SketchAPI_EllipticArc.h
20#ifndef SketchAPI_EllipticArc_H_
21#define SketchAPI_EllipticArc_H_
23#include "SketchAPI.h"
24#include "SketchAPI_SketchEntity.h"
26#include <SketchPlugin_EllipticArc.h>
27
34{
35public:
37 SKETCHAPI_EXPORT
38 explicit SketchAPI_EllipticArc(const std::shared_ptr<ModelAPI_Feature>& theFeature);
39
41 SKETCHAPI_EXPORT
42 SketchAPI_EllipticArc(const std::shared_ptr<ModelAPI_Feature>& theFeature,
43 double theCenterX, double theCenterY,
44 double theFocusX, double theFocusY,
45 double theStartX, double theStartY,
46 double theEndX, double theEndY,
47 bool theInversed);
48
50 SKETCHAPI_EXPORT
51 SketchAPI_EllipticArc(const std::shared_ptr<ModelAPI_Feature>& theFeature,
52 const std::shared_ptr<GeomAPI_Pnt2d>& theCenter,
53 const std::shared_ptr<GeomAPI_Pnt2d>& theFocus,
54 const std::shared_ptr<GeomAPI_Pnt2d>& theStart,
55 const std::shared_ptr<GeomAPI_Pnt2d>& theEnd,
56 bool theInversed);
57
59 SKETCHAPI_EXPORT
60 SketchAPI_EllipticArc(const std::shared_ptr<ModelAPI_Feature>& theFeature,
61 const ModelHighAPI_Selection& theExternal);
62
64 SKETCHAPI_EXPORT
65 SketchAPI_EllipticArc(const std::shared_ptr<ModelAPI_Feature>& theFeature,
66 const std::wstring& theExternalName);
67
69 SKETCHAPI_EXPORT
70 virtual ~SketchAPI_EllipticArc();
71
72 INTERFACE_13(SketchPlugin_EllipticArc::ID(),
99
100
101 SKETCHAPI_EXPORT
102 void setByCenterFocusAndPoints(double theCenterX, double theCenterY,
103 double theFocusX, double theFocusY,
104 double theStartX, double theStartY,
105 double theEndX, double theEndY,
106 bool theInversed);
107
109 SKETCHAPI_EXPORT
110 void setByCenterFocusAndPoints(const std::shared_ptr<GeomAPI_Pnt2d>& theCenter,
111 const std::shared_ptr<GeomAPI_Pnt2d>& theFocus,
112 const std::shared_ptr<GeomAPI_Pnt2d>& theStart,
113 const std::shared_ptr<GeomAPI_Pnt2d>& theEnd,
114 bool theInversed);
115
117 SKETCHAPI_EXPORT
118 void setByExternal(const ModelHighAPI_Selection& theExternal);
119
121 SKETCHAPI_EXPORT
122 void setByExternalName(const std::wstring& theExternalName);
123
125 SKETCHAPI_EXPORT
126 void setCenter(double theX, double theY);
127
129 SKETCHAPI_EXPORT
130 void setCenter(const std::shared_ptr<GeomAPI_Pnt2d> & theCenter);
131
133 SKETCHAPI_EXPORT
134 void setFocus(double theX, double theY);
135
137 SKETCHAPI_EXPORT
138 void setFocus(const std::shared_ptr<GeomAPI_Pnt2d> & theFocus);
139
144 SKETCHAPI_EXPORT
145 std::list<std::shared_ptr<SketchAPI_SketchEntity> > construction(
146 const std::wstring& center = std::wstring(),
147 const std::wstring& firstFocus = std::wstring(),
148 const std::wstring& secondFocus = std::wstring(),
149 const std::wstring& majorAxisStart = std::wstring(),
150 const std::wstring& majorAxisEnd = std::wstring(),
151 const std::wstring& minorAxisStart = std::wstring(),
152 const std::wstring& minorAxisEnd = std::wstring(),
153 const std::wstring& majorAxis = std::wstring(),
154 const std::wstring& minorAxis = std::wstring()) const;
155
157 SKETCHAPI_EXPORT
158 virtual void dump(ModelHighAPI_Dumper& theDumper) const;
159};
160
162typedef std::shared_ptr<SketchAPI_EllipticArc> EllipticArcPtr;
163
164#endif // SketchAPI_EllipticArc_H_
Dump engine for the model.
Interface for Elliptic Arc feature.
Definition: SketchAPI_EllipticArc.h:34
Definition: SketchAPI_EllipticArc.cpp:85
virtual std::shared_ptr< GeomDataAPI_Point2D > majorAxisNegative() const
Start point of major axis.
Definition: SketchAPI_EllipticArc.h:98
Set center.
