SketchAPI_Line Class Reference
Interface for Line feature. More...
#include <SketchAPI_Line.h>
Inheritance diagram for SketchAPI_Line:
 SketchAPI_Line (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 SketchAPI_Line (const std::shared_ptr< ModelAPI_Feature > &theFeature, double theX1, double theY1, double theX2, double theY2)
 SketchAPI_Line (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::shared_ptr< GeomAPI_Pnt2d > &theStartPoint, const std::shared_ptr< GeomAPI_Pnt2d > &theEndPoint)
 SketchAPI_Line (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theExternal)
 SketchAPI_Line (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::wstring &theExternalName)
virtual ~SketchAPI_Line ()
virtual std::string getID ()
virtual std::shared_ptr< GeomDataAPI_Point2D > startPoint () const
 Start point. More...
virtual std::shared_ptr< GeomDataAPI_Point2D > endPoint () const
 End point. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > external () const
 External. More...
void setByCoordinates (double theX1, double theY1, double theX2, double theY2)
 Set by coordinates. More...
void setByPoints (const std::shared_ptr< GeomAPI_Pnt2d > &theStartPoint, const std::shared_ptr< GeomAPI_Pnt2d > &theEndPoint)
 Set by points. More...
void setByExternal (const ModelHighAPI_Selection &theExternal)
 Set by external. More...
void setByExternalName (const std::wstring &theExternalName)
 Set by external name. More...
void setStartPoint (double theX, double theY)
 Set start point. More...
void setStartPoint (const std::shared_ptr< GeomAPI_Pnt2d > &thePoint)
void setEndPoint (double theX, double theY)
 Set end point. More...
void setEndPoint (const std::shared_ptr< GeomAPI_Pnt2d > &thePoint)
 Dump wrapped feature. More...
std::shared_ptr< ModelAPI_AttributeBoolean > auxiliary () const
 Auxiliary. More...
void setAuxiliary (bool theAuxiliary)
 Set auxiliary. More...
std::wstring name () const
static std::string ID ()
static std::list< std::shared_ptr< SketchAPI_SketchEntity > > wrap (const std::list< std::shared_ptr< ModelAPI_Feature > > &theFeatures)
 Convert list of features to list of appropriate wrappers. More...
bool initialize ()
bool isCopy () const
 Check the entity is a copy of another feature. More...
std::shared_ptr< GeomDataAPI_Point2D > mystartPoint
std::shared_ptr< GeomDataAPI_Point2D > myendPoint
std::shared_ptr< ModelAPI_AttributeSelection > myexternal
std::shared_ptr< ModelAPI_AttributeBoolean > myAuxiliary
◆ SketchAPI_Line() [1/5]
SketchAPI_Line::SketchAPI_Line ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ SketchAPI_Line() [2/5]
SketchAPI_Line::SketchAPI_Line ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
double  theX1,
double  theY1,
double  theX2,
double  theY2
◆ SketchAPI_Line() [3/5]
const std::shared_ptr< GeomAPI_Pnt2d > &  theStartPoint,
const std::shared_ptr< GeomAPI_Pnt2d > &  theEndPoint
◆ SketchAPI_Line() [4/5]
const ModelHighAPI_Selection &  theExternal
◆ SketchAPI_Line() [5/5]
const std::wstring &  theExternalName
◆ ~SketchAPI_Line()
SketchAPI_Line::~SketchAPI_Line ( )
◆ startPoint()
virtual std::shared_ptr< GeomDataAPI_Point2D > SketchAPI_Line::startPoint ( ) const
Start point.
◆ endPoint()
virtual std::shared_ptr< GeomDataAPI_Point2D > SketchAPI_Line::endPoint ( ) const
End point.
◆ external()
virtual std::shared_ptr< ModelAPI_AttributeSelection > SketchAPI_Line::external ( ) const
External.
◆ setByCoordinates()
void SketchAPI_Line::setByCoordinates ( double  theX1,
double  theY1,
double  theX2,
double  theY2
Set by coordinates.
◆ setByPoints()
void SketchAPI_Line::setByPoints ( const std::shared_ptr< GeomAPI_Pnt2d > &  theStartPoint,
Set by points.
◆ setByExternal()
void SketchAPI_Line::setByExternal ( const ModelHighAPI_Selection &  theExternal)
Set by external.
◆ setByExternalName()
void SketchAPI_Line::setByExternalName ( const std::wstring &  theExternalName)
◆ setStartPoint() [1/2]
void SketchAPI_Line::setStartPoint ( double  theX,
double  theY
Set start point.
◆ setStartPoint() [2/2]
void SketchAPI_Line::setStartPoint ( const std::shared_ptr< GeomAPI_Pnt2d > &  thePoint)
Set start point.
◆ setEndPoint() [1/2]
void SketchAPI_Line::setEndPoint ( double  theX,
double  theY
Set end point.
◆ setEndPoint() [2/2]
void SketchAPI_Line::setEndPoint ( const std::shared_ptr< GeomAPI_Pnt2d > &  thePoint)
Set end point.
◆ dump()
void SketchAPI_Line::dump ( ModelHighAPI_Dumper &  theDumper) const
Reimplemented from SketchAPI_SketchEntity.
◆ auxiliary()
std::shared_ptr< ModelAPI_AttributeBoolean > SketchAPI_SketchEntity::auxiliary ( ) const
Auxiliary.
◆ setAuxiliary()
void SketchAPI_SketchEntity::setAuxiliary ( bool  theAuxiliary)
Set auxiliary.
◆ wrap()
std::list< std::shared_ptr< SketchAPI_SketchEntity > > SketchAPI_SketchEntity::wrap ( const std::list< std::shared_ptr< ModelAPI_Feature > > &  theFeatures)
◆ isCopy()
bool SketchAPI_SketchEntity::isCopy ( ) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
