Interface for Elliptic Arc feature. More...
#include <SketchAPI_EllipticArc.h>
| SketchAPI_EllipticArc (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| SketchAPI_EllipticArc (const std::shared_ptr< ModelAPI_Feature > &theFeature, double theCenterX, double theCenterY, double theFocusX, double theFocusY, double theStartX, double theStartY, double theEndX, double theEndY, bool theInversed) | |
| SketchAPI_EllipticArc (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::shared_ptr< GeomAPI_Pnt2d > &theCenter, const std::shared_ptr< GeomAPI_Pnt2d > &theFocus, const std::shared_ptr< GeomAPI_Pnt2d > &theStart, const std::shared_ptr< GeomAPI_Pnt2d > &theEnd, bool theInversed) | |
| SketchAPI_EllipticArc (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theExternal) | |
| Constructor with external. More... | |
| SketchAPI_EllipticArc (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::wstring &theExternalName) | |
| virtual | ~SketchAPI_EllipticArc () |
| Destructor. More... | |
| virtual std::shared_ptr< GeomDataAPI_Point2D > | center () const |
| Center point. More... | |
| virtual std::shared_ptr< GeomDataAPI_Point2D > | startPoint () const |
| Start point of elliptic arc. More... | |
| virtual std::shared_ptr< GeomDataAPI_Point2D > | endPoint () const |
| End point of elliptic arc. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeBoolean > | reversed () const |
| Inversed flag. More... | |
| virtual std::shared_ptr< GeomDataAPI_Point2D > | firstFocus () const |
| Focus in positive direction of a major axis. More... | |
| virtual std::shared_ptr< GeomDataAPI_Point2D > | secondFocus () const |
| Focus in negative direction of a major axis. More... | |
| virtual std::shared_ptr< GeomDataAPI_Point2D > | majorAxisNegative () const |
| Start point of major axis. More... | |
| virtual std::shared_ptr< GeomDataAPI_Point2D > | majorAxisPositive () const |
| End point of major axis. More... | |
| virtual std::shared_ptr< GeomDataAPI_Point2D > | minorAxisNegative () const |
| Start point of minor axis. More... | |
| virtual std::shared_ptr< GeomDataAPI_Point2D > | minorAxisPositive () const |
| End point of minor axis. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | majorRadius () const |
| Major radius. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | minorRadius () const |
| Minor radius. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | external () const |
| External. More... | |
| void | setByCenterFocusAndPoints (double theCenterX, double theCenterY, double theFocusX, double theFocusY, double theStartX, double theStartY, double theEndX, double theEndY, bool theInversed) |
| Set by center, focus and radius. More... | |
| void | setByCenterFocusAndPoints (const std::shared_ptr< GeomAPI_Pnt2d > &theCenter, const std::shared_ptr< GeomAPI_Pnt2d > &theFocus, const std::shared_ptr< GeomAPI_Pnt2d > &theStart, const std::shared_ptr< GeomAPI_Pnt2d > &theEnd, bool theInversed) |
| void | setByExternal (const ModelHighAPI_Selection &theExternal) |
| Set by external. More... | |
| void | setByExternalName (const std::wstring &theExternalName) |
| Set by external name. More... | |
| void | setCenter (double theX, double theY) |
| Set center. More... | |
| void | setCenter (const std::shared_ptr< GeomAPI_Pnt2d > &theCenter) |
| void | setFocus (double theX, double theY) |
| Set focus. More... | |
| void | setFocus (const std::shared_ptr< GeomAPI_Pnt2d > &theFocus) |
| std::list< std::shared_ptr< SketchAPI_SketchEntity > > | construction (const std::wstring ¢er=std::wstring(), const std::wstring &firstFocus=std::wstring(), const std::wstring &secondFocus=std::wstring(), const std::wstring &majorAxisStart=std::wstring(), const std::wstring &majorAxisEnd=std::wstring(), const std::wstring &minorAxisStart=std::wstring(), const std::wstring &minorAxisEnd=std::wstring(), const std::wstring &majorAxis=std::wstring(), const std::wstring &minorAxis=std::wstring()) const |
| Create construction elements (focuses, axes etc.). More... | |
| std::shared_ptr< ModelAPI_AttributeBoolean > | auxiliary () const |