Definition: SketchAPI_EllipticArc.cpp:134
virtual std::shared_ptr< ModelAPI_AttributeDouble > majorRadius() const
Major radius.
SketchAPI_EllipticArc(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: SketchAPI_EllipticArc.cpp:34
void setByExternal(const ModelHighAPI_Selection &theExternal)
Set by external.
Definition: SketchAPI_EllipticArc.cpp:122
Set focus.
Definition: SketchAPI_EllipticArc.cpp:146
virtual std::shared_ptr< GeomDataAPI_Point2D > minorAxisPositive() const
End point of minor axis.
virtual std::shared_ptr< GeomDataAPI_Point2D > firstFocus() const
Focus in positive direction of a major axis.
virtual std::shared_ptr< ModelAPI_AttributeSelection > external() const
External.
virtual std::shared_ptr< GeomDataAPI_Point2D > majorAxisPositive() const
End point of major axis.
void setByCenterFocusAndPoints(double theCenterX, double theCenterY, double theFocusX, double theFocusY, double theStartX, double theStartY, double theEndX, double theEndY, bool theInversed)
Set by center, focus and radius.
Definition: SketchAPI_EllipticArc.cpp:89
virtual std::shared_ptr< GeomDataAPI_Point2D > startPoint() const
Start point of elliptic arc.
Dump wrapped feature.
Definition: SketchAPI_EllipticArc.cpp:207
std::list< std::shared_ptr< SketchAPI_SketchEntity > > construction(const std::wstring &center=std::wstring(), const std::wstring &firstFocus=std::wstring(), const std::wstring &secondFocus=std::wstring(), const std::wstring &majorAxisStart=std::wstring(), const std::wstring &majorAxisEnd=std::wstring(), const std::wstring &minorAxisStart=std::wstring(), const std::wstring &minorAxisEnd=std::wstring(), const std::wstring &majorAxis=std::wstring(), const std::wstring &minorAxis=std::wstring()) const
Create construction elements (focuses, axes etc.).
Definition: SketchAPI_EllipticArc.cpp:180
virtual std::shared_ptr< GeomDataAPI_Point2D > secondFocus() const
Focus in negative direction of a major axis.
virtual std::shared_ptr< ModelAPI_AttributeBoolean > reversed() const
Inversed flag.
virtual std::shared_ptr< ModelAPI_AttributeDouble > minorRadius() const
Minor radius.
virtual std::shared_ptr< GeomDataAPI_Point2D > center() const
Center point.
void setByExternalName(const std::wstring &theExternalName)
Set by external name.
Definition: SketchAPI_EllipticArc.cpp:128
virtual std::shared_ptr< GeomDataAPI_Point2D > endPoint() const
End point of elliptic arc.
virtual std::shared_ptr< GeomDataAPI_Point2D > minorAxisNegative() const
Start point of minor axis.
static const std::string & MINOR_AXIS_END_ID()
2D point - end point of minor axis
Definition: SketchPlugin_EllipticArc.h:93
static const std::string & REVERSED_ID()
Flag the arc is reversed.
Definition: SketchPlugin_EllipticArc.h:114
static const std::string & MAJOR_RADIUS_ID()
Major radius of the ellipse.
Definition: SketchPlugin_EllipticArc.h:100
static const std::string & MAJOR_AXIS_START_ID()
2D point - start point of major axis
Definition: SketchPlugin_EllipticArc.h:74
static const std::string & END_POINT_ID()
2D point - end point of elliptic arc
Definition: SketchPlugin_EllipticArc.h:54
static const std::string & MINOR_RADIUS_ID()
Minor radius of the ellipse.
Definition: SketchPlugin_EllipticArc.h:107
static const std::string & FIRST_FOCUS_ID()
2D point - focus of the ellipse
Definition: SketchPlugin_EllipticArc.h:61
static const std::string & START_POINT_ID()
2D point - start point of elliptic arc
Definition: SketchPlugin_EllipticArc.h:48
static const std::string & MAJOR_AXIS_END_ID()
2D point - end point of major axis
Definition: SketchPlugin_EllipticArc.h:80
static const std::string & SECOND_FOCUS_ID()
2D point - second focus of the ellipse
Definition: SketchPlugin_EllipticArc.h:67
Ellipse feature kind.
Definition: SketchPlugin_EllipticArc.h:34
static const std::string & CENTER_ID()
2D point - center of the ellipse
Definition: SketchPlugin_EllipticArc.h:41
static const std::string & MINOR_AXIS_START_ID()
2D point - start point of minor axis
Definition: SketchPlugin_EllipticArc.h:87
static const std::string & EXTERNAL_ID()
Reference to the external edge or vertex as a AttributeSelection.
Definition: SketchPlugin_SketchEntity.h:55
