPI_Arc.cpp:137
static const std::string & CENTER_ID()
Central 2D point of the circle which contains the arc.
Definition: SketchPlugin_Arc.h:47
static const std::string & START_ID()
Start 2D point of the arc.
Definition: SketchPlugin_Arc.h:54
static const std::string & REVERSED_ID()
Reversed flag.
Definition: SketchPlugin_Arc.h:82
Arc radius.
Definition: SketchPlugin_Arc.h:68
static const std::string & END_ID()
End 2D point of the arc.
Definition: SketchPlugin_Arc.h:61
static const std::string & ANGLE_ID()
Arc angle.
Definition: SketchPlugin_Arc.h:75
Arc feature kind.
Definition: SketchPlugin_Arc.h:40
static const std::string & EXTERNAL_ID()
Reference to the external edge or vertex as a AttributeSelection.
Definition: SketchPlugin_SketchEntity.h:55
