SketchAPI_Projection Class Reference
Interface for Projection feature. More...
#include <SketchAPI_Projection.h>
Inheritance diagram for SketchAPI_Projection:
 SketchAPI_Projection (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 SketchAPI_Projection (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theExternalFeature)
virtual ~SketchAPI_Projection ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeSelection > externalFeature () const
 External feature. More...
virtual std::shared_ptr< ModelAPI_AttributeRefAttr > projectedFeature () const
 Projected feature. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > external () const
 External. More...
virtual std::shared_ptr< ModelAPI_AttributeBoolean > includeToResult () const
 Include into result. More...
void setExternalFeature (const ModelHighAPI_Selection &theExternalLine)
 Set external feature. More...
void setIncludeToResult (bool theKeepResult)
 Set flag to include projection to result or not. More...
void setKeepReferenceToOriginal (bool theKeepRefToOriginal)
 Set flag to keep the reference to the original shape. More...
std::shared_ptr< SketchAPI_SketchEntity > createdFeature () const
 Returns created feature. More...
 Dump wrapped feature. More...
std::shared_ptr< ModelAPI_AttributeBoolean > auxiliary () const
 Auxiliary. More...
void setAuxiliary (bool theAuxiliary)
 Set auxiliary. More...
std::wstring name () const
static std::string ID ()
static std::list< std::shared_ptr< SketchAPI_SketchEntity > > wrap (const std::list< std::shared_ptr< ModelAPI_Feature > > &theFeatures)
 Convert list of features to list of appropriate wrappers. More...
bool initialize ()
bool isCopy () const
 Check the entity is a copy of another feature. More...
std::shared_ptr< ModelAPI_AttributeSelection > myexternalFeature
std::shared_ptr< ModelAPI_AttributeRefAttr > myprojectedFeature
std::shared_ptr< ModelAPI_AttributeBoolean > myincludeToResult
std::shared_ptr< ModelAPI_AttributeBoolean > myAuxiliary
◆ SketchAPI_Projection() [1/2]
SketchAPI_Projection::SketchAPI_Projection ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ SketchAPI_Projection() [2/2]
SketchAPI_Projection::SketchAPI_Projection ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const ModelHighAPI_Selection &  theExternalFeature
◆ ~SketchAPI_Projection()
SketchAPI_Projection::~SketchAPI_Projection ( )
◆ externalFeature()
virtual std::shared_ptr< ModelAPI_AttributeSelection > SketchAPI_Projection::externalFeature ( ) const
External feature.
◆ projectedFeature()
virtual std::shared_ptr< ModelAPI_AttributeRefAttr > SketchAPI_Projection::projectedFeature ( ) const
Projected feature.
◆ external()
virtual std::shared_ptr< ModelAPI_AttributeSelection > SketchAPI_Projection::external ( ) const
External.
◆ includeToResult()
virtual std::shared_ptr< ModelAPI_AttributeBoolean > SketchAPI_Projection::includeToResult ( ) const
◆ setExternalFeature()
void SketchAPI_Projection::setExternalFeature ( const ModelHighAPI_Selection &  theExternalLine)
◆ setIncludeToResult()
void SketchAPI_Projection::setIncludeToResult ( bool  theKeepResult)
◆ setKeepReferenceToOriginal()
void SketchAPI_Projection::setKeepReferenceToOriginal ( bool  theKeepRefToOriginal)
◆ createdFeature()
std::shared_ptr< SketchAPI_SketchEntity > SketchAPI_Projection::createdFeature ( ) const
◆ dump()
void SketchAPI_Projection::dump ( ModelHighAPI_Dumper &  theDumper) const
Reimplemented from SketchAPI_SketchEntity.
◆ auxiliary()
std::shared_ptr< ModelAPI_AttributeBoolean > SketchAPI_SketchEntity::auxiliary ( ) const
Auxiliary.
◆ setAuxiliary()
void SketchAPI_SketchEntity::setAuxiliary ( bool  theAuxiliary)
Set auxiliary.
◆ wrap()
std::list< std::shared_ptr< SketchAPI_SketchEntity > > SketchAPI_SketchEntity::wrap ( const std::list< std::shared_ptr< ModelAPI_Feature > > &  theFeatures)
◆ isCopy()
bool SketchAPI_SketchEntity::isCopy ( ) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
