SketchAPI_Projection.h
20#ifndef SRC_SKETCHAPI_SKETCHAPI_PROJECTION_H_
21#define SRC_SKETCHAPI_SKETCHAPI_PROJECTION_H_
23//--------------------------------------------------------------------------------------
24#include "SketchAPI.h"
26#include <SketchPlugin_Projection.h>
27
28#include "SketchAPI_SketchEntity.h"
29//--------------------------------------------------------------------------------------
31//--------------------------------------------------------------------------------------
37{
38public:
40 SKETCHAPI_EXPORT
41 explicit SketchAPI_Projection(const std::shared_ptr<ModelAPI_Feature> & theFeature);
43 SKETCHAPI_EXPORT
44 SketchAPI_Projection(const std::shared_ptr<ModelAPI_Feature> & theFeature,
45 const ModelHighAPI_Selection & theExternalFeature);
47 SKETCHAPI_EXPORT
48 virtual ~SketchAPI_Projection();
49
50 INTERFACE_4(SketchPlugin_Projection::ID(),
51 externalFeature, SketchPlugin_Projection::EXTERNAL_FEATURE_ID(),
53 projectedFeature, SketchPlugin_Projection::PROJECTED_FEATURE_ID(),
57 includeToResult, SketchPlugin_Projection::INCLUDE_INTO_RESULT(),
59 )
60
61
62 SKETCHAPI_EXPORT
63 void setExternalFeature(const ModelHighAPI_Selection & theExternalLine);
64
66 SKETCHAPI_EXPORT
67 void setIncludeToResult(bool theKeepResult);
68
70 SKETCHAPI_EXPORT
71 void setKeepReferenceToOriginal(bool theKeepRefToOriginal);
72
74 SKETCHAPI_EXPORT
75 std::shared_ptr<SketchAPI_SketchEntity> createdFeature() const;
76
78 SKETCHAPI_EXPORT
79 virtual void dump(ModelHighAPI_Dumper& theDumper) const;
80};
81
83typedef std::shared_ptr<SketchAPI_Projection> ProjectionPtr;
84
85//--------------------------------------------------------------------------------------
86//--------------------------------------------------------------------------------------
87#endif /* SRC_SKETCHAPI_SKETCHAPI_PROJECTION_H_ */
Attribute that contains reference to an attribute of a feature or reference to a feature (switchable)
Definition: ModelAPI_AttributeRefAttr.h:33
Dump engine for the model.
Interface for Projection feature.
Definition: SketchAPI_Projection.h:37
Dump wrapped feature.
Definition: SketchAPI_Projection.cpp:120
std::shared_ptr< SketchAPI_SketchEntity > createdFeature() const
Returns created feature.
Definition: SketchAPI_Projection.cpp:88
Definition: SketchAPI_Projection.cpp:59
SketchAPI_Projection(const std::shared_ptr< ModelAPI_Feature > &theFeature)
Constructor without values.
Definition: SketchAPI_Projection.cpp:42
virtual std::shared_ptr< ModelAPI_AttributeSelection > externalFeature() const
External feature.
Definition: SketchAPI_Projection.h:59
virtual std::shared_ptr< ModelAPI_AttributeBoolean > includeToResult() const
Include into result.
Set flag to include projection to result or not.
Definition: SketchAPI_Projection.cpp:72
Set flag to keep the reference to the original shape.
Definition: SketchAPI_Projection.cpp:78
virtual std::shared_ptr< ModelAPI_AttributeSelection > external() const
External.
virtual std::shared_ptr< ModelAPI_AttributeRefAttr > projectedFeature() const
Projected feature.
void setExternalFeature(const ModelHighAPI_Selection &theExternalLine)
Set external feature.
Definition: SketchAPI_Projection.cpp:65
Projection feature kind.
Definition: SketchPlugin_Projection.h:35
static const std::string & EXTERNAL_ID()
Reference to the external edge or vertex as a AttributeSelection.
Definition: SketchPlugin_SketchEntity.h:55
