SketchAPI_MacroCircle Class Reference
Interface for Circle feature. More...
#include <SketchAPI_MacroCircle.h>
Inheritance diagram for SketchAPI_MacroCircle:
 SketchAPI_MacroCircle (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 SketchAPI_MacroCircle (const std::shared_ptr< ModelAPI_Feature > &theFeature, double theCenterX, double theCenterY, double thePassedX, double thePassedY, bool theIsToAddPoint=false, double theAngle=0.0)
 SketchAPI_MacroCircle (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::shared_ptr< GeomAPI_Pnt2d > &theCenterPoint, const std::shared_ptr< GeomAPI_Pnt2d > &thePassedPoint, bool theIsToAddPoint=false, double theAngle=0.0)
 SketchAPI_MacroCircle (const std::shared_ptr< ModelAPI_Feature > &theFeature, double theX1, double theY1, double theX2, double theY2, double theX3, double theY3, bool theIsToAddPoint=false, double theAngle=0.0)
 SketchAPI_MacroCircle (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::shared_ptr< GeomAPI_Pnt2d > &thePoint1, const std::shared_ptr< GeomAPI_Pnt2d > &thePoint2, const std::shared_ptr< GeomAPI_Pnt2d > &thePoint3, bool theIsToAddPoint=false, double theAngle=0.0)
virtual ~SketchAPI_MacroCircle ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeString > circleType () const
 Circle type. More...
virtual std::shared_ptr< GeomDataAPI_Point2D > centerPoint () const
 Center point. More...
virtual std::shared_ptr< GeomDataAPI_Point2D > passedPoint () const
 Passed point. More...
virtual std::shared_ptr< GeomDataAPI_Point2D > firstPoint () const
 First point. More...
virtual std::shared_ptr< GeomDataAPI_Point2D > secondPoint () const
 Second point. More...
virtual std::shared_ptr< GeomDataAPI_Point2D > thirdPoint () const
 Third point. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > angle () const
 Angle. More...
virtual std::shared_ptr< ModelAPI_AttributeBoolean > addpoint () const
 Is to add point. More...
std::shared_ptr< ModelAPI_AttributeBoolean > auxiliary () const
 Auxiliary. More...
void setAuxiliary (bool theAuxiliary)
 Set auxiliary. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
static std::list< std::shared_ptr< SketchAPI_SketchEntity > > wrap (const std::list< std::shared_ptr< ModelAPI_Feature > > &theFeatures)
 Convert list of features to list of appropriate wrappers. More...
bool initialize ()
bool isCopy () const
 Check the entity is a copy of another feature. More...
std::shared_ptr< ModelAPI_AttributeString > mycircleType
std::shared_ptr< GeomDataAPI_Point2D > mycenterPoint
std::shared_ptr< GeomDataAPI_Point2D > mypassedPoint
std::shared_ptr< GeomDataAPI_Point2D > myfirstPoint
std::shared_ptr< GeomDataAPI_Point2D > mysecondPoint
std::shared_ptr< GeomDataAPI_Point2D > mythirdPoint
std::shared_ptr< ModelAPI_AttributeDouble > myangle
std::shared_ptr< ModelAPI_AttributeBoolean > myaddpoint
std::shared_ptr< ModelAPI_AttributeBoolean > myAuxiliary
◆ SketchAPI_MacroCircle() [1/5]
SketchAPI_MacroCircle::SketchAPI_MacroCircle ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ SketchAPI_MacroCircle() [2/5]
SketchAPI_MacroCircle::SketchAPI_MacroCircle ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
double  theCenterX,
double  theCenterY,
double  thePassedX,
double  thePassedY,
bool  theIsToAddPoint = false,
double  theAngle = 0.0
◆ SketchAPI_MacroCircle() [3/5]
const std::shared_ptr< GeomAPI_Pnt2d > &  theCenterPoint,
const std::shared_ptr< GeomAPI_Pnt2d > &  thePassedPoint,
◆ SketchAPI_MacroCircle() [4/5]
double  theX1,
double  theY1,
double  theX2,
double  theY2,
double  theX3,
double  theY3,
◆ SketchAPI_MacroCircle() [5/5]
const std::shared_ptr< GeomAPI_Pnt2d > &  thePoint1,
const std::shared_ptr< GeomAPI_Pnt2d > &  thePoint2,
const std::shared_ptr< GeomAPI_Pnt2d > &  thePoint3,
◆ ~SketchAPI_MacroCircle()
SketchAPI_MacroCircle::~SketchAPI_MacroCircle ( )
◆ circleType()
virtual std::shared_ptr< ModelAPI_AttributeString > SketchAPI_MacroCircle::circleType ( ) const
Circle type.
◆ centerPoint()
virtual std::shared_ptr< GeomDataAPI_Point2D > SketchAPI_MacroCircle::centerPoint ( ) const
Center point.
◆ passedPoint()
virtual std::shared_ptr< GeomDataAPI_Point2D > SketchAPI_MacroCircle::passedPoint ( ) const
Passed point.
◆ firstPoint()
virtual std::shared_ptr< GeomDataAPI_Point2D > SketchAPI_MacroCircle::firstPoint ( ) const
First point.
◆ secondPoint()
virtual std::shared_ptr< GeomDataAPI_Point2D > SketchAPI_MacroCircle::secondPoint ( ) const
Second point.
◆ thirdPoint()
virtual std::shared_ptr< GeomDataAPI_Point2D > SketchAPI_MacroCircle::thirdPoint ( ) const
Third point.
◆ angle()
virtual std::shared_ptr< ModelAPI_AttributeDouble > SketchAPI_MacroCircle::angle ( ) const
Angle.
◆ addpoint()
virtual std::shared_ptr< ModelAPI_AttributeBoolean > SketchAPI_MacroCircle::addpoint ( ) const
Is to add point.
◆ auxiliary()
std::shared_ptr< ModelAPI_AttributeBoolean > SketchAPI_SketchEntity::auxiliary ( ) const
Auxiliary.
◆ setAuxiliary()
void SketchAPI_SketchEntity::setAuxiliary ( bool  theAuxiliary)
Set auxiliary.
◆ dump()
void SketchAPI_SketchEntity::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ wrap()
std::list< std::shared_ptr< SketchAPI_SketchEntity > > SketchAPI_SketchEntity::wrap ( const std::list< std::shared_ptr< ModelAPI_Feature > > &  theFeatures)
◆ isCopy()
bool SketchAPI_SketchEntity::isCopy ( ) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
