FeaturesAPI_NormalToFace Class Reference
Interface for NormalToface feature. More...
#include <FeaturesAPI_BoundingBox.h>
Inheritance diagram for FeaturesAPI_NormalToFace:
 FeaturesAPI_NormalToFace (const std::shared_ptr< ModelAPI_Feature > &theFeature)
 FeaturesAPI_NormalToFace (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theBaseFace, const ModelHighAPI_Selection &theOptionalPoint)
 FeaturesAPI_NormalToFace (const std::shared_ptr< ModelAPI_Feature > &theFeature, const ModelHighAPI_Selection &theBaseFace)
virtual ~FeaturesAPI_NormalToFace ()
virtual std::string getID ()
virtual std::shared_ptr< ModelAPI_AttributeSelection > faceSelected () const
 base face More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > vertexSelected () const
 vertex More...
virtual std::shared_ptr< ModelAPI_AttributeString > vertexOption () const
 use a vertex More...
 Dump wrapped feature. More...
std::wstring name () const
static std::string ID ()
bool initialize ()
std::shared_ptr< ModelAPI_AttributeSelection > myfaceSelected
std::shared_ptr< ModelAPI_AttributeSelection > myvertexSelected
std::shared_ptr< ModelAPI_AttributeString > myvertexOption
◆ FeaturesAPI_NormalToFace() [1/3]
FeaturesAPI_NormalToFace::FeaturesAPI_NormalToFace ( const std::shared_ptr< ModelAPI_Feature > &  theFeature)
explicit
◆ FeaturesAPI_NormalToFace() [2/3]
FeaturesAPI_NormalToFace::FeaturesAPI_NormalToFace ( const std::shared_ptr< ModelAPI_Feature > &  theFeature,
const ModelHighAPI_Selection &  theBaseFace,
const ModelHighAPI_Selection &  theOptionalPoint
explicit
◆ FeaturesAPI_NormalToFace() [3/3]
explicit
◆ ~FeaturesAPI_NormalToFace()
FeaturesAPI_NormalToFace::~FeaturesAPI_NormalToFace ( )
◆ faceSelected()
virtual std::shared_ptr< ModelAPI_AttributeSelection > FeaturesAPI_NormalToFace::faceSelected ( ) const
base face
◆ vertexSelected()
virtual std::shared_ptr< ModelAPI_AttributeSelection > FeaturesAPI_NormalToFace::vertexSelected ( ) const
vertex
◆ vertexOption()
virtual std::shared_ptr< ModelAPI_AttributeString > FeaturesAPI_NormalToFace::vertexOption ( ) const
use a vertex
◆ dump()
void FeaturesAPI_NormalToFace::dump ( ModelHighAPI_Dumper &  theDumper) const
◆ feature()
◆ subFeature()
◆ getKind()
◆ execute()
◆ setName()
◆ result()
◆ results()
◆ defaultResult()
◆ throwException()
◆ attributeGetter()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ myFeature
◆ myAttrGetter
