Interface for BSpline feature. More...
#include <SketchAPI_BSpline.h>
| SketchAPI_BSpline (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| virtual | ~SketchAPI_BSpline () |
| Destructor. More... | |
| virtual std::shared_ptr< GeomDataAPI_Point2DArray > | poles () const |
| B-spline poles. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeDoubleArray > | weights () const |
| B-spline weights. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeDoubleArray > | knots () const |
| B-spline knots. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeIntArray > | multiplicities () const |
| Knots multiplicities. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeInteger > | degree () const |
| B-spline degree. More... | |
| virtual std::shared_ptr< GeomDataAPI_Point2D > | startPoint () const |
| First pole of B-spline. More... | |
| virtual std::shared_ptr< GeomDataAPI_Point2D > | endPoint () const |
| Last pole of B-spline. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | external () const |
| External. More... | |
| void | setByDegreePolesAndWeights (const ModelHighAPI_Integer &theDegree, const std::list< std::shared_ptr< GeomAPI_Pnt2d > > &thePoles, const std::list< ModelHighAPI_Double > &theWeights) |
| Set by poles and weights. More... | |
| void | setByParameters (const ModelHighAPI_Integer &theDegree, const std::list< std::shared_ptr< GeomAPI_Pnt2d > > &thePoles, const std::list< ModelHighAPI_Double > &theWeights, const std::list< ModelHighAPI_Double > &theKnots, const std::list< ModelHighAPI_Integer > &theMults) |
| Initialize by full set of B-spline parameters. More... | |
| void | setByExternal (const ModelHighAPI_Selection &theExternal) |
| Set by external. More... | |
| std::list< std::shared_ptr< SketchAPI_SketchEntity > > | controlPoles (const std::list< int > ®ular=std::list< int >(), const std::list< int > &auxiliary=std::list< int >()) const |
| Generate list of construction points coincident with B-spline poles. More... | |
| std::list< std::shared_ptr< SketchAPI_SketchEntity > > | controlPolygon (const std::list< int > ®ular=std::list< int >(), const std::list< int > &auxiliary=std::list< int >()) const |
| Generate control polygon for B-spline curve. More... | |
| bool | insertPole (const int theIndex, const std::shared_ptr< GeomAPI_Pnt2d > &theCoordinates, const ModelHighAPI_Double &theWeight=ModelHighAPI_Double(1.0)) |
| Insert new pole after the pole with the given index. More... | |
| std::shared_ptr< ModelAPI_AttributeBoolean > | auxiliary () const |
| Auxiliary. More... | |
| void | setAuxiliary (bool theAuxiliary) |
| Set auxiliary. More... | |
| static std::list< std::shared_ptr< SketchAPI_SketchEntity > > | wrap (const std::list< std::shared_ptr< ModelAPI_Feature > > &theFeatures) |
| Convert list of features to list of appropriate wrappers. More... | |
| bool | initialize () |
| SketchAPI_BSpline (const std::shared_ptr< ModelAPI_Feature > &theFeature, bool theInitialize) | |
| bool | isCopy () const |
| Check the entity is a copy of another feature. More... | |
Protected Attributes | |
| std::shared_ptr< GeomDataAPI_Point2DArray > | mypoles |
| std::shared_ptr< ModelAPI_AttributeDoubleArray > | myweights |
| std::shared_ptr< ModelAPI_AttributeDoubleArray > | myknots |
| std::shared_ptr< ModelAPI_AttributeIntArray > | mymultiplicities |
| std::shared_ptr< ModelAPI_AttributeInteger > | mydegree |
| std::shared_ptr< GeomDataAPI_Point2D > | mystartPoint |
| std::shared_ptr< GeomDataAPI_Point2D > | myendPoint |
| std::shared_ptr< ModelAPI_AttributeSelection > | myexternal |
| std::shared_ptr< ModelAPI_AttributeBoolean > | myAuxiliary |
explicit |
inlinevirtual |
B-spline poles.
inlinevirtual |
B-spline weights.
inlinevirtual |
B-spline knots.
inlinevirtual |
inlinevirtual |
B-spline degree.
inlinevirtual |
inlinevirtual |
inlinevirtual |
External.
| void SketchAPI_BSpline::setByDegreePolesAndWeights | ( | const ModelHighAPI_Integer & | theDegree, |
| const std::list< std::shared_ptr< GeomAPI_Pnt2d > > & | thePoles, | ||
| const std::list< ModelHighAPI_Double > & | theWeights | ||
| void SketchAPI_BSpline::setByParameters | ( | const ModelHighAPI_Integer & | theDegree, |
| const std::list< ModelHighAPI_Double > & | theWeights, | ||
| const std::list< ModelHighAPI_Double > & | theKnots, | ||
| const std::list< ModelHighAPI_Integer > & | theMults | ||
| void SketchAPI_BSpline::setByExternal | ( | const ModelHighAPI_Selection & | theExternal | ) |
Set by external.
| std::list< std::shared_ptr< SketchAPI_SketchEntity > > SketchAPI_BSpline::controlPoles | ( | const std::list< int > & | regular = std::list<int>(), |
| const std::list< int > & | auxiliary = std::list<int>() |
| ) | const |
| std::list< std::shared_ptr< SketchAPI_SketchEntity > > SketchAPI_BSpline::controlPolygon | ( | const std::list< int > & | regular = std::list<int>(), |
| ) | const |
| bool SketchAPI_BSpline::insertPole | ( | const int | theIndex, |
| const std::shared_ptr< GeomAPI_Pnt2d > & | theCoordinates, | ||
| const ModelHighAPI_Double & | theWeight = ModelHighAPI_Double(1.0) |
Reimplemented from SketchAPI_SketchEntity.
Auxiliary.
Set auxiliary.
staticinherited |
protectedinherited |
