Interface for Circle feature. More...
#include <SketchAPI_Circle.h>
| SketchAPI_Circle (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| SketchAPI_Circle (const std::shared_ptr< ModelAPI_Feature > &theFeature, double theCenterX, double theCenterY, double theRadius, bool theIsAddPoint=false, double theAngle=0.0) | |
| SketchAPI_Circle (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::shared_ptr< GeomAPI_Pnt2d > &theCenter, double theRadius, bool theIsAddPoint=false, double theAngle=0.0) | |
| SketchAPI_Circle (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theExternal) | |
| SketchAPI_Circle (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::wstring &theExternalName) | |
| virtual | ~SketchAPI_Circle () |
| Destructor. More... | |
| virtual std::shared_ptr< GeomDataAPI_Point2D > | center () const |
| Center point. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | radius () const |
| Radius. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | external () const |
| External. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | angle () const |
| Angle. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeBoolean > | addpoint () const |
| Is to add point. More... | |
| void | setByCenterAndRadius (double theCenterX, double theCenterY, double theRadius, bool theIsAddPoint=false, double theAngle=0.0) |
| Set by center and radius. More... | |
| void | setByCenterAndRadius (const std::shared_ptr< GeomAPI_Pnt2d > &theCenter, double theRadius, bool theIsAddPoint=false, double theAngle=0.0) |
| void | setByExternal (const ModelHighAPI_Selection &theExternal) |
| Set by external. More... | |
| void | setByExternalName (const std::wstring &theExternalName) |
| Set by external name. More... | |
| void | setCenter (double theX, double theY) |
| Set center. More... | |
| void | setCenter (const std::shared_ptr< GeomAPI_Pnt2d > &theCenter) |
| void | setRadius (double theRadius) |
| Set radius. More... | |
| void | setAngle (double theAngle) |
| Set angle. More... | |
| void | setIsToAddPoint (bool theIsToAddPoint) |
| Set is to add point. More... | |
| std::shared_ptr< SketchAPI_SketchEntity > | createdPoint () const |
| Returns created points on circle. More... | |
| std::shared_ptr< ModelAPI_AttributeBoolean > | auxiliary () const |
| Auxiliary. More... | |
| void | setAuxiliary (bool theAuxiliary) |
| Set auxiliary. More... | |
| static std::list< std::shared_ptr< SketchAPI_SketchEntity > > | wrap (const std::list< std::shared_ptr< ModelAPI_Feature > > &theFeatures) |
| Convert list of features to list of appropriate wrappers. More... | |
| bool | initialize () |
| bool | isCopy () const |
| Check the entity is a copy of another feature. More... | |
Protected Attributes | |
| std::shared_ptr< GeomDataAPI_Point2D > | mycenter |
| std::shared_ptr< ModelAPI_AttributeDouble > | myradius |
| std::shared_ptr< ModelAPI_AttributeSelection > | myexternal |
| std::shared_ptr< ModelAPI_AttributeDouble > | myangle |
| std::shared_ptr< ModelAPI_AttributeBoolean > | myaddpoint |
| std::shared_ptr< ModelAPI_AttributeBoolean > | myAuxiliary |
explicit |
| SketchAPI_Circle::SketchAPI_Circle | ( | const std::shared_ptr< ModelAPI_Feature > & | theFeature, |
| double | theCenterX, | ||
| double | theCenterY, | ||
| double | theRadius, | ||
| bool | theIsAddPoint = false, |
| double | theAngle = 0.0 |
| const std::shared_ptr< GeomAPI_Pnt2d > & | theCenter, | ||
| const ModelHighAPI_Selection & | theExternal | ||
| const std::wstring & | theExternalName | ||
inlinevirtual |
Center point.
inlinevirtual |
Radius.
inlinevirtual |
External.
inlinevirtual |
Angle.
inlinevirtual |
Is to add point.
| void SketchAPI_Circle::setByCenterAndRadius | ( | double | theCenterX, |
| void SketchAPI_Circle::setByCenterAndRadius | ( | const std::shared_ptr< GeomAPI_Pnt2d > & | theCenter, |
| void SketchAPI_Circle::setByExternal | ( | const ModelHighAPI_Selection & | theExternal | ) |
Set by external.
| void SketchAPI_Circle::setByExternalName | ( | const std::wstring & | theExternalName | ) |
| void SketchAPI_Circle::setCenter | ( | double | theX, |
| double | theY | ||
Set center.
| void SketchAPI_Circle::setCenter | ( | const std::shared_ptr< GeomAPI_Pnt2d > & | theCenter | ) |
Set center.
| void SketchAPI_Circle::setRadius | ( | double | theRadius | ) |
Set radius.
| void SketchAPI_Circle::setAngle | ( | double | theAngle | ) |
Set angle.
| void SketchAPI_Circle::setIsToAddPoint | ( | bool | theIsToAddPoint | ) |
| std::shared_ptr< SketchAPI_SketchEntity > SketchAPI_Circle::createdPoint | ( | ) | const |
Reimplemented from SketchAPI_SketchEntity.
Auxiliary.
Set auxiliary.
staticinherited |
protectedinherited |
