Interface for Glue Faces feature. More...
#include <FeaturesAPI_GlueFaces.h>
| FeaturesAPI_GlueFaces (const std::shared_ptr< ModelAPI_Feature > &theFeature) | |
| FeaturesAPI_GlueFaces (const std::shared_ptr< ModelAPI_Feature > &theFeature, const std::list< ModelHighAPI_Selection > &theMainObjects, const ModelHighAPI_Double &theTolerance, bool theIsKeepNonSolids=true) | |
| virtual | ~FeaturesAPI_GlueFaces () |
| Destructor. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelectionList > | mainObjects () const |
| Main objects. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeDouble > | tolerance () const |
| Tolerance. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeBoolean > | keepNonSolids () const |
| Keep all non-solid shapes. More... | |
| void | setMainObjects (const std::list< ModelHighAPI_Selection > &theMainObjects) |
| Set main objects. More... | |
| void | setTolerance (const ModelHighAPI_Double &theTolerance) |
| Set the tolerance. More... | |
| void | setKeepNonSolids (bool theFlag) |
| Set flag whether to keep all non-solid shapes. More... | |
| bool | initialize () |
Protected Attributes | |
| std::shared_ptr< ModelAPI_AttributeSelectionList > | mymainObjects |
| std::shared_ptr< ModelAPI_AttributeDouble > | mytolerance |
| std::shared_ptr< ModelAPI_AttributeBoolean > | mykeepNonSolids |
explicit |
explicit |
inlinevirtual |
Main objects.
inlinevirtual |
Tolerance.
inlinevirtual |
| void FeaturesAPI_GlueFaces::setMainObjects | ( | const std::list< ModelHighAPI_Selection > & | theMainObjects | ) |
Set main objects.
| void FeaturesAPI_GlueFaces::setTolerance | ( | const ModelHighAPI_Double & | theTolerance | ) |
Set the tolerance.
| void FeaturesAPI_GlueFaces::setKeepNonSolids | ( | bool | theFlag | ) |
protectedinherited |