| Auxiliary. More... | |
| void | setAuxiliary (bool theAuxiliary) |
| Set auxiliary. More... | |
| static std::list< std::shared_ptr< SketchAPI_SketchEntity > > | wrap (const std::list< std::shared_ptr< ModelAPI_Feature > > &theFeatures) |
| Convert list of features to list of appropriate wrappers. More... | |
| bool | initialize () |
| bool | isCopy () const |
| Check the entity is a copy of another feature. More... | |
Protected Attributes | |
| std::shared_ptr< GeomDataAPI_Point2D > | mycenter |
| std::shared_ptr< GeomDataAPI_Point2D > | mystartPoint |
| std::shared_ptr< GeomDataAPI_Point2D > | myendPoint |
| std::shared_ptr< ModelAPI_AttributeBoolean > | myreversed |
| std::shared_ptr< GeomDataAPI_Point2D > | myfirstFocus |
| std::shared_ptr< GeomDataAPI_Point2D > | mysecondFocus |
| std::shared_ptr< GeomDataAPI_Point2D > | mymajorAxisNegative |
| std::shared_ptr< GeomDataAPI_Point2D > | mymajorAxisPositive |
| std::shared_ptr< GeomDataAPI_Point2D > | myminorAxisNegative |
| std::shared_ptr< GeomDataAPI_Point2D > | myminorAxisPositive |
| std::shared_ptr< ModelAPI_AttributeDouble > | mymajorRadius |
| std::shared_ptr< ModelAPI_AttributeDouble > | myminorRadius |
| std::shared_ptr< ModelAPI_AttributeSelection > | myexternal |
| std::shared_ptr< ModelAPI_AttributeBoolean > | myAuxiliary |
explicit |
| SketchAPI_EllipticArc::SketchAPI_EllipticArc | ( | const std::shared_ptr< ModelAPI_Feature > & | theFeature, |
| double | theCenterX, | ||
| double | theCenterY, | ||
| double | theFocusX, | ||
| double | theFocusY, | ||
| double | theStartX, | ||
| double | theStartY, | ||
| double | theEndX, | ||
| double | theEndY, | ||
| bool | theInversed | ||
| const std::shared_ptr< GeomAPI_Pnt2d > & | theCenter, | ||
| const std::shared_ptr< GeomAPI_Pnt2d > & | theFocus, | ||
| const std::shared_ptr< GeomAPI_Pnt2d > & | theStart, | ||
| const std::shared_ptr< GeomAPI_Pnt2d > & | theEnd, | ||
| const ModelHighAPI_Selection & | theExternal | ||
| const std::wstring & | theExternalName | ||
inlinevirtual |
Center point.
inlinevirtual |
inlinevirtual |
inlinevirtual |
Inversed flag.
inlinevirtual |
inlinevirtual |
inlinevirtual |
inlinevirtual |
inlinevirtual |
inlinevirtual |
inlinevirtual |
Major radius.
inlinevirtual |
Minor radius.
inlinevirtual |
External.
| void SketchAPI_EllipticArc::setByCenterFocusAndPoints | ( | double | theCenterX, |
| void SketchAPI_EllipticArc::setByCenterFocusAndPoints | ( | const std::shared_ptr< GeomAPI_Pnt2d > & | theCenter, |
| void SketchAPI_EllipticArc::setByExternal | ( | const ModelHighAPI_Selection & | theExternal | ) |
Set by external.
| void SketchAPI_EllipticArc::setByExternalName | ( | const std::wstring & | theExternalName | ) |
| void SketchAPI_EllipticArc::setCenter | ( | double | theX, |
| double | theY | ||
Set center.
| void SketchAPI_EllipticArc::setCenter | ( | const std::shared_ptr< GeomAPI_Pnt2d > & | theCenter | ) |
Set center.
| void SketchAPI_EllipticArc::setFocus | ( | double | theX, |
| double | theY | ||
Set focus.
| void SketchAPI_EllipticArc::setFocus | ( | const std::shared_ptr< GeomAPI_Pnt2d > & | theFocus | ) |
Set focus.
| std::list< std::shared_ptr< SketchAPI_SketchEntity > > SketchAPI_EllipticArc::construction | ( | const std::wstring & | center = std::wstring(), |
| const std::wstring & | firstFocus = std::wstring(), |
| const std::wstring & | secondFocus = std::wstring(), |
| const std::wstring & | majorAxisStart = std::wstring(), |
| const std::wstring & | majorAxisEnd = std::wstring(), |
| const std::wstring & | minorAxisStart = std::wstring(), |
| const std::wstring & | minorAxisEnd = std::wstring(), |
| const std::wstring & | majorAxis = std::wstring(), |
| const std::wstring & | minorAxis = std::wstring() |
| ) | const |
Empty value for each parameter shows that the corresponding feature has been removed. Value "aux" marks this feature as auxiliary. And the name of the feature shows that it is a regular feature.
Reimplemented from SketchAPI_SketchEntity.
Auxiliary.
Set auxiliary.
staticinherited |
protectedinherited |
