SketchAPI_Point Class Reference
Interface for Point feature. More...
#include <SketchAPI_Point.h>
Inheritance diagram for SketchAPI_Point:
 SketchAPI_Point (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 SketchAPI_Point (const std::shared_ptr< ModelAPI_Feature > &theFeature, double theX, double theY)
 SketchAPI_Point (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::shared_ptr< GeomAPI_Pnt2d > &thePoint)
 SketchAPI_Point (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theExternal)
 SketchAPI_Point (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::wstring &theExternalName)
virtual ~SketchAPI_Point ()
virtual std::string getID ()
virtual std::shared_ptr< GeomDataAPI_Point2D > coordinates () const
 Point coordinates. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > external () const
 External. More...
void setCoordinates (double theX, double theY)
 Set by coordinates. More...
void setCoordinates (const std::shared_ptr< GeomAPI_Pnt2d > &thePoint)
 Set by points. More...
void setByExternal (const ModelHighAPI_Selection &theExternal)
 Set by external. More...
void setByExternalName (const std::wstring &theExternalName)
 Set by external name. More...
 Dump wrapped feature. More...
std::shared_ptr< ModelAPI_AttributeBoolean > auxiliary () const
 Auxiliary. More...
void setAuxiliary (bool theAuxiliary)
 Set auxiliary. More...
std::wstring name () const
static std::string ID ()
static std::list< std::shared_ptr< SketchAPI_SketchEntity > > wrap (const std::list< std::shared_ptr< ModelAPI_Feature > > &theFeatures)
 Convert list of features to list of appropriate wrappers. More...
bool initialize ()
bool isCopy () const
 Check the entity is a copy of another feature. More...
std::shared_ptr< GeomDataAPI_Point2D > mycoordinates
std::shared_ptr< ModelAPI_AttributeSelection > myexternal
std::shared_ptr< ModelAPI_AttributeBoolean > myAuxiliary
◆ SketchAPI_Point() [1/5]
SketchAPI_Point::SketchAPI_Point ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ SketchAPI_Point() [2/5]
SketchAPI_Point::SketchAPI_Point ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
double  theX,
double  theY
◆ SketchAPI_Point() [3/5]
const std::shared_ptr< GeomAPI_Pnt2d > &  thePoint
◆ SketchAPI_Point() [4/5]
const ModelHighAPI_Selection &  theExternal
◆ SketchAPI_Point() [5/5]
const std::wstring &  theExternalName
◆ ~SketchAPI_Point()
SketchAPI_Point::~SketchAPI_Point ( )
◆ coordinates()
virtual std::shared_ptr< GeomDataAPI_Point2D > SketchAPI_Point::coordinates ( ) const
Point coordinates.
◆ external()
virtual std::shared_ptr< ModelAPI_AttributeSelection > SketchAPI_Point::external ( ) const
External.
◆ setCoordinates() [1/2]
void SketchAPI_Point::setCoordinates ( double  theX,
double  theY
Set by coordinates.
◆ setCoordinates() [2/2]
void SketchAPI_Point::setCoordinates ( const std::shared_ptr< GeomAPI_Pnt2d > &  thePoint)
Set by points.
◆ setByExternal()
void SketchAPI_Point::setByExternal ( const ModelHighAPI_Selection &  theExternal)
Set by external.
◆ setByExternalName()
void SketchAPI_Point::setByExternalName ( const std::wstring &  theExternalName)
◆ dump()
void SketchAPI_Point::dump ( ModelHighAPI_Dumper &  theDumper) const
Reimplemented from SketchAPI_SketchEntity.
◆ auxiliary()
std::shared_ptr< ModelAPI_AttributeBoolean > SketchAPI_SketchEntity::auxiliary ( ) const
Auxiliary.
◆ setAuxiliary()
void SketchAPI_SketchEntity::setAuxiliary ( bool  theAuxiliary)
Set auxiliary.
◆ wrap()
std::list< std::shared_ptr< SketchAPI_SketchEntity > > SketchAPI_SketchEntity::wrap ( const std::list< std::shared_ptr< ModelAPI_Feature > > &  theFeatures)
◆ isCopy()
bool SketchAPI_SketchEntity::isCopy ( ) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
