Interface for IntersectionPoint feature. More...
#include <SketchAPI_IntersectionPoint.h>
| SketchAPI_IntersectionPoint (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| SketchAPI_IntersectionPoint (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theExternal) | |
| SketchAPI_IntersectionPoint (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::wstring &theExternalName) | |
| virtual | ~SketchAPI_IntersectionPoint () |
| Destructor. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | externalFeature () const |
| External edge. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | external () const |
| External. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeBoolean > | includeToResult () const |
| Include into result. More... | |
| void | setByExternalEdge (const ModelHighAPI_Selection &theExternaEdge) |
| Set by external. More... | |
| void | setByExternalEdgeName (const std::wstring &theExternalEdgeName) |
| Set by external name. More... | |
| void | setIncludeToResult (bool theKeepResult) |
| Set flag to include projection to result or not. More... | |
| std::list< std::shared_ptr< SketchAPI_SketchEntity > > | intersectionPoints () const |
| Returns created intersection points. More... | |
| std::shared_ptr< ModelAPI_AttributeBoolean > | auxiliary () const |
| Auxiliary. More... | |
| void | setAuxiliary (bool theAuxiliary) |
| Set auxiliary. More... | |
| static std::list< std::shared_ptr< SketchAPI_SketchEntity > > | wrap (const std::list< std::shared_ptr< ModelAPI_Feature > > &theFeatures) |
| Convert list of features to list of appropriate wrappers. More... | |
| bool | initialize () |
| bool | isCopy () const |
| Check the entity is a copy of another feature. More... | |
Protected Attributes | |
| std::shared_ptr< ModelAPI_AttributeSelection > | myexternalFeature |
| std::shared_ptr< ModelAPI_AttributeSelection > | myexternal |
| std::shared_ptr< ModelAPI_AttributeBoolean > | myincludeToResult |
| std::shared_ptr< ModelAPI_AttributeBoolean > | myAuxiliary |
explicit |
| SketchAPI_IntersectionPoint::SketchAPI_IntersectionPoint | ( | const std::shared_ptr< ModelAPI_Feature > & | theFeature, |
| const ModelHighAPI_Selection & | theExternal | ||
| const std::wstring & | theExternalName | ||
inlinevirtual |
External edge.
inlinevirtual |
External.
inlinevirtual |
| void SketchAPI_IntersectionPoint::setByExternalEdge | ( | const ModelHighAPI_Selection & | theExternaEdge | ) |
Set by external.
| void SketchAPI_IntersectionPoint::setByExternalEdgeName | ( | const std::wstring & | theExternalEdgeName | ) |
| void SketchAPI_IntersectionPoint::setIncludeToResult | ( | bool | theKeepResult | ) |
| std::list< std::shared_ptr< SketchAPI_SketchEntity > > SketchAPI_IntersectionPoint::intersectionPoints | ( | ) | const |
Reimplemented from SketchAPI_SketchEntity.
Auxiliary.
Set auxiliary.
staticinherited |
protectedinherited |
