BuildAPI_SubShapes Class Reference
Interface for SubShapes feature. More...
#include <BuildAPI_SubShapes.h>
Inheritance diagram for BuildAPI_SubShapes:
 BuildAPI_SubShapes (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 BuildAPI_SubShapes (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theBaseShape, const std::list< ModelHighAPI_Selection > &theSubShapes)
virtual ~BuildAPI_SubShapes ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeSelection > baseShape () const
 Base shape. More...
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > subShapes () const
 Sub-shapes. More...
void setBaseShape (const ModelHighAPI_Selection &theBaseShape)
 Modify base attribute of the feature. More...
void setSubShapes (const std::list< ModelHighAPI_Selection > &theSubShapes)
 Modify sub-shapes attribute of the feature. More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeSelection > mybaseShape
std::shared_ptr< ModelAPI_AttributeSelectionList > mysubShapes
◆ BuildAPI_SubShapes() [1/2]
BuildAPI_SubShapes::BuildAPI_SubShapes ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ BuildAPI_SubShapes() [2/2]
BuildAPI_SubShapes::BuildAPI_SubShapes ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const ModelHighAPI_Selection &  theBaseShape,
const std::list< ModelHighAPI_Selection > &  theSubShapes
explicit
◆ ~BuildAPI_SubShapes()
BuildAPI_SubShapes::~BuildAPI_SubShapes ( )
◆ baseShape()
virtual std::shared_ptr< ModelAPI_AttributeSelection > BuildAPI_SubShapes::baseShape ( ) const
Base shape.
◆ subShapes()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > BuildAPI_SubShapes::subShapes ( ) const
Sub-shapes.
◆ setBaseShape()
void BuildAPI_SubShapes::setBaseShape ( const ModelHighAPI_Selection &  theBaseShape)
◆ setSubShapes()
void BuildAPI_SubShapes::setSubShapes ( const std::list< ModelHighAPI_Selection > &  theSubShapes)
◆ dump()
void BuildAPI_SubShapes::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
